    Mistake in corners
    • CupaCabraundefined
      CupaCabra
      I have a little bit trubble by the Printig corners an the Nozzel extrud 1/10s befor the print beging Material out.
      I mean between from the first layer to the start of the second layer. The print wait some time put material out an begin to printing.
      I have cange some settings in the confog.g but without success
      the config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"My Printer" ; set printer name
      M667 S1 ; select CoreXY mode
      M551 P"123" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4257.90 E420.00:420.00 ; set steps per mm
      M566 X1000.00 Y1000.00 Z12.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z360.00 E2400.00:2400.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z20.00 E500.00:500.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1200 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z450 S0 ; set axis maxima
      M574 X2 S1 P"!xstop"
      M574 Y2 S1 P"!ystop"
      M574 Z2 S2
      M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X17,5 Y15 Z1.2 ; set Z probe trigger value, offset and trigger height
      M557 X30:350 Y30:350 S60 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M140 H0 ; Disable bang-bang
      M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      G10 P0 X35 Y0 Z0 ; set tool 0 axis offsets
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M501 ;Load saved parameters
      I hope someone can help to fix it
      • JamesMundefined
        JamesM
        @CupaCabra said in Mistake in corners:
        Looks like a couple things need to be increased...z acceleration needs to be higher..I have mine at 500 for z acceleration...the same goes for both the extruder acceleration and jerk. For my extruders which are Bondtech clones I have my extruder instantaneous speed at 1200 and acceleration at 2000.
        So I would change these 2 lines to this
        M566 X1000.00 Y1000.00 Z150.00 E1200.00:1200.00 ; set maximum instantaneous speed changes (mm/min)
        M201 X2000.00 Y2000.00 Z500.00 E2000.00:2000.00 ; set accelerations (mm/s^2)
        It also looks like you are over extruding a bit so after making those changes I would work on calibrating the extruder steps/mm and then the flow rate or extrusion factor depending on which slicer you are using.
        Another thing can be if you are using simplify3d I believe there is a bug when using the wipe command where it is dependent on one of the tool change retraction speed settings or something weird. Just looking at those offset blobs I have to assume you are using wipe, coast or both. I stopped using those once I started using pressure advance so that is another thing to look into.
          CupaCabra
          thx 4 your help. #
          I will change the 2 lines, so i have the same clone bondtech extruder. Now i hope the changes will make all better than bevor.
          I print the cube next monday 🙂 and i post the result.
          i have now calibarate the the extruder 🙂 if i extrude 100mm i take 99,97mm out.
            Pressure advance will be the next thing to tune and should help a lot.
            https://duet3d.dozuki.com/Wiki/Pressure_advance
