Another Predator
  • Hello all,
    I've gone the same way as a few on these forums and got my self a AC predator.. I've had a duet 2 Ethernet along with a smart effector and PT100 daughter board and PT100 for a while it was for a linear plus but lacked time and thought good place to store it would be the in the predator the install and setup uneventful following the documentation and delta calibration guide more than once (cough 50 to 60 times) everything seems to function as I think it should ...except the printing part.
    when I installed the board I installed version 3 firmware and had the no print with that now on,
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC3 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-29b4
    with no solution to my woe's ..I've tried a few configs i.e. Jays being one NexxCats config modified for my hardware along with the RepRap config tool initially and I am stumped now the only print I did with the original Predator was the calibration print supplied and waited for the rods to arrive from Haydn then finished the build with them being 440.47mm in length any ideas would be much appreciated ..don't get me wrong its a lot of fun sat in a room tinkering for hours and days and weeks but at some point you gotta get something back as this relationship is all take take take.
    config is below along with my last (of hundred that all look the same) mesh
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
    ; Delta Settings
    M665 L440.470 R232.088 H420.498 B185.0 X0.000 Y0.000 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0.000 Y0.000 Z0.000 A0.000 B0.000 ; Put your endstop adjustments here, or let auto calibration find them
    M550 P"Street Predator" ; Set machine name
    M551 P"" ; Set password
    M552 P192.168.0.25 S1 ; Enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X80.00 Y80.00 Z80.00 E434 ; Set steps per mm
    M566 X3000 Y3000 Z3000 E40 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z12000.00 E446 ; Set maximum speeds (mm/min)
    M201 X9000.00 Y9000.00 Z9000.00 E9000.00 ; Set accelerations (mm/s^2)
    M906 X1400.00 Y1400.00 Z1400.00 E1400.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Retraction
    M207 S0.8 F350 R0.1 T1200 Z0.2 ; Firmware retraction
    M208 Z0 S1 ; Set minimum Z
    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
    M558 P8 R0.6 F800 H20 T1200 C"zprobe.in+zprobe.mod" ; Set Z probe type to switch and the dive height + speeds
    G31 P50 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
    M557 R175 S16 -0.15 ; Define mesh grid
    ;Bed Heater
    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
    M950 H0 C"bed_heat" Q100 T0 ; heater 0 uses the bed_heat pin, sensor 0, PWM frequency 100Hz
    ;Hotend
    M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50 ; configure sensor 1 as PT100 on daughter board
    M950 H1 C"e0_heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
    M143 H1 S320 ; set temperature limit for heater 1 to 320C
    M307 H1 B0 S1.00
    M950 F1 C"fan1" Q500 ; create part cooling fan 1 on pin fan1 and set its frequency
    M563 P0 D0 H1 ; Define tool 0
    ;M591 D0 P2 C4 S1 ; Activate filament sensor
    M404 N1.75 D0.4 ; Set for print monitor
    Any Ideas ? hopefully I can look like a complete moron and be simple setting i'd be cool with being tagged a moron 🙂
  • Moderator
    What exactly is the problem you're having?
    Perhaps it would be best to switch to firmware 2.05.1 for the time being?
  • @Carlo
    Nothing stands out as being wrong with your config.
    As Phaedrux said, what's actually wrong?
    I've just upgraded my predator to RC3 and I'm printing ok. I've even incorporated dc42s conditional code for the bed file.
  • Hi Phaedrux ,Jay
    Cannot get a first layer down it actually looks like the effector is being lifted and motion is odd in its not smooth
    but I've check all carriages belts motors uprights lubed magnets and balls
    I have the bulls eye level that came with the effector and its bang on ! and alllll the Delta calibration complete without issue
    I've tried the G92 Z0 before Calibration and after calibration then run mesh and without all versions of Calibration
    always the same result
    I've changed the probe trigger height always the same
    And that PLA I struggle to get off my ender3 on a bare bed
    That's with the attempted print previously below
  • @Carlo
    Try updating you M558 command to
    M558 P8 C"zprobe.in+zprobe.mod" H4 F1000 T12000 R0.2 S0.02 A5
    I had issues at one point with my probe speed being on the slow side and getting inconsistent readings.
  • @jay_s_uk
    Hi Jay,
    That’s the last iteration of config those speeds have been set to yours previously and lowered and increased at 100 increments in between and still no change ..I’ve taken off the boden and filament from my E3D Titan also removed my v2 nimble and put the Titan back on in case it was adding false probe positives still no change.
    Appreciate you looking mate great blog btw.
  • Had a quick try this morning with the suggested settings FROM jay above
    Its hard to explain but its like a learner driver is at the wheel of this thing sort of gas on gas off as its printing probing and manual movements are fine ..But during these testing prints it will accelerate during a move slow and accelerate again in the same print move so during one of the arcs move its noticeably odd non linear if that even the right context to use linear its like its not understanding what its been told or it simply cant read a map and won't ask for directions .
    I have printed a scaled version of the same file on my ender and my linear kossel and they print as this machine did on the only print to come off it in its original state which was fine to rule out the print file also sliced in 4 slicers to rule that out.
    oh and tried it with 2 carriage setups NexxCats currently and the v2 stand off with the supplied pcbs as per your blog no difference at all.
  • Installed
    @Phaedrux said in Another Predator:
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-09b1
    backdated the applicable setting as per the distructions and G92 Z0 on a fresh piece of paper calibrated well
    I'm quids in if Disney want to make a weird psychedelic lady and the tramp lots of spaghetti here.
    and I have tried lots of filaments mostly Fillamentum and a little form and the anycubic that came with it which actually prints rather nice
    Also went back to 3.0 in case some strange install issue which I'm not qualified to see be aware of.
    Not sure where to go here.
    Divorce time ?
  • @Carlo
    If you can wait a couple of days I'll be able to give you some help. Currently in Ireland away from my machine
  • @jay_s_uk
    Thanks Jay appreciate it ...Ahh Ireland wonderful place!
    Read on return..
    honestly I think the board has an issue as nothing else seems amiss
    Also you have already helped !
  • Moderator
    I'm not a delta user, so I'm limited in what to suggest, but I do often see problems like this being solved by finding a mechanical issue. Loose carriage, stuck wheel, wire pulling taught, stuff like that. In the absence of better advice, might be a good time to go over it with a fine toothed comb.
  • @Phaedrux
    Thanks,
    I'm no expert either but this things been gone over more time than a Williams F1 car surely there would be an indication in the mesh if there is movement ? dimensional issues this was done a few mins ago I get one map being ok ish luckily but all of them looking very similar as I said i'm not even experienced in 3d printing ..maybe I've been lucky until now maybe i'll just revert it back to the original configuration.
    heightmap.csv
  • Moderator
    rather than the csv, can you post a picture of the resulting heightmap?
  • @Phaedrux
    Here we go,
    Cheers
  • So I thought I'd throw the original board back in and test for dimensional issues or mechanical issues as suggested
    and well found nothing except it print fine in fact its better than the print I got off it previously no stringing at all granted my testing is not substantial or very scientific even but it does suggest the actual dimensional built is good enough to get an actual print and that's not stock literally did one z probe and using printed effector adapter ends for the magballs and rods from Haydn.
    Any ideas ?
    Cheers
    Please share your bed.g file.
    Have you measured the trigger height of the strain gauge sensor? It's set to -0.1mm in your config.g file, but if the bed is soft then you might need to change it to a more negative value.
    When you run auto calibration, what deviation does it report at the end?
    For best results, use this sequence:
    • Home the printer
    • Heat the printer (bed and extruder) up to operating temperature, or close to it
    • Run auto calibration (and don't re-home at the end of it)
    • Start the print without homing it again
    A well-built delta printer using the Smart Effector and a flat bed doesn't need mesh bed compensation. If you do use mesh bed compensation by loading a pre-made height map using G29 S1, do a single G30 probe at bed centre after loading the height map.
  • @dc42
    I have tried all of that
    I always pre heat
    My config is set to 0.1 when starting a test again
    Generally it returns .12 which I’ve set it to in the config on the G30 single probe
    Not set it and left it at 0.1
    I don’t home after a single probe or delta calibration
    Have tried with mesh and without
    Home ,G30 Z0 then probe
    Home probe then G30 Z0
    I’m not sure there is a way I have not tried
    I’ve slowed my FR down
    Sped it up reduced my travel speed sped it up
    The maps look right though do they as I don’t know if the are?
    I follow the guides and suggestions from the good people here
    I’ve used other config as a starting point as well configured from scratch
    Always with the same result exactly the same.
    So it is either something I am doing every single time and we are talking hundreds of time
    Or it’s a constant issue that doesn’t appear with the original controller.
    So would suggest not mechanical.
    Cheers
    You haven't answered some of my questions:
    Have you measured the trigger height of the strain gauge sensor? it looks to me that you are starting printing too high, which suggests that your trigger height isn't set correctly.
  • Hi,
    Bed.g
    ; bed.g file for RepRapFirmware, generated by Escher3D calculator
    ; 10 points, 6 factors, probing radius: 175, probe offset (0, 0)
    G30 P0 X0.00 Y175.00 Z-99999 H0
    G30 P1 X151.55 Y87.50 Z-99999 H0
    G30 P2 X151.55 Y-87.50 Z-99999 H0
    G30 P3 X0.00 Y-175.00 Z-99999 H0
    G30 P4 X-151.55 Y-87.50 Z-99999 H0
    G30 P5 X-151.55 Y87.50 Z-99999 H0
    G30 P6 X0.00 Y87.50 Z-99999 H0
    G30 P7 X75.78 Y-43.75 Z-99999 H0
    G30 P8 X-75.78 Y-43.75 Z-99999 H0
    G30 P9 X0 Y0 Z-99999 S6
    I've tried a few trigger heights as per documentation initially stating higher until calibration is done
    trigger height of the strain gauge sensor? is that not -.12 ?
    Glass build plate as far as I know
    I have tried it with as far as -.2 even though on the single probe indicates -0.12 although I do appear to have a pit forming at the center now.
    Cheers
