    Using the 10th Stepper (D axis?)
    386
    • TechnomadicJimundefined
      TechnomadicJim
      Hi Duet / All
      Thanks for creating such a great board. I'm really enjoying using it although I have one issue I can't seem to find an answer for on the forums or in the docs:
      I want to use all 10 stepper drivers on my Duet Ethernet + DueX5 as axes for a CNC project. I can get the first 9 to work fine (X Y Z U V W A B C) but I can't get the 10th (drive mapping 9, axis D) to appear or work. Here's my config:
      G90                              ; Send absolute coordinates...
      M83                              ; ...but relative extruder moves
      M550 P"Duet3D"                 ; Set machine name
      M551 P"xxxxxxxxx"                 ; Set password
      M552 P0.0.0.0 S1                 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1                       ; Enable HTTP
      M586 P1 S0                       ; Disable FTP
      M586 P2 S0                       ; Disable Telnet
      M584 X0 Y1 Z2 U3 V4 W5 A6 B7 C8 D9; Setup additional drive mappings
      M569 P0 S0
      M569 P1 S0
      M569 P2 S1                       ; Z Goes forwards. The rest back.
      M569 P3 S0
      M569 P4 S0
      M569 P5 S0
      M569 P6 S0
      M569 P7 S0
      M569 P8 S0
      M569 P9 S0
      M350 X16 Y16 Z16 U16 V16 W16 A16 B16 C16 D16 I1              ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z80.00 U80.00 V80.00 W80.00 A80.00 B80.00 C80.00 D80.00         ; Set steps per mm
      M566 X900.00 Y900.00 Z900.00 U900.00 V900.00 W900.00 A900.00 B900.00 C900.00 D900.00     ; Set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y6000.00 Z24000.00 U6000.00 V6000.00 W6000.00 A6000.00 B6000.00 C6000.00 D6000.00  ; Set maximum speeds (mm/min)
      M201 X300.00 Y500.00 Z500.00 U500.00 V500.00 W500.00 A500.00 B500.00 C500.00 D500.00   ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z1200.00 U800.00 V800.00 W800.00 A800.00 B800.00 C800.00 D800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                          ; Set idle timeout
      ; Drive end stop sensitivity
      M915 Y Z U V W A B C D S3 R0 F0
      M208 X0 Y0 Z0 U0 V0 W0 A0 B0 C0 D0 S1                 ; Set axis minima
      M208 X800 Y200 Z200 U200 V200 W200 A200 B200 C200 D200 S0           ; Set axis maxima
      M564 S0 H0			 ; allow movement of axes that have not been homed, allow movement outside boundaries
      M574 X1 S1			 ; Set endstops controlled by micro switch (just X axis)
      M574 Y1 Z1 U1 V1 W1 A1 B1 C1 D1 S3  ; Set endstops controlled by motor load detection
      M140 H-1                         ; Disable heated bed
      M307 H3 A-1 C-1 D-1              ; change heater 3 for the open/close lid relay
      M307 H4 A-1 C-1 D-1		 ; change heater 4 for servo for flap
      M307 H5 A-1 C-1 D-1              ; change heater 5 for the start button relay
      M307 H6 A-1 C-1 D-1              ; change heater 6 for the enter button relay
      M307 H7 A-1 C-1 D-1              ; change heater 7 for the laser relay
      ;M106 P0 S0 I0 F500 H T45         ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ;M106 P1 S1 I0 F500 H1 T45        ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Any idea what I'm missing or doing wrong?
      Thanks in advance!
      Jim
      Firmware Electronics: Duet Ethernet 1.02 or later + DueX5
      Firmware Version: 2.05.1 (2020-02-09b1)
      Web Interface Version: 1.22.6
      droftartsundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @TechnomadicJim
        @TechnomadicJim see https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
        U, V, W, A, B, Cnnn Driver number(s) for additional axes U, V, W, A, B and C (UVW available in RepRapFirmware 1.16 and later; UVWABC available in RepRapFirmware 1.19 and later; UVWABCD available in RepRapFirmware 3.0 and later)
        No D in RRF2. You’re going to have to update to RRF3. But that’s okay, it’s the future!
          TechnomadicJim
          Thanks for your reply Ian. I've upgraded to 3.01-RC3 (I also tried the non RC stable version) but I'm still unable to access the D axis. Is my config.g correct? I'm not sure what else to try.
          Board: Duet Ethernet 1.02 or later + DueX5
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC3 (2020-02-29b4)
          Thanks for your help so far!
            @TechnomadicJim can you post your new config.g for RRF3?
              If you send M584 without parameters, does the response mention the D axis? Likewise if you send M92 without parameters.
              TechnomadicJimundefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @TechnomadicJim
                This post is deleted!
                  TechnomadicJim
                  Here you go:
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 22:12:05 GMT+0000 (Greenwich Mean Time)
                  G90        ; send absolute coordinates...
                  M550 P"PrinterName"        ; set printer name
                  M551 P"xxx"        ; set password
                  M552 P0.0.0.0 S1        ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1        ; enable HTTP
                  M586 P1 S0        ; disable FTP
                  M586 P2 S0        ; disable Telnet
                  M569 P0 S0
                  M569 P1 S0
                  M569 P3 S0
                  M569 P4 S0
                  M569 P5 S0
                  M569 P6 S0
                  M569 P7 S0
                  M569 P8 S0
                  M569 P9 S0
                  M906 X800.00 Y800.00 U800.00 V800.00 W800.00 A800.00 B800.00 C800.00 D800.00 I30            		; Set motor currents (mA) and motor idle factor in per cent
                  M906 Z1600.00 I30                                           						; Give Z more current for stronger clamping.
                  M140 H-1        ; disable heated bed (overrides default heater mapping)
                    The maximum number of axis on Duet 2 is currently 9. I can increase it to 10 in release 3.01RC4.
                      TechnomadicJim @dc42
                      @dc42 said in Using the 10th Stepper (D axis?):
                      It doesn't although it does mention "E3" which is odd.
                      Driver assignments: X0 Y1 Z2 U3 V4 W5 A6 B7 C8 E3, 9 axes visible
                      Ahh ok thanks. So I'm not going mad and it's a software limitation? Looking forward to testing RC4 🙂
                        TechnomadicJim
                        I just upgraded to 3.01RC4 and I can now use the D axis.
                        Thanks @dc42 for the quick fix. Much appreciated. Also thanks @droftarts for your help too.
