    duet maestro and duex5 exp. board compatible?
    • reneh
      reneh last edited by
      Hello all,
      is it possible to connect a duex5 expansion board to an duet maestro board? If not - how can i connect 4 z-stepper motors on a duet maestro board?
      Thank you for help.
      René
      • jay_s_uk
        jay_s_uk last edited by
        @reneh
        I believe you can only connect another 2 motors to the maestro.
        So I think the short answer is no, you can't connect the duex5 to it and no, you can't connect a further 4 motors to the maestro.
        • bricor
          bricor last edited by
          Maestro Guide:
          https://duet3d.dozuki.com/c/Duet_2_Maestro#Section_Compatible_add_on_Hardware
          • A Former User
            Yeah the Meastro does not have enough pins to control more than the adittional 2 steppers you get with the expansion (another bottleneck might be the MCU in general).
            Not sure why the expansion isn't in the link above, or not linked to from the Duet 2 Maestro product page, but there is a guide on the wiki at least. https://duet3d.dozuki.com/Wiki/Dual_Stepper_Driver_Expansion_Module
            edit: may explain: https://forum.duet3d.com/post/51214
            bricor 1 Reply Last reply Reply Quote 0
            • bricor
              bricor @Guest last edited by
              @bearer The Dual Stepper Expansion is listed (pictured) near the top of the page under Related Pages.
              Points to https://duet3d.dozuki.com/Wiki/Dual_Stepper_Driver_Expansion_Module
              • aidar
                aidar last edited by
                And here is link from Duet shop https://www.duet3d.com/DuetAddons/Duet2Maestro2StepExpansion
                • reneh
                  Hello all,
                  this was very helpful.
                  Thank you
                  René
