    Cartesian to CoreXY conversion
    936
    • Valld
      Valld last edited by
      Hi Everyone. I managed to replace almost every bit of my Ender 5 Plus, including the control board to Maestro. My last upgrade was to convert the mechanics from cartesian to corexy and all is working fine, movement, origin and homing are OK I managed to make all changes following the Duet wiki. I only have one issue (I don't even know if it's a problem). Now the X and Y axis are swapped. On the movement section when I want to move the Y axis (front back direction) I have to press the X-, X+ buttons and when I want to move the X axis (left - right direction) i have to use the Y+ and Y- buttons. I haven't yet completed the hot end, so no test prints so far, just wanted to know if this is something specific to the CoreXY, or I messed up the configuration.
        You are not alone, lot of users have trouble with CoreXY motor directions. I suggest you follow https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter and post again if you still have trouble.
        Valld 1 Reply Last reply Reply Quote 0
        • droftarts
          droftarts administrators @Valld last edited by
          @Valld Also see https://duet3d.dozuki.com/Wiki/Test_axes_or_motors_individually
          The origin (X0,Y0) should ideally be when the nozzle is over the front left corner of the bed. You can also set it to the centre (I do). Positive X moves should move the nozzle to the right, positive Y moves should move it back.
          You may need to swap the motor connections (or remap X to Y and Y to X with M584 in config.g) if the motors are moving the carriage in the wrong direction.
          With the Z axis, don't be confused by some of the comments in the home.g files. They say things like 'Move Z up'. But this is assuming the nozzle moves up (like in a machine with a gantry), rather than the bed moving down! Think of it as Z 'increasing', ie more distance between the nozzle and bed.
          Perhaps draw a diagram of your printer similar to this, to help visualise where everything is:
          • Valld
            Valld @dc42 last edited by
            @dc42 I did follow the instructions and everything went easy and well, except that Y is X and X is Y ( when I try to navigate from the Machine Movement). If I send G91 followed by G1 S2 X10 F3000 as per the instructions the gantry goes towards + X +Y , same for G1 S2 Y10 F3000, it moves in +X and -Y. Z moves properly, X and Y homing is OK, the BL touch is homing Z correctly, Z offset is fine, If I could swap the X and Y in the Machine Movement section on the web interface I wouldn't have a question (and I still don't know if I really have a problem). Ill post my config.g (drives and endstops section) and homeall.g belo9w:
            M667 S1 ; switch to CoreXY mode; M669 K1
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P1 S1 ; physical drive 1 goes backwards
            M569 P3 S1 ; physical drive 3 goes backwards
            M584 X0 Y1 Z2:4 E3 ; set drive mapping k
            M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
            M92 X160.00 Y160.00 Z3200.00 E818.00 ; set steps per mm
            M566 X1000.00 Y1000.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) (Z was 24)
            M203 X8000.00 Y8000.00 Z400.00 E8000.00 ; set maximum speeds (mm/min) (Z was 180)
            M201 X500.00 Y500.00 Z120.00 E3000.00 ; set accelerations (mm/s^2) (Z was 100)
            M906 X800 Y800 Z800 E900 I40 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X340 Y345 Z700 S0 ; set axis maxima
            G91 ; relative positioning
            G1 H1 X320 Y320 F3000 ; home X and Y
            G1 H1 X320 ; coarse home X
            G1 H1 Y320 ; coarse home Y
            G90 ; absolute positioning
            G1 X175 Y175 F6000 ; go to MidBed and home Z
            G29 S1 ; load heiht map automatically
            • Valld
              Valld @droftarts last edited by Valld
              @droftarts Thanks for the input. My machine configuration is exactly the same as on the photo, with two differences, my X and Y motors are mounted at the back side and I'm using Y high and X high endstops, so the gantry homes at the right back side of the printer at X340 Y340, Origin at X0 Y0 at front left corner. I tried swapping the two motors and went bad, everything moves in different direction. Photo below:
                dc42 administrators @Valld last edited by dc42
                @Valld said in Cartesian to CoreXY conversion:
                First decide which directions you want to be +X and +Y, and then get the motors moving in the correct directions, as described in the instructions.
                • droftarts
                  @Valld Are you saying that you press the X buttons in DWC, the carriage moves in Y? What happens if you send G1 X10? And are you sure it moves in +X and -Y for G1 S2 Y10 F3000, not -X and +Y?
                  On a different note, is that a SecKit SK-Go? Your belt connections to the X carriage are not correct; they are joining at an angle, when they should be straight. You're going to have problems with belt tensioning, and X accuracy across the bed. Certain belts on a CoreXY MUST be parallel or perpendicular to each other. See @mrehorstdmd excellent blog here: https://drmrehorst.blogspot.com/2018/08/corexy-mechanism-layout-and-belt.html
                  To quote: "[belt] segments A-H must be parallel to the guide rails or the belt tension will vary with the position of the extruder carriage."
                  Valld 1 Reply Last reply Reply Quote 1
                  • Valld
                    @droftarts Thank you! I finally managed to sort out the motor movement, as dc42 said more than ones, "follow the instructions". All moves and homes properly now.
                    Regarding your note on the belt connections to the X carriage, yes, I used the design from the SecKit SK-Go and was wondering why the XY joiner pulleys are not combined, and now thanks to you I know. I will complete all the wiring and see how it prints and when i see that its not printing properly, I'll change my design accordingly, thanks for the heads up, I really appreciate it!
                    • Valld
                      @dc42 Thanks for your help, you were 100% right to say "follow the instructions". All movement and homing works perfect now (in terms of direction)
                      • droftarts
                        I'd fix it now. It may print correctly in the middle, but it will be putting extra load on the belts when the carriage is at the end of the axes, eg when homing. Try feeling the belt tension when the carriage is in the middle versus when it's at X0 Y0. Often with CoreXY you need accurately and consistently tensioned belts to square the X axis to the Y axis, so this may also be moving around as the carriage moves.
                        • Valld
                          @droftarts I cannot express how much I appreciate your input on this, just to confirm, I need to make this marked in red two sections of the belts from the joiner to the gantry mount parallel , correct, see the photo below:
                          droftarts mrehorstdmd 2 Replies Last reply Reply Quote 0
                          • droftarts
                            @Valld yes, and the same on the other side of the X carriage.
                            • mrehorstdmd
                              mrehorstdmd @Valld last edited by
                              @Valld And not just parallel to each other, but parallel to the X axis guide rail.
