    looking for good starting gcode
    400
    • Co3get
      Co3get last edited by
      I'm working on a start gcode (I use Prusa slicer) that will move the nozzle out to the beginning of the print at +10 Z or so then lowering it. Trying to solve the problem of dragging cross the bed at first layer height to the beginning of the print. What I have (below) doesn't work even though I move the Z up at the end. IDeas?
      Working with this:
      ;prepare positions
      G21 ;metric values
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      M104 S[first_layer_temperature_0]; heat hotend (no wait)
      G28 X0 Y0 ;move X/Y to min endstops
      M190 S[bed_temperature]; heat bed (wait)
      M109 S[first_layer_temperature_0]; heat hotend (wait)
      G92 E0 ;zero the extruded length
      G1 F200 E8 ;extrude 8mm of feed stock
      G92 E0 ;zero the extruded length again
      G28 Z10 ;move Z up
      M420 S1 ; ensures auto leveling is enabled
      M117 Printing...
      • aidar
        aidar last edited by
        @Co3get said in looking for good starting gcode:
        G28 Z10 ;move Z up
        G28 is homing command, not just moving. So you should use here G1 Z10 (if your nozzle is not at that high or more already). If you want to move Z up 10 from current position, you should also use relative mode first, so commands should be :
        G91
        G1 Z10
        G90
          Phaedrux Moderator @Co3get last edited by
          M420 isn't implemented in RRF. What you want is G29 S1.
          • DIY-O-Sphere
            DIY-O-Sphere last edited by
            @Co3get
            If I got you right, you would like to move to the starting point in a diagonal Z path.
            Like in Cura? I would prefere that too.
            That's related to the code Prusaslicer is writing after the start sequence.
            So it's not posible to do it in that way.
            What I have done, is to edit the gcode manually.
            For example:
            G1 Z0.195 F9600.000
            G1 X217.576 Y47.012 F9600.000
            Put the Z and XY part together
            G1 X217.576 Y47.012 Z0.195 F9600.000
            (For clarity I have removed some lines of original code)
            (UTC+1)
            Co3get 1 Reply Last reply Reply Quote 0
            • Co3get
              Co3get @DIY-O-Sphere last edited by
              @DIY-O-Sphere said in looking for good starting gcode:
              @Co3get
              For example:
              G1 Z0.195 F9600.000
              Yes that is it in a nutshell... might be reason enough to use Cura even though I like PrusaSlicer so much.
                If you're dragging across the bed to get to the start of the print that may be related to using M420 to enable the mesh compensation. G29 S1 should work and if your mesh is done properly it shouldn't be touching the bed at all.
                • Co3get
                  Co3get @Phaedrux last edited by
                  @Phaedrux I'm printing on a textured sheet and its very very close.
                    As a work around if you don't want to switch slicers could be to use baby stepping manually while you are watching the start of the print. Simply up the baby stepping while it's moving to position and then reduce it after it's in position.
                    • Danal
                      Danal last edited by
                      G28 Z10 ;move Z up
                      That is not doing what you want. Do a G1 Z10 F6000, or similar G1 command. That will fix a lot of things; do that first and adjust from there.
