    CR10S Bondtech E3D, Dual Z outputs - Cura Settings.
    • Turricann
      Turricann last edited by
      I am new to the Duet wifi (Just Set up the first time ) and was wondering if anyone had a good starting point for the configuration od X,Y and Z
      Microstepping (interpolation)
      Max. Speed Change (mm/s)
      Max. Speed (mm/s)
      Acceleration (mm/s²) Motor Current (mA) using stock motors except extruder is a pancake.
      If anyone can give me a cura profile they use to get me started I would appreciate it.
      • Danal
        Danal last edited by
        Most of the things you've asked for should be in the config.g on the printer, not in Cura.
        See https://configtool.reprapfirmware.org/ for a great way to get started.
        • Turricann
          it is a great way to get started which is where I am @ but I wanted to know what settings users found works best instead of default values.
          Danal droftarts 2 Replies Last reply Reply Quote 0
          • Danal
            Danal @Turricann last edited by Danal
            @Turricann said in CR10S Bondtech E3D, Dual Z outputs - Cura Settings.:
            microstepping of 16x with interpolation is best 99.9 percent of the time.
            Speeds and accel are HIGHLY dependent on your mechanics. A CR10s is going to work pretty well on the defaults. Anyone with a CR10s on duet should chime in, if they've found any fine tuning.
            • droftarts
              droftarts administrators @Turricann last edited by
              @Turricann As a CR10S is pretty much the same as an Ender 3, see @Phaedrux guide here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38#s125
              If you have a copy of the CR10S Marlin configuration, you can get the stock settings from there. Be aware that Marlin defines things in mm/second, which RepRapFirmware uses mm/minute.
