    Keep losing Z offset
    497
    • Weevil
      Weevil last edited by
      I don't know what happened but now I keep losing my z offset each time the printer is homed, restarted or ends a print. I can't make sense of the thing.
      • Turbo
        Turbo last edited by
        do you have the offset defined in the config.g file? the line should start with a G31 and look something like
        G31 X0 Y23 Z0.650 P25
        or
        G31 P500 X55 Y10 Z1.05
        The main parameter is gonna be the z value.
        Cant stop tuning wont stop tuning.
        Dbot, Custom i3, Voron 0&2
        Weevil 1 Reply Last reply Reply Quote 0
        • Weevil
          Weevil @Turbo last edited by
          @Turbo Yes, here it is:
          G31 P500 X-38 Y0 Z0.95
          But the head is too close to the bed now. I don't know what happened.
          • Turbo
            try an extreme. Set the z offset to be way too high, in this case 0 or less, and see if where z=0 is too high. if its still contacting the bed, try a negative value (not sure if bltouch will take a negative value but its worth a shot if 0 doesnt work.)
            I always have to make a note in my config file which way goes which with a value change, like so:
            G31 X0 Y23 Z0.650 P25             ; Probe Offset - Increase for Nozzle down, Decrease for Nozzle up
            Report back when you finish
            • Weevil
              Weevil @Turbo last edited by Weevil
              @Turbo I'll be damned. I threw a negative sign in front of the value and that seems to work. I am fine tuning now. Thanks.
              • Turbo
                Awesome!
                • Weevil
                  @Turbo It appears to still be an issue. I lost Z offset after last night's print. The settings are still there in config.g. Simply saving the file again without any changes restores the Z offset. Something is resetting my G31 numbers.
                    What firmware are you using? What duet?
                    Can you post your config.g and homeall?
                    What do you have in your slicer start and end gcode?
                    • Weevil
                      Weevil @Phaedrux last edited by
                      @Phaedrux
                      Board: Duet 3 MB6HC v0.6 or 1.0
                      Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC4 (2020-03-16b1)
                      Config.g:
                      G90
                      M83
                      M550 P"MYTH3D"
                      M667 S1
                      ; Networking
                      M552 P192.168.1.14 S1
                      M553 P255.255.255.0
                      M554 192.168.1.1
                      M586 P1 S1
                      M586 P2 S
                      M552 S1
                      M569 P0.0 S1
                      M569 P0.1 S0
                      M569 P0.2 S1
                      M569 P0.5 S1
                      M569 P0.3 S1
                      M569 P0.4 S1
                      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5
                      M350 X16 Y16 Z16 E16 I1
                      M92 X78.74 Y78.65 Z394.04 E494.74
                      M566 X900.00 Y900.00 Z12.00 E120.00
                      M203 X6000.00 Y6000.00 Z180.00 E1200.00
                      M201 X500.00 Y500.00 Z20.00 E250.00
                      M906 X800 Y800 Z800 E800
                      M84 S30
                      M671 X-15:150:310 Y50:310:150 1S0.5
                      M208 X0 Y0 Z0 S1
                      M208 X300 Y300 Z500 S0
                      M574 X2 S1 P"io5.in"
                      M574 Y1 S1 P"io2.in"
                      M950 S0 C"io7.out"
                      M558 P9 C"io7.in" H5 F120 T6000
                      G31 P500 X-38 Y0 Z0.75
                      M557 X15:227 Y5:210 S50
                      M308 S0 P"temp0" Y"thermistor" T100000 B4138
                      M950 H1 C"out1" T0
                      M143 H0 S280
                      M950 F1 C"out7" Q500
                      M106 P1 S1 H T45
                      M950 F0 C"out8" Q500
                      M106 P0 S255
                      M501
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                      M563 P0 S"MYTHprint" D0 H1 F0
                      M563 P0 D0 H1 F0
                      G10 P0 X0 Y0 Z0
                      G10 P0 R0 S0
                      T0
                      Homeall.g:
                      G91
                      G1 H2 Z5 F6000
                      G1 H1 X305 Y-305 F2000
                      G1 H1 X305
                      G1 H1 Y-305
                      G1 X-5 Y5 F6000
                      G1 H1 X305 F360
                      G1 H1 Y-305
                      G1 X-150 Y150 F6000
                      M558 F500
                      G30
                      M558 F50
                      G30
                      G32
                      Slicer start code:
                      G28
                      Slicer end code:
                      G91
                      G1 H2 Z5 F6000
                      G1 H1 X305
                      G1 H1 Y-305
                      G1 X-5 Y5 F6000
                      G1 H1 X305 F360
                      G1 H1 Y-305
                      M104 S0
                      M140 S0
                      M84
                      • fcwilt
                        fcwilt last edited by
                        You can always reset in your "slicer start code" to be sure it is correct.
                          You've got g32 in your home all. What is in bed.g?
                          • Weevil
                            @Phaedrux Bed.g:
                            ; bed.g
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
                            G29 ; probe the bed and enable compensation
                            • JamesM
                              JamesM last edited by
                              I'm no expert with firmware but comparing your homeall to mine, I have a G90 before calling any G30 commands...maybe an issue with relative vs absolute positioning???
                              This is my homeall.g
                              G91 ; relative positioning
                              G1 S1 X-350 Y350 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                              G1 S1 X-350 ; home X axis
                              G1 S1 Y350 ; home Y axis
                              G1 X5 Y5 F600 ; go back a few mm
                              G1 S1 X-10 ; move slowly to X axis endstop once more (second pass)
                              G1 S1 Y-10 ; then move slowly to Y axis endstop
                              G90 ; absolute positioning
                              G1 X170 Y160 F6000 ; go to first bed probe point and home Z
                              Weevil 2 Replies Last reply Reply Quote 0
                              • Weevil
                                Weevil @JamesM last edited by
                                @JamesM Thanks, I'll try that.
                                • Weevil
                                  @JamesM That one change threw the homing off. I reverted back to the original settings. Thanks anyway for the suggesstion.
                                    Phaedrux Moderator @Weevil last edited by
                                    @Weevil said in Keep losing Z offset:
                                    What exactly do you mean by this? Do you mean that the first layer isn't good? Do you mean that G31 is literally blank?
                                    Head crash? Loose print head? Probe mount shifted?
                                    I'd recommend removing G32 from your homeall. All it does is clear the current transform and then runs mesh compensation. May be overkill to re probe the entire bed every time you homeall. You could use G29 S1 instead at the end of homeall which would load a saved heightmap.
                                    Change the P500 to P25 to make the BLTouch trigger a bit more sensitive.
                                    Weevil 1 Reply Last reply Reply Quote 1
                                    • Weevil
                                      @Phaedrux I'll try that. Thanks.
