Nozzle probes off bed.
Glad you got it! Its really weird at first, but it makes a lot of sense when it clicks ya know. If youve got any more issues lemme know
@Turbo Thanks, I'm hoping with the touch mounted on the left I can get most of the bed mapped out. (Since the probe can move more to right of the hotbed)
Can anybody explain how to do the above when you’re bed origin is at the Centre?
I’m using a induction sensor with a special print bed top. My printer is an Ender 5 pro, with a duet 2 maestro board.
My probe offset is -60(x) and -12(y).
What’s the formula you should use to figure out what to program your settings to so my probe doesn’t go off the bed?
Thank you so much for your hell with this!
@Damien it should be very much the same since it's still just a cartesian X Y coordinate system. The only difference with having 0,0 in the center is that the low ends will be negative.
What are your M208 limits?
@Phaedrux right now it’s
M208 X-110 Y-110 Z0 S1
M208 X110 Y85(Due to the HeroMe Gen5 duct installed) Z300 S0 -
I was thinking of putting together an Excel Spreadsheet and sharing it so it figures out min/max values automatically.
Thank you for your help, by the way!
Alright, so the M557 would as far as you want on the low side because your probe offsets are to the low side, and on the high side it would only be able to reach as far as x110 - x60 and Y85 - y12
@Damien The easiest way to find the ideal M557 for me in practice is to just jog the print head around so that the probe is where I want it and take those XY coordinates.
Ok....I am still so confused!
So I took you suggestion about jogging head around to find what I can work with based on my mods.
As a result, my min/Max axis has changed.
Below is my config. What calculations should I use to figure out how to define the grid again?
Thank so much in advance!!
; Configuration file for Duet Maestro (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 22:55:16 GMT-0500 (Colombia Standard Time); General preferences
M550 P"Damiens Ender 5 Pro" ; set printer name; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P3 S0 ; physical drive 3 goes backwards
M350 X64 Y64 Z64 E128 I1 ; configure microstepping with interpolation
M92 X320.00 Y320.00 Z3200.00 E747.59 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-110 Y-110 Z0 S1 ; set axis minima
M208 X105 Y92 Z300 S0 ; set axis maxima; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop; Z-Probe
M558 P5 C"!^zprobe.in" H5 A1 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P200 X-60 Y-12 Z5.98 ; set Z probe trigger value, offset and trigger height
M557 X-110:110 Y-110:110 S10 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A140.3 C627.1 D0.2 S1.00 V22.9 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A340.0 C140.0 D5.5 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0:2 ; define tool 0
M501 -
Maybe it would help if you created a diagram of your bed like this one.
By the way, 60mm in the x direction is quite a bit. Is that really the closest you can get the probe to the nozzle?
Thank you for this. I'll fill in and see if it helps. I'll post image if I still can't work it out.
In the meantime, here are some pics of my setup. With the Induction sensor I have, this is the closest I could get it...
Ok, here it is....What do you think?
@Phaedrux When I input the ranges of the green the probe still goes over the edge. Any pointers?
What's the coordinate of the nozzle that keeps your probe on the bed?
@Phaedrux all the coordinates you see in the green are ones where the sensor stays over the bed. But, so some reason when I put my M557 x-110:55 Y-110:82 S10 other first probe starts at x-50 y-98. 🤨
Then it proceeds to keep probing until off the bed on the x axis, which I then have to emergency kill it.
Ok, I just tried adding the probe offset on one side of the green coordinates and minus’’Ed on the other and that seems to have done the trick.
So my coordinates for M557 is now X-170:-5 Y-122:94. Probing is perfect now.
@Phaedrux Before I continue, I wanted to say a big thank you for your help before! It's good to have people like you helping us all make the most out of our printers.
After all of the above, I have decided to make my origin back to its original place in the corner. I've decided this because I am not getting a good consistent squish across the various spots on my bed. Plus, I am not confident that the mesh on my bed that I got is correct. (See below)
I'm just about to redo my trigger height, but I have a question. In the guide(https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe), it calls for you to bring your nozzle to the center of the bed and do the paper test. Afterward, it asks you to begin your trigger height routine. BUT, here is my question...
Seeing as my probe offset is so far, isn't it a better idea to bring the probe over the same spot I did the paper check to make sure I have a consistent base height? Or, does the programming for the G29 somehow compensate for this?
Thanks in advance!
Answered in your other thread.
