    Duet Wifi Wlan vs WPA2 = Connection Error
    74
    • Warstone
      Warstone last edited by
      As the titled say: i got a connection problem with my Duet Wifi. A friend and i configured the Board and linked it up to his home w-lan without any problem. We do all the necessary things to get the printer started and it worked.
      When i get home, i just entering the commands as shown:
      M552 S-1
      M552
      M552 S0
      M552
      M587 S“My SSID“ P“ My Password“
      M587
      M552 S1
      After that i get connection error (see protocol below). Several attempts later I changed the SSID and passwords but nothing worked.
      So I decided to set up a WiFi HotSpot with my Galaxy S7 and zoom … the Duet connected to the Smartphone after 3 Secs.
      So I tried to connected back to my home Wifi and get the typical message: error
      I retry the Smartphone which was working fine and then decided to try a connection to my neighbors WiFi and again: zooom connection after 3 secs (ask for his Password and SSID)
      I went further and enabled MAC in my Router Option … nothing … the only way for connecting was to disable the WPA / WPA2 protocol in my router and surprise: we get a stable connection after 3 secs …
      Hopefully someone has a idea to fix this, I use a Vodafone Router with the newest firmware. Other devices as our smartphones, the normal HP printer and Smart- TV / TV- Stick work still fine with the router settings.
      YAT Protocol
      M552 S-1
      WiFi module stopped
      ok
      M552 S-1
      ok
      M552 S0
      ok
      WiFi module started
      M552 S1
      ok
      WiFi reported error: Timed out while trying to connect to DWTN
      WiFi module is idle
      WiFi reported error: no known networks found
      WiFi module is idle
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DJM-9178L-L2MSD-6JKD0-3S46Q-TTFGP
      Used output buffers: 2 of 24 (3 max)
      Static ram: 25712
      Dynamic ram: 93176 of which 0 recycled
      Exception stack ram used: 304
      Never used ram: 11880
      Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
      Owned mutexes:
      Last reset 01:35:48 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11872 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 24.0, current 26.2, max 27.0
      Supply voltage: min 0.1, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Slowest loop: 99.79ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.34ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is changing mode
        WiFi module is idle
        Failed to get WiFi status
        ok
        Error retrieving WiFi status message: bad reply format version
        WiFi module is idle
        Failed to change WiFi mode (code -4)
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User last edited by
        i think this is the second report of an incompatbility with vodafone routers. no solution as far as I know.
        Doubt its relevant, but any special characters in the key?
        • Warstone
          Warstone last edited by Warstone
          No, just a standard Key like "A1234567b" (was my testing Key)
          • matt3o
            matt3o last edited by
            is the SSID hidden? that can sometimes cause issues
            • A Former User
              A Former User @Warstone last edited by
              it wouldn't try to connect to DWTN without it specified on the M552 command if it was hidden
              • Warstone
                SSID is broadcasted
                The Router know the MAC of the Duet
                The Duet is remembering the SSID (and Password)
                Executing config.g...Error: M587: Failed to add SSID to remembered list
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                M552 S-1
                WiFi module stopped
                ok
                M552 S0
                ok
                WiFi module started
                M587
                Remembered networks:
                DWTN IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                ok
                • droftarts
                  droftarts Moderator @Warstone last edited by
                  @Warstone as @bearer said, there seems to be an issue with Vodafone Station routers. This may be related to an obscure bug in the Duet WiFi firmware. See this thread https://forum.duet3d.com/topic/14993/cannot-connect-duet-wifi-to-new-wifi-router
                  Ideally, use an access point to connect for now.
                  • Warstone
                    Hooked up my old D-Link Wifi router between the Vodafon router and my PC. It slows down my connection a bit, but the Duet is connecting without any problems to the D-Link instead of the Vodafon Router.
