    Duet Maestro 2 stops mid print
    409
    • massynrt
      massynrt last edited by
      Please help - I'm new to 3d printing. My printer stops mid print for now reason. When I log into the web console, I find the duet Restarted. Nothing homed.. How do I find the problem?
      Please help. Where do I start looking for the problem..
      I am running the latest firmware for the Duet 2 Maestro - Release 2.05.1 (Duet 2), 1.26.1 (Duet 06/085)
      Rudi
      • PaulHew
        PaulHew last edited by
        Can you post the results of a M122 please
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • massynrt
          Here it is - Does it matter when I run the M122 command. Must it be right after a fail, or is this one good.
          RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
          Board ID: 08DJM-9X66L-LG3SN-6J1FD-3SJ6M-9BZAR
          Used output buffers: 3 of 24 (15 max)
          Static ram: 19804
          Dynamic ram: 87320 of which 0 recycled
          Exception stack ram used: 204
          Never used ram: 23744
          Tasks: NETWORK(ready,764) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
          Owned mutexes:
          Last reset 00:52:32 ago, cause: software
          Last software reset at 2020-03-30 09:34, reason: Unknown, spinning module Platform, available RAM 23288 bytes (slot 1)
          Software reset code 0x40b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000fe4 Task 0x5754454e
          Stack: 004042f7 004046a2 a1000000 20008498 00404d97 00000001 00405765 2000849c e000ed01 20001c0c a5a5a5a5 a5a5a5a5 00000001 200083a0 92cb8acf 00000000 004094a5 a5a5a5a5 10000000 e000ed04 20001c0c a5a5a5a5 00409507
          Error status: 0
          Free file entries: 10
          SD card 0 detected, interface speed: 15.0MBytes/sec
          SD card longest block write time: 2.8ms, max retries 0
          MCU temperature: min 32.8, current 33.4, max 33.9
          Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, read errors 0, write errors 0, ifcount 69, reads 53397, timeouts 0
          Driver 1: standstill, read errors 0, write errors 0, ifcount 63, reads 53397, timeouts 0
          Driver 2: standstill, read errors 0, write errors 0, ifcount 71, reads 53397, timeouts 0
          Driver 3: standstill, read errors 0, write errors 0, ifcount 55, reads 53397, timeouts 0
          Driver 4: standstill, read errors 0, write errors 0, ifcount 36, reads 53397, timeouts 0
          Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 53398
          Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 53397
          Date/time: 2020-03-30 10:26:43
          Slowest loop: 7.74ms; fastest: 0.05ms
          Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
          === DDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Bed heaters = 0, chamberHeaters = -1 -1
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          lcd is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 22.11ms; fastest: 0.04ms
          HTTP sessions: 1 of 8
          Interface state 5, link 100Mbps full duplex
          • PaulHew
            @massynrt said in Duet Maestro 2 stops mid print:
            Thanks.
            I spotted this - Last reset 00:52:32 ago, cause: software, but yes, immediately after a fail would be better.
            • massynrt
              m122
              Used output buffers: 12 of 24 (15 max)
              Static ram: 19804
              Dynamic ram: 87356 of which 0 recycled
              Exception stack ram used: 300
              Never used ram: 23612
              Tasks: NETWORK(ready,812) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
              Owned mutexes:
              Last reset 00:01:24 ago, cause: reset button
              Error status: 0
              MCU temperature: min 37.3, current 37.4, max 37.7
              Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, read errors 0, write errors 0, ifcount 84, reads 24, timeouts 0
              Driver 1: standstill, read errors 0, write errors 0, ifcount 78, reads 24, timeouts 0
              Driver 2: standstill, read errors 0, write errors 0, ifcount 86, reads 24, timeouts 0
              Driver 3: standstill, read errors 0, write errors 0, ifcount 64, reads 24, timeouts 0
              Driver 4: standstill, read errors 0, write errors 0, ifcount 43, reads 24, timeouts 0
              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 23
              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 24
              Slowest loop: 1.06ms; fastest: 0.06ms
              === DDARing ===
              Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              Segments left: 0
              === Network ===
              Slowest loop: 3.46ms; fastest: 0.05ms
              HTTP sessions: 2 of 8
                Thanks for your report. Unfortunately it's not clear to me what caused the reset. It looks as though the tick interrupt did the reset because the heater management task hadn't indicated it was active for the previous 20 seconds, but it's difficult to be sure. If it happens again, please post another M122 report.
                massynrt 3 Replies Last reply Reply Quote 0
                • massynrt
                  massynrt @dc42 last edited by
                  @dc42 Thank you for the assistance. How can I know for sure. I tried doing a event log, but that did not complete. As if if did not write once the reset happened. What else can I try?
                    Is the Duet connected by USB to a PC? If so then see the wiki page on USB ground loops.
                    massynrt 1 Reply Last reply Reply Quote 0
                    • massynrt
                      @dc42 No - Only Ethernet.
                      • massynrt
                        @dc42 m122
                        Used output buffers: 14 of 24 (15 max)
                        Static ram: 19804
                        Owned mutexes:
                        Last reset 00:01:35 ago, cause: reset button
                        Last software reset at 2020-03-30 11:00, reason: User, spinning module GCodes, available RAM 23612 bytes (slot 2)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04427000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                        Error status: 0
                        MCU temperature: min 37.3, current 37.6, max 37.6
                        Driver 0: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                        Driver 1: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                        Driver 2: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                        Driver 3: standstill, read errors 0, write errors 0, ifcount 15, reads 62, timeouts 0
                        Driver 4: standstill, read errors 0, write errors 0, ifcount 13, reads 62, timeouts 0
                        Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 62
                        Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 62
                        Date/time: 2020-03-30 16:40:13
                        Slowest loop: 0.86ms; fastest: 0.06ms
                        === DDARing ===
                        Segments left: 0
                        === Network ===
                        Slowest loop: 3.40ms; fastest: 0.05ms
                        Error: Could not flush remaining data while finishing upload
                        Error: Uploaded file size is different (0 vs. expected 1112 bytes)
                        Error: Uploaded file size is different (0 vs. expeError: Could not flush remaining data while finishing upload
                        • massynrt
                          I see the last reset was done by a reset button- What does that mean?
                          • massynrt
                            And.. The diag light stays on. Using a BL Touch
                            • massynrt
                              @dc42 Tasks: NETWORK(ready,900) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:00:55 ago, cause: software
                              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 23804 bytes (slot 0)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                              • massynrt
                                Lets try again - I'm posting 2 M122 Diagnostic files.
                                The first one, was done a few seconds before the machine stopped, the 2nd one right after.. Lets hope you can make something from this..
                                ------------------------------------------FIRST------------------------------------------------------
                                01/04/2020, 09:20:50: M122: === Diagnostics ===
                                RepRapFirmware for Duet 2 Maestro version 3.01-RC5 running on Duet Maestro 1.0
                                Used output buffers: 1 of 24 (17 max)
                                Static ram: 22012
                                Dynamic ram: 88460 of which 20 recycled
                                Exception stack ram used: 368
                                Never used ram: 20212
                                Tasks: NETWORK(ready,976) HEAT(blocked,1328) MAIN(running,2020) IDLE(ready,84)
                                Owned mutexes:
                                Last reset 00:11:01 ago, cause: power up
                                Last software reset at 2020-04-01 07:25, reason: User, spinning module GCodes, available RAM 20632 bytes (slot 1)
                                Error status: 0
                                Free file entries: 9
                                MCU temperature: min 37.0, current 37.6, max 37.8
                                Supply voltage: min 23.9, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: ok, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                                Driver 1: ok, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                                Driver 2: standstill, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                                Driver 3: ok, read errors 0, write errors 0, ifcount 8, reads 974, timeouts 0
                                Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 974, timeouts 0
                                Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 973
                                Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 974
                                Date/time: 2020-04-01 09:20:49
                                Slowest loop: 3.29ms; fastest: 0.12ms
                                Hiccups: 0(0), FreeDm: 166, MinFreeDm: 158, MaxWait: 0ms
                                === MainDDARing ===
                                Scheduled moves: 3938, completed moves: 3917, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                === AuxDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                Bed heaters = 0 -1, chamberHeaters = -1 -1
                                Heater 0 is on, I-accum = 0.1
                                Heater 1 is on, I-accum = 0.3
                                Segments left: 1
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is doing "G1 X-4.045 Y5.452 E2.82853" in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                === Network ===
                                Slowest loop: 4.93ms; fastest: 0.04ms
                                Interface state active, link 100Mbps full duplex
                                ------------------------------------------2nd ------------------------------------------------------
                                01/04/2020, 09:21:21: M122: === Diagnostics ===
                                Used output buffers: 3 of 24 (6 max)
                                Static ram: 22012
                                Dynamic ram: 88260 of which 20 recycled
                                Never used ram: 20576
                                Tasks: NETWORK(ready,976) HEAT(blocked,1360) MAIN(running,2020) IDLE(ready,84)
                                Owned mutexes:
                                Last reset 00:00:28 ago, cause: reset button
                                Error status: 0
                                MCU temperature: min 37.1, current 37.4, max 37.9
                                Supply voltage: min 0.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                                Driver 1: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                                Driver 2: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                                Driver 3: standstill, read errors 0, write errors 1, ifcount 15, reads 1145, timeouts 0
                                Driver 4: standstill, read errors 0, write errors 1, ifcount 13, reads 1145, timeouts 0
                                Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1151
                                Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1151
                                Slowest loop: 3.25ms; fastest: 0.11ms
                                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                File is idle in state(s) 0
                                === Network ===
                                Slowest loop: 104.32ms; fastest: 0.02ms
                                • massynrt
                                  @dc42 I've uploaded 2 M122 files above. Please see if you can spot an issue. This is very frustrating.
                                  • A Former User
                                    A Former User last edited by
                                    Presumably you haven't pressed the reset button, maybe some pictures showing the mounting of the board and wires that are run near the reset swtich can help dc42 in his investigation. Understandably its a difficult issue to diagnose.
                                    • massynrt
                                      I know it is rough, but is a work in progress...
                                      • massynrt
                                        One more thing I've noticed, not sure if it is an issue... The prints look wrong before the reset... Infill looks wacked!
                                        • massynrt
                                          massynrt @Guest last edited by
                                          @bearer Nope. Not touching the reset button. I did read on the forum that some of them Maestro Reset buttons do get stuck. I did try to release it a bit with tweezers. I must say the reset button is VERY stiff. But not convinced that the button is the problem as yet.. That is why I'm asking.. If that error can only be generated by the button, then I guess it is time for shipping a new board, as this one is new.
                                          A Former User droftarts 2 Replies Last reply Reply Quote 0
                                          • A Former User
                                            A Former User @massynrt last edited by
                                            Afaik, it is, but lets defer to dc42 on that one; with the pictures I'm sure he'll have a clearer idea of what could possibly affect it but to the untrained eye it doesn't look like mechanical forces or electrical noise should be a likely culprit.
                                            • droftarts
                                              droftarts Moderator @massynrt last edited by
                                              @massynrt what PSU are you using? Is the wiring firmly connected to the Duet screw terminals? Also, when and where did you purchase the Duet? Warranty is 6 months, so if recent, that’s fine. You’ll need to follow the warranty procedure of the place you bought it from, which usually involves getting an okay from me, dc42 or Phaedrux here on the forum. But before that, let’s see what dc42 says about the M122 reports.
                                              • massynrt
                                                massynrt last edited by massynrt
                                                I use a Mean Well 450w 24v PSU. Yes the connectors are secure. The heat bed is 220v with a SSR. Thus no load on PSU..
                                                I bough it on the 02/03/2020 directly for your website. Order no: 7975.
                                                Problem is I was forced to buy it from you directly as the local distributor informed me that they won't stock Duet anymore. Thus to ship back, and pay shipment and import duties again will just make this very expensive.
                                                • droftarts
                                                  @massynrt okay, thanks. Let’s try and resolve the problem without shipping it back! Out of interest, who is your local distributor?
                                                  • massynrt
                                                    Da Vincy Lab.. I see they do have Maestros in stock according to there website. I think my query was for a Duet 3, and I just assumed it was for the Maestro also. And the fact that you had the Maestro on discount, which was not the case in South Africa.
                                                    • A Former User
                                                      If you guys come to the conclusion that the switch can be faulty ... if it were my board and the alternative was to pay shipping and taxes I'd be inclined to remove the switch; but lets not get ahead of ourselves.
