    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    22.4k
    • Danalundefined
      Danal
      https://github.com/DanalEstes/DuetLapse
      Time Lapse camera support for Duet based 3D printers. Works with firmware V2 or V3 (including stand alone V3 or Pi based V3).
      Designed to run on a Raspberry Pi, any Pi, not necessarily the one on the printer; may be adaptable to other platforms. Supports cameras via USB, Pi (ribbon cable), and Webcam. May support DSLR triggering in the future. Produces a video with H.264 encoding in an MP4 container. Does not, at this time, manage a library of videos, it simply drops the vid in home directory.
      Triggers images based on time, layer change, or pause. Works with existing pauses in G-Code, or can force pauses at other trigger events. Coming soon: Optionally moves head to a specified position before capturing paused images.
      See readme on github for the most current list of features, as they get implemented.
      zaptaundefined Baenwortundefined A Former User? A Former User? 4 Replies Last reply Reply Quote 10
      • gtj0undefined
        gtj0
        Should work with DSF since it uses your DuetWebAPI yeah?
        If so, I'll be testing later today!
        • Danalundefined
          Danal
          Yes, needs only network connectivity to V2 or V3 printer. A V3 can be stand-alone or Pi, doesn't matter. Also, to be clear, does NOT require running on the printer's Pi; of course, it can also be run there if you wish.
          It does have the "common sense" requirements regarding camera attach: USB and Ribbon cameras must be on the Pi where it runs, Webcam must be network reachable, etc.
          I know that people tend to not like command line... so it was written with as much "help you run it" as reasonably possible. For example, it won't just fail if a co-req module is missing; it will tell you what is missing and how to install it. I'll be adding more of that regarding cameras in the near future.
          • chas2706undefined
            chas2706
            Hi Danal
            I have a duet 3 with SBC and running this on the printers pi.
            The script executes ok, reports that it is connected to my printer and webcam but then exits with an error message as such:
            Attempting to connect to printer at 127.0.0.1
            Connected to a Duet V3 printer at http://127.0.0.1
            Options in force for this run:
            Camera = web
            Printer = 127.0.0.1
            Seconds = 20.0
            Detect = none
            Pause = no
            Movehead = 0.00 0.00
            Waiting for print to start on printer 127.0.0.1
            Traceback (most recent call last):
            File "./DuetLapse.py", line 228, in <module>
            status=printer.getStatus()
            AttributeError: 'DuetWebAPI' object has no attribute 'getStatus'
            pi@Duet3:~/DuetLapse $
            Any ideas?
            Great work though!
            • Danalundefined
              Danal
              Looks like you have an old copy of DuetWebAPI, the getStatus call was a recent add.
              Re-download it and put it in the same directory.
              Let me know...
              • Danalundefined
                Danal
                Also, just committed support for forcing pauses and moving the head during pauses.
                • chas2706undefined
                  chas2706
                  @Danal said in DuetLapse available for Alpha testing:
                  Clicking on the link to DuetWebAPI leads me to the one and only copy that I can see there.
                  Danalundefined 1 Reply Last reply Reply Quote 0
                  • Danalundefined
                    Danal @chas2706
                    @chas2706 said in DuetLapse available for Alpha testing:
                    AHA!! Something that I thought was linked together was not. This is why we alpha test! THANK YOU for exposing this.
                    And... there was a commit about one minute before this post, if you re-pull DuetWebAPI now, it will work.
                    https://github.com/DanalEstes/DuetWebAPI
                    • chas2706undefined
                      chas2706
                      Thank you so much. I will let you know how I get on.
                      • PaulHewundefined
                        PaulHew
                        Hi Danal
                        Eventually got it working, not very good with Linux!
                        When I ran the DuetLapse.py I got this message
                        rm: cannot remove '/tmp/DuetLapse': No such file or directory
                        Couple of things, where are the images stored?
                        Does it delete them after a print?
                        and where does it put the video?
                        I am going to install Samba so I can access the finished videos on a PC and would be nice if we could define where we wanted them.
                        Great work, Thank you.
                        Regards,
                        Paul
                        Edit - I also had this error message
                         Python Library Module 'numpy' is required.
                        Thought it was directed at me! 🙂
                        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                        • Danalundefined
                          Danal
                          Edit: That message should be suppressed, but is not. I will fix that.
                          It puts the images in /tmp/DuetLapse. They will stay until the next reboot, or next invocation of the script. They have sequence numbers, I don't remember the exact name format.
                          It puts the video in your home directory. The vid will be uniquely named with DDMMYYHHMM and you can certainly move it wherever, if you wish to keep them, etc.
                          • Danalundefined
                            Danal
                            Re: The "numpy" message, it also should have told you how to install it.
                            Obtain via 'sudo python3 -m pip install numpy'
                            Be sure you have the latest copy of DuetLapse.py, I am pushing four and five updates a day.
                            • zaptaundefined
                              zapta @Danal
                              Project's documentation looks very clear and professionalWould be interesting to see here sample videos.
                              The layer sync without a wired connection to the printer is a creative idea. Is it possible to achieve somehow the 'stationary print head' effect? https://youtu.be/S2cpHMoK8mw?t=13
                              Edit: a feature idea, include automatically music in the generated video.
                              Edit: another feature idea, add automatic time indication in the generator video. E.g. an analog clock at the corner, or digital time.
                              Danalundefined 3 Replies Last reply Reply Quote 0
                              • Danalundefined
                                Danal @zapta
                                @zapta said in DuetLapse available for Alpha testing:
                                This is already implemented. Add -movehead 10 15 to flags that either detect or force pauses. The numbers are X and Y respectively.
                                zaptaundefined 1 Reply Last reply Reply Quote 0
                                • Danalundefined
                                  Danal @zapta
                                  Not a bad idea. I will add that to the "to do" list.
                                  • Danalundefined
                                    Danal @zapta
                                    Probably going to let people do that in post-processing.
                                    • PaulHewundefined
                                      PaulHew
                                      @Danal
                                      It has stopped processing at image46 out of 200.
                                      I had this issue with the other Timelapse, and dropped the resolution of the images.
                                      Is there somewhere I can tweak the resolution?
                                      I am not a Python Guru, my skills lie elsewhere.
                                      Regards,
                                      Paul.
                                      • PaulHewundefined
                                        PaulHew
                                        @Danal
                                        Following on, I added the -q 25 to the DuetLapse.py for the Raspistill
                                                cmd = 'raspistill -o -q 25 '+fn
                                        I am getting some errors and it seems to be taking pictures whilst my bed leveling is happening
                                        End of print will be sensed, and frames will be converted into video.
                                        Capturing frame     0 at X25.00 Y25.00 Z117.31
                                        Invalid command line option (25)
                                        Capturing frame     1 at X25.00 Y25.00 Z121.31
                                        Capturing frame     2 at X-10.00 Y25.00 Z117.31
                                        Capturing frame     3 at X-10.00 Y25.00 Z121.31
                                        Capturing frame     4 at X-10.00 Y-8.00 Z117.31
                                        Capturing frame     5 at X150.00 Y150.00 Z122.31
                                        • zaptaundefined
                                          zapta @Danal
                                          Very nice! You are doing magic with network connections to the Duet.
                                          • zaptaundefined
                                            zapta @Danal
                                            While you do it you can add other visual indicators such as Z height, and filament used.
