    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    22.9k
    • Danalundefined
      Danal
      Looks like you have an old copy of DuetWebAPI, the getStatus call was a recent add.
      Re-download it and put it in the same directory.
      Let me know...
      • Danalundefined
        Danal
        Also, just committed support for forcing pauses and moving the head during pauses.
        • chas2706undefined
          chas2706
          @Danal said in DuetLapse available for Alpha testing:
          Clicking on the link to DuetWebAPI leads me to the one and only copy that I can see there.
          • Danalundefined
            Danal @chas2706
            @chas2706 said in DuetLapse available for Alpha testing:
            AHA!! Something that I thought was linked together was not. This is why we alpha test! THANK YOU for exposing this.
            And... there was a commit about one minute before this post, if you re-pull DuetWebAPI now, it will work.
            https://github.com/DanalEstes/DuetWebAPI
            • chas2706undefined
              chas2706
              Thank you so much. I will let you know how I get on.
              • PaulHewundefined
                PaulHew
                Hi Danal
                Eventually got it working, not very good with Linux!
                When I ran the DuetLapse.py I got this message
                rm: cannot remove '/tmp/DuetLapse': No such file or directory
                Couple of things, where are the images stored?
                Does it delete them after a print?
                and where does it put the video?
                I am going to install Samba so I can access the finished videos on a PC and would be nice if we could define where we wanted them.
                Great work, Thank you.
                Regards,
                Paul
                Edit - I also had this error message
                 Python Library Module 'numpy' is required.
                Thought it was directed at me! 🙂
                • Danalundefined
                  Danal
                  Edit: That message should be suppressed, but is not. I will fix that.
                  It puts the images in /tmp/DuetLapse. They will stay until the next reboot, or next invocation of the script. They have sequence numbers, I don't remember the exact name format.
                  It puts the video in your home directory. The vid will be uniquely named with DDMMYYHHMM and you can certainly move it wherever, if you wish to keep them, etc.
                  • Danalundefined
                    Danal
                    Re: The "numpy" message, it also should have told you how to install it.
                    Obtain via 'sudo python3 -m pip install numpy'
                    Be sure you have the latest copy of DuetLapse.py, I am pushing four and five updates a day.
                    • zaptaundefined
                      zapta @Danal
                      Project's documentation looks very clear and professionalWould be interesting to see here sample videos.
                      The layer sync without a wired connection to the printer is a creative idea. Is it possible to achieve somehow the 'stationary print head' effect? https://youtu.be/S2cpHMoK8mw?t=13
                      Edit: a feature idea, include automatically music in the generated video.
                      Edit: another feature idea, add automatic time indication in the generator video. E.g. an analog clock at the corner, or digital time.
                      Danalundefined 3 Replies Last reply Reply Quote 0
                      • Danalundefined
                        Danal @zapta
                        @zapta said in DuetLapse available for Alpha testing:
                        This is already implemented. Add -movehead 10 15 to flags that either detect or force pauses. The numbers are X and Y respectively.
                        • Danalundefined
                          Danal @zapta
                          Not a bad idea. I will add that to the "to do" list.
                          • Danalundefined
                            Danal @zapta
                            Probably going to let people do that in post-processing.
                            • PaulHewundefined
                              PaulHew
                              @Danal
                              It has stopped processing at image46 out of 200.
                              I had this issue with the other Timelapse, and dropped the resolution of the images.
                              Is there somewhere I can tweak the resolution?
                              I am not a Python Guru, my skills lie elsewhere.
                              Regards,
                              Paul.
                              • PaulHewundefined
                                PaulHew
                                @Danal
                                Following on, I added the -q 25 to the DuetLapse.py for the Raspistill
                                        cmd = 'raspistill -o -q 25 '+fn
                                I am getting some errors and it seems to be taking pictures whilst my bed leveling is happening
                                End of print will be sensed, and frames will be converted into video.
                                Capturing frame     0 at X25.00 Y25.00 Z117.31
                                Invalid command line option (25)
                                Capturing frame     1 at X25.00 Y25.00 Z121.31
                                Capturing frame     2 at X-10.00 Y25.00 Z117.31
                                Capturing frame     3 at X-10.00 Y25.00 Z121.31
                                Capturing frame     4 at X-10.00 Y-8.00 Z117.31
                                Capturing frame     5 at X150.00 Y150.00 Z122.31
                                • zaptaundefined
                                  zapta @Danal
                                  Very nice! You are doing magic with network connections to the Duet.
                                  • zaptaundefined
                                    zapta @Danal
                                    While you do it you can add other visual indicators such as Z height, and filament used.
                                    • Danalundefined
                                      Danal @PaulHew
                                      @PaulHew said in DuetLapse available for Alpha testing:
                                      @Danal
                                      Yes, those errors are from the flag you added. Don't add a flag between -o and the file name.
                                      Also, the raspistill default is 35, so there is not much point in overriding to 25, that's not all that different.
                                      If you have a bed leveling command in the print job, then yes, it will be capturing pictures, because the printer is running a job.
                                      If you are manually initiating the bed leveling, do not start the script until after you bed level, but before you start the print job.
                                      If there is some other situation, let me know.
                                      • Danalundefined
                                        Danal @PaulHew
                                        @Danal
                                        Regards,
                                        Paul.
                                        What camera? What command did you issue to start the script?
                                        PaulHewundefined 1 Reply Last reply Reply Quote 0
                                        • Danalundefined
                                          Danal @zapta
                                          Keep the ideas coming!
                                          • PaulHewundefined
                                            PaulHew @Danal
                                            Morning Danal
                                            I used ./DuetLapse.py -camera pi -duet 192.168.0.7
