    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    21.9k
    • Danalundefined
      Danal
      Edit: That message should be suppressed, but is not. I will fix that.
      It puts the images in /tmp/DuetLapse. They will stay until the next reboot, or next invocation of the script. They have sequence numbers, I don't remember the exact name format.
      It puts the video in your home directory. The vid will be uniquely named with DDMMYYHHMM and you can certainly move it wherever, if you wish to keep them, etc.
      • Danalundefined
        Danal
        Re: The "numpy" message, it also should have told you how to install it.
        Python Library Module 'numpy' is required.
        Obtain via 'sudo python3 -m pip install numpy'
        Be sure you have the latest copy of DuetLapse.py, I am pushing four and five updates a day.
        • zaptaundefined
          zapta @Danal
          Project's documentation looks very clear and professionalWould be interesting to see here sample videos.
          The layer sync without a wired connection to the printer is a creative idea. Is it possible to achieve somehow the 'stationary print head' effect? https://youtu.be/S2cpHMoK8mw?t=13
          Edit: a feature idea, include automatically music in the generated video.
          Edit: another feature idea, add automatic time indication in the generator video. E.g. an analog clock at the corner, or digital time.
          Danalundefined 3 Replies Last reply Reply Quote 0
          • Danalundefined
            Danal @zapta
            @zapta said in DuetLapse available for Alpha testing:
            This is already implemented. Add -movehead 10 15 to flags that either detect or force pauses. The numbers are X and Y respectively.
            • Danalundefined
              Danal @zapta
              Not a bad idea. I will add that to the "to do" list.
              • Danalundefined
                Danal @zapta
                Probably going to let people do that in post-processing.
                • PaulHewundefined
                  PaulHew
                  @Danal
                  It has stopped processing at image46 out of 200.
                  I had this issue with the other Timelapse, and dropped the resolution of the images.
                  Is there somewhere I can tweak the resolution?
                  I am not a Python Guru, my skills lie elsewhere.
                  Regards,
                  Paul.
                  • PaulHewundefined
                    PaulHew
                    @Danal
                    Following on, I added the -q 25 to the DuetLapse.py for the Raspistill
                            cmd = 'raspistill -o -q 25 '+fn
                    I am getting some errors and it seems to be taking pictures whilst my bed leveling is happening
                    End of print will be sensed, and frames will be converted into video.
                    Capturing frame     0 at X25.00 Y25.00 Z117.31
                    Invalid command line option (25)
                    Capturing frame     1 at X25.00 Y25.00 Z121.31
                    Capturing frame     2 at X-10.00 Y25.00 Z117.31
                    Capturing frame     3 at X-10.00 Y25.00 Z121.31
                    Capturing frame     4 at X-10.00 Y-8.00 Z117.31
                    Capturing frame     5 at X150.00 Y150.00 Z122.31
                    • zaptaundefined
                      zapta @Danal
                      @Danal said in DuetLapse available for Alpha testing:
                      Very nice! You are doing magic with network connections to the Duet.
                      • zaptaundefined
                        zapta @Danal
                        While you do it you can add other visual indicators such as Z height, and filament used.
                        • Danalundefined
                          Danal @PaulHew
                          @PaulHew said in DuetLapse available for Alpha testing:
                          @Danal
                          Yes, those errors are from the flag you added. Don't add a flag between -o and the file name.
                          Also, the raspistill default is 35, so there is not much point in overriding to 25, that's not all that different.
                          If you have a bed leveling command in the print job, then yes, it will be capturing pictures, because the printer is running a job.
                          If you are manually initiating the bed leveling, do not start the script until after you bed level, but before you start the print job.
                          If there is some other situation, let me know.
                          • Danalundefined
                            Danal @PaulHew
                            @Danal
                            Regards,
                            Paul.
                            What camera? What command did you issue to start the script?
                            PaulHewundefined 1 Reply Last reply Reply Quote 0
                            • Danalundefined
                              Danal @zapta
                              Keep the ideas coming!
                              • PaulHewundefined
                                PaulHew @Danal
                                Morning Danal
                                I used ./DuetLapse.py -camera pi -duet 192.168.0.7
                                • PaulHewundefined
                                  PaulHew
                                  Using -q 40 with the other TL program my filesizes are ...
                                  This is the line it used.
                                  raspistill -bm -q 40 -w 640 -h 480 -o $snapshot && curl -X POST http://localhost:8000/snapshot -d '{"name":"'$snapshot'"}'
                                  These are the sizes of the files using DuetLapse
                                  I was getting 'malloc' errors with the other program and it would fail when running the FFMPEG but when I dropped the filesize using the -q it worked. Do not know if the 640x480 had a part in it also.
                                  I can try if it helps you.
                                  As I previously mentioned, I am not a Linux / Python guru, just trying to help and fix things myself and also contribute.
                                  Regards,
                                  Paul
                                  • chas2706undefined
                                    chas2706
                                    @Danal
                                    Absolutely brilliant. It works a treat.
                                    Fantastic work!
                                    • Danalundefined
                                      Danal @PaulHew
                                      @PaulHew You can add the -q 25 (or whatever you wish to try), just put it before the -o. Or, more correctly, not between the -o and the filename.
                                      At this moment, none of my Pi cameras can reach to see a printer. Ribbon too short. I have some longer ribbon, and an Arducam, on the way. Amazon keeps moving the date (which I totally understand). I'll be able to fine tune this more when I receive that stuff.
                                      Meanwhile, keep the specifics coming! (And, you are a lot more of a Guru than you think)
                                      • gtj0undefined
                                        gtj0
                                        Just about to try it but noticed that it seems to be opening and closing the unix socket twice a second. Not usually an issue except I run the DCS with debug logging so it's kinda distracting. Any chance of just keeping the socket open or better yet, just getting the model updates as they happen?
                                        • gtj0undefined
                                          gtj0
                                          Getting
                                          # python3 ./DuetLapse.py -camera usb -duet 127.0.0.1 -seconds 5 -detect none
                                          Attempting to connect to printer at 127.0.0.1
                                          Connected to a Duet V3 printer at http://127.0.0.1
                                          # Options in force for this run: #
                                          # camera   = usb                 #
                                          # printer  = 127.0.0.1           #
                                          # seconds  = 5.0                 #
                                          # detect   = none                #
                                          # pause    = no                  #
                                          # movehead =   0.00   0.00       #
                                          Waiting for print to start on printer 127.0.0.1
                                          Print start sensed.
                                          Capturing frame     0 after 1586032541.73 seconds elapsed.
                                          Unable to find a compatible palette format.
                                          Capturing frame     1 after 5.01 seconds elapsed.
                                          Nothing written to /tmp/DuetLapse.
                                          Any ideas?
                                          • Danalundefined
                                            Danal
                                            Which USB camera?
