    Z motor blew
    457
    • Thinepaundefined
      Thinepa @bot
      @bot - the nylon washer is under the metal one- the metal washer isn’t actually touching the board, but I do see your point.
      botundefined 1 Reply Last reply Reply Quote 1
      • botundefined
        bot @Thinepa
        @Thinepa This is why I asked a question instead of just pointing fingers. If there is a nylon washer underneath I can't see how it would be an issue, so long as there is no contact between metal and other areas.
        *not actually a robot
        Thinepaundefined 1 Reply Last reply Reply Quote 0
        • Thinepaundefined
          Thinepa @A Former User
          @bearer - I was aiming to use E1, but would I still be able to use both z motors? I’m still learning (clearly), and am not sure if remapping the driver would allow me to use both z motor connections (the ones adjacent to the z motor driver) and the E1 driver, or if I could only use a single motor at E1.
          • Thinepaundefined
            Thinepa @bot
            @bot - I do appreciate that. I’ll remove the metal washers still - just in case.
            • A Former User?
              A Former User @Thinepa
              @Thinepa said in Z motor blew:
              the only magic there is for the z driver is that here is two headers that gives you convenient access to run two motors in series - you could replicate the same arrangement with wiring the motors in series before connecting to the single E1 header.
              • Thinepaundefined
                @bearer - that makes sense. Thanks!
                • A Former User?
                  A Former User
                  but maybe find out what caused the short first so you don't end up with E1 sending smoke signals
                  • Thinepaundefined
                    @bearer - true. I’m thinking I mis-wired my z motors. Breaking out the multimeter to confirm.
                    • Thinepaundefined
                      Thinepa
                      Well - after some multimeter deciphering, I've come to understand that my z motor coils run A1 A2 B1 B2, whereas my other stepper motors run A1 B1 A2 B2. After removing all metal washers, rewiring and setting up my Z motors in series on my E1 driver, all of my axes seem to be working.
                      My last problem is that I keep getting an error on my Driver 2 that it's over temp. I'm certain that that chip has blown, but is there a way to "turn off" that driver so I don't continue getting that error? I can turn off the motor with M58, but that doesn't seem to affect the driver error.
                      Any thoughts?
                        Yes you can disable the driver using M569. Specifically the P and R parameters.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
                        dc42undefined Thinepaundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @Phaedrux
                          @Phaedrux said in Z motor blew:
                          Specifically, the R-1 parameter.
                          • Thinepaundefined
                            Thinepa @Phaedrux
                            @Phaedrux - thank you very much. Worked perfectly. No more warnings. 😁
                            • Thinepaundefined
                              Thinepa @dc42
                              @dc42 - the wiki is super helpful. So much to learn. Thank you!
