    Homing issue when homey.g
    648
    • yngndrwundefined
      yngndrw
      I have an E3D tool changer (CoreXY) and it was initially using stall detection for the X / Y axis endstops.
      I've just upgraded to physical endstops but I'm now having an issue where running the homey.g file performs the actual homing moves, but then seems to hang the printer. It shows as "idle" and the axis shows as homed, but it ignores any input when trying to jog the file and running homey.g again hangs the printer. (State changes to "busy" and the homing moves do not occur)
      If I run each line from homey.g manually in the console, it works and I can cycle through these numerous times without issue.
      ; homey.g
      ; called to home the Y axis
      ; DC42 reduced stall sensitivity from 3 to 2
      ; DC42 replaced G1 S parameters by H
      ; DC42 removed redundant G4 and M574 commands
      ; AY updated to use physical endstops
      G91					; use relative positioning
      G1 H2 X0.5 Y-0.5 F10000	; energise motors to ensure they are not stalled
      M400				; make sure everything has stopped before we change the motor currents
      M913 X20 Y20		; drop motor currents to 20%
      ;M915 H200 X Y S3 R0 F0	; set X and Y to sensitivity 3, do nothing when stall, unfiltered
      G1 H2 Z3 F5000		; lift Z 3mm
      G1 H1 X3 F5000		; move X 3mm
      G1 H1 Y-400 F3000	; move to the front 400mm, stopping at the endstop
      G1 Y1 F2000			; move away from end
      G1 H1 Y-2 F500		; fine home, stopping at the endstop
      G1 Y2 F2000			; move away from end
      G1 H2 Z-3 F1200		; lower Z
      G90					; back to absolute positioning
      M400				; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100		; motor currents back to 100%
      What can I do to debug this?
      Duet Web Control 2.0.4
      Board: Duet WiFi 1.0 or 1.01 + DueX5
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
      Duet WiFi Server Version: 1.23
      Diagnostic output while it's in its "hung" state:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.0 or 1.01 + DueX5
      Board ID: 08D6M-91AST-L23S4-7JTD6-3S86L-TNXFK
      Used output buffers: 3 of 24 (14 max)
      Static ram: 30516
      Dynamic ram: 92924 of which 28 recycled
      Exception stack ram used: 536
      Never used ram: 7068
      Tasks: NETWORK(ready,688) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
      Owned mutexes:
      Last reset 00:02:38 ago, cause: software
      Last software reset at 2020-04-08 12:22, reason: User, spinning module GCodes, available RAM 7052 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 9
      MCU temperature: min 42.8, current 44.5, max 45.0
      Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/350
      Driver 1: standstill, SG min/max 0/1023
      Driver 2: standstill, SG min/max 0/225
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Driver 8: standstill, SG min/max not available
      Driver 9: standstill, SG min/max not available
      Date/time: 2020-04-08 12:25:09
      Cache data hit count 439170185
      Slowest loop: 4.00ms; fastest: 0.09ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 15498ms
      === MainDDARing ===
      Scheduled moves: 21, completed moves: 14, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 1
      Stack records: 1 allocated, 1 in use
      Movement lock held by http
      http is idle in state(s) 1 8, running macro
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 81.61ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address a0:20:a6:16:ee:92
      WiFi Vcc 3.35, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24360
      WiFi IP address 192.168.1.189
      WiFi signal strength -44dBm, reconnections 0, sleep mode modem
      • aidarundefined
        aidar
        @yngndrw said in Homing issue when homey.g:
        H1 means stop at endstop. I assume you have already homed x, so most likely you cant hit x endstop with move x3. Should that H1 be H2 instead?
        yngndrwundefined 1 Reply Last reply Reply Quote 0
        • yngndrwundefined
          yngndrw @aidar
          @aidar said in Homing issue when homey.g:
          Good catch, you're absolutely right. Sadly as H2 moved individual motors instead of axes I have to manually coordinate the CoreXY move but I've changed that now:
          G1 H2 X3 Y3 F5000	; move X 3mm (adjusted for CoreXY movement)
          Sadly it doesn't seem to have resolved my main issue though, it still seems to hang within the routine for some reason.
          • aidarundefined
            aidar
            For some reason you lowered you motors current to 20%. With endstop switches you dont have to do so, leave it to 100% and test then.
              Phaedrux Moderator @yngndrw
              If the axis is already homed you don't need an H at all.
              Agree with Aidar about the 20% current. That may be too low to reliably ensure movement.
        Duet Web Control 2.0.4        Board: Duet WiFi 1.0 or 1.01 + DueX5        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)        Duet WiFi Server Version: 1.23
                At this point if you are planning on sticking with RRF3 you should consider upgrading to 3.01 RC6 and DWC 2.1.1
                • yngndrwundefined
                  yngndrw @aidar
                  @Phaedrux said in Homing issue when homey.g:
                  This was left over from the old stall-detection setup, it is sufficient to move the axis as it was working like this previously and the M913 documentation does suggest that this can be used to protect your endstops so that's why I left it in. I've just tried it without (Also removed the related M400's) but sadly it didn't make a difference.
                  In this case the X axis may not have been homed (Even for a "home all", I home the Y axis before the X axis) as the X endstop switch is mounted on the fixed frame and touches the carriage. This move is to make sure that the carriage is out of the way so that I don't smash into the X endstop while homing the Y axis. This is another reason for the reduction in current while homing, this particular line may bump the carriage into the other side of the machine - Thinking about it I should probably back it off a tiny amount so that it can't scrape along the frame!
                  I had avoided 3.01 as it's an RC, but I've just realised that the version I'm on is a beta version anyway so I might as well upgrade. I'll have to work out the configuration changes I need to make in order to upgrade and then give it another go.
                  While looking over the configurations in relation to your suggestions I did just find the line which is causing the issue. Looking at the actual homing section for the Y axis: (I've changed some of the speeds here)
                  G1 Y1 F10000		; move away from end
                  G1 H1 Y-2 F300		; fine home, stopping at the endstop
                  I coarsely home the axis once at a high(er) speed, then step back and re-home at a lower speed. It appears to be hanging on the G1 H1 Y-2 F300 line for some reason. I've double checked that the 1mm back-off is enough to clear the endstop so it must be a bug in this version. I also tried setting it to absolute mode and back to relative mode between the two homing commands in case the coordinates were getting messed up but it doesn't seem to be the case.
                    Yes reducing the current is a good idea, but you must ensure that it's still set high enough to guarantee reliable movement. So you'll need to experiment. Try 30% or 40%.
                    It appears to be hanging on the G1 H1 Y-2 F300line for some reason.
                    try increasing the movement distance. 2mm should be enough based on the distance of the previous move, but setting it higher still just to be safe.
                    RC6 seems to have some issues of it's own at the moment and RC7 appears to be right around the corner, so maybe hold out for that.
                    • yngndrwundefined
                      yngndrw @Phaedrux
                      Okay I'll increase it a little to be safe.
                      I just tried 10mm but that didn't resolve it - It doesn't even try to move for that line.
                      I did notice in the release notes for RepRapFirmware 3.01-RC3:
                      Bug fixes:
                      * When homing switches were already triggered at the start of a homing move, sometimes the move queue got stuck, requiring a reboot
                      ... so this looks to be the issue that I'm seeing. I've still not finished reading through the release notes but it looks like I shouldn't have to change anything in order to upgrade. If RC6 is having issues, I might upgrade to RC5 for the time being.
                      • yngndrwundefined
                        yngndrw
                        RC5 is working fine so it looks like that bug was the issue.
                        Thank you all for your time and help.
