Help needed to remap fan1
  • I had a wire break on my hot end fan and the wires shorted and fan1 port is no longer working. Can I use fan2 for the hot end and how?
    Duet2 maestro and firmware v3
    In advance thank you
    S. Rolin
  • There should be a line in your config.g looking something like:
    you can change "fan1" to "fan2" and it will use that connector instead.
  • @bondus thank you I will try that.
  • @bondus That did not work, did i miss somthing?
    M950 F1 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
    G10 P0 R0 S0
  • Moderator
    @S-Rolin said in Help needed to remap fan1:
    Did you also move the fan port for the hotend fan to Fan2 port?
  • Yes i did, mabye it is blow to 😞
  • Moderator
    Have you checked the fan fuse?
    Does the fan work when connected to the always on fan port?
  • @Phaedrux yes it does, that what i've done to keep the printer running. where would i find the fan fuse?
    sorry for alle the questions.
    /Soren
  • Moderator
    Sorry, I see now that you're using a Duet Maestro, so no replaceable fan fuse.
    Since this is the hotend fan, you could still use the always on fan port. If fan port 1 and 2 are no longer working.
    Actually. the fan 2 block has it's own voltage select jumper, how is it set? Perhaps it's not set properly and that's why your Fan2 port isn't working as expected.
    https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
