    How to calculate feed rate?
    5384
    • monster
      monster last edited by
      How does one configures (and does it right) filament feed rate?
      Is there a life hack how to do it except trial and error?
      Heads of my printer are basically bolts connected to steppers. And threading of bolts does push filament into hotend.
      I guess from that I can (theoretically) know how many motor steps required to move 1mm of raw filament.
      I also should know diameter of nozzle (which I dont) but old BFB software was configured to 0.25 so I guess it is the one.
      Is there a calculator or formula to table to use in order to configure it right?
      P.S. At least at this point head motors are spinning way to slow for print to happen 😕
      • giostark
        giostark last edited by giostark
        Did you just want calibrate the extrusion?
        The nozzle diameter should not be relevant, you have a range where you can extrude. Just 0.25 is really small so you can't go much fast in extrusion. Keep this in mind. If you will go you will bite the filament, ecc ecc
        This guide should make your calibration easy :
        https://all3dp.com/2/extruder-calibration-6-easy-steps-2/
        monster 1 Reply Last reply Reply Quote 0
        • monster
          monster @giostark last edited by
          @giostark said in How to calculate feed rate?:
          Thank you. I'll study it now.
          I just realized that I'm not even sure I asked a right question. Perhaps I should have asked how to setup feed & feedrate.
          • deckingman
            deckingman @monster last edited by
            @monster Extruder calibration is one thing - that's how may steps are required to extrude 1mm of filament. The feed rate is speed. But as far as your configuration file is concerned, the maximum feedrate you set using M203 is largely irrelevant as long as it isn't too low. It needs to be set at or higher than the maximum speed that you think you might need for retraction moves and within the maximum speed that your extruder can handle. Any retraction move will take place at the speed defined either in the slicer or in M207 if you use firmware retraction. So if for example you set the maximum speed to 1800 (mm/min) using M203 then any extruder only move would be limited to 30mm/sec (1800/60) regardless of what retraction speed you set in the slicer or in M207. So if you think you'll need to retract at say 60mm/sec then make sure that M203 is set to at least 3600 (mm/min). For print moves which will be combined X,Y and E moves, the extruder will run much slower - typically single digit percentages of the carriage speed (e.g. 5mm/sec for a carriage speed of 100mm/sec, depending on nozzle size and layer height).
            • monster
              @deckingman Thank you a lot for this portion of knowledge. I'm slowly processing it 😂 I guess after re-reading it 10th time I'll get it right 😄
              @giostark amazing link. Thank you for that lifehack 🙂
                There's also this guide on extruder calibration and max volumetric feed rate that goes into a bit more depth
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                monster 2 Replies Last reply Reply Quote 1
                • Wally
                  Wally last edited by
                  Once you have your steps/mm feed rate working, you will want to know what your hot end is capable extruding by volume. Need to know so your X-Y moves/speeds set in your slicer program are not so fast that the hot end cannot extrude filament to match. CNC Kitchen has a good article w/ video here:
                  https://www.cnckitchen.com/blog/flow-rate-benchmarking-of-a-hotend
                  monster 1 Reply Last reply Reply Quote 1
                  • monster
                    monster @Phaedrux last edited by
                    @Phaedrux said in How to calculate feed rate?:
                    Awesome! That also answers on "Find Maximum Extrusion Rate" which i bumped on last night 👍
                    • monster
                      monster @Wally last edited by
                      @Wally said in How to calculate feed rate?:
                      Thanks! That for the moment is a step after next step. Good that now I know what to red! 👍
                      • monster
                        Great resource, and I used it.
                        Can't say it solved the riddle completely 😂
                        Max Print Speed = Volumetric Limit / ( Layer Height * Extrusion Width)
                        Oki - I tested/calculated my Volumetric Limit --> i got 9 --> it worked ideal with G1 E50 F80
                        Extrusion Width is more like fixed parameter defined by nozzle and btw Volumetric Limit also depends on it, isn't it?
                        Layer Height is something that you choose in slicer. And that suggests that this setting belongs to slicer. And so I go and actually find the setting.
                        According to formula I should have (if I wanna print with layer 0.2) -> 9/(0.25*0.2) = 9/0.5=180
                        At the moment in Cura i got Print speed = 60 but I get extreme underextrusion. Somehow extruder's stepper spins like a snail.
                        M569 P0 S0                                      ; physical drive 0 goes backward
                        M569 P1 S0                                      ; physical drive 1 goes backward
                        M569 P2 S1                                      ; physical drive 2 goes backward
                        M569 P3 S1                                      ; physical drive 3 goes forwards
                        M569 P4 S1                                      ; physical drive 4 goes forwards
                        M569 P5 S1                                      ; physical drive 5 goes forwards
                        M584 X0 Y1 Z2 E3:4:5                              			; set drive mapping
                        M350 X16 Y16 Z16 E16:16:16 I1                      			; configure microstepping with interpolation
                        M92 X87.40 Y87.40 Z1060.00 E6500.00:6500.00:6500.00       	; set steps per mm
                        M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00      		; set maximum instantaneous speed changes (mm/min
                        M204 P2000 T4000											; Set printing and travel accelerations
                        M203 X3000.00 Y3000.00 Z1000.00 E80.00:80.00:80.00 			; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z50.00 E500.00:500.00:500.00      		; set accelerations (mm/s^2)
                        M906 X300 Y600 Z500 E700:700:700 I30                		; set motor currents (mA) and motor idle factor in per cent
                        M84 S10                                         			; Set idle timeout
                        M207 S1.0 F2400
                        M563 P0 D2 H1 F0                                ; define tool 0
                        G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
                        G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
                        M563 P1 D1 H2 F0                                ; define tool 1
                        G10 P1 X45 Y0 Z0                                 ; set tool 1 axis offsets
                        G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                        M563 P2 D0 H3 F0                                ; define tool 2
                        G10 P2 X88 Y0 Z0                                 ; set tool 2 axis offsets
                        G10 P2 R0 S0                                    ; set initial tool 2 active and standby temperatures to 0C
                        Clearly my settings are wrong somewhere...
                          Phaedrux Moderator @monster last edited by
                          @monster said in How to calculate feed rate?:
                          Yes, that's right. It's typical to use a extrusion width equal to the nozzle with or slightly larger. It is set in the slicer.
                          Layer height is set in the slicer as well.
                          You must set your extruder max speed to much high than 80mm/min this would explain the snail speed. You should set this value to 8000 perhaps. If you had this set this low during your testing you should change it and then redo your extruder calibration.
                          monster 2 Replies Last reply Reply Quote 0
                          • monster
                            Ahaa! That is a bit counter intuitive I'd say - as with loaded filament motor won't go much higher! Thank you for that! I'll redo whole thing again now!
                              @monster The main reason to have it set higher is to allow for retractions which will probably be in the range of 25 to 80mm/s which is substantially faster than the 1.33mm/s you have set. The speed used during printing will depend on the slicer which will choose how fast it needs to go based on how fast you are printing and the extrusion width and layer height.
                              • monster
                                monster @Phaedrux last edited by monster
                                You were so right about it!
                                I did it again and now I got stability with G1 E100 F160 twice as fast!
                                That made Volumetric Limit --> 18.8
                                Max Print Speed --> 367
                                Though when it prints nothing changes! Extruder's stepper still a snail 😞
                                Also slicer doesn't seem very happy about speed:
                                But retruction speed sounds like ultrasonic 😂
                                • monster
                                  I constantly have this feeling that I'm missing some setting either in firmware on in slicer.
                                  Would it be possible to slice that kinda print which would require printer do only one move, lets say one 10cm line of extrusion? And then look in g code and see what slicer set there for extrusion? Would that be helpful?
                                    This is an over ambitious choice for print speed. The extruder may be able to provide enough plastic at that rate, but the rest of the machine likely will not.
                                    It's far more common to use a print speed around 60mm/s for most things due to reasons of model size and geometry, overhangs, bridging, fine detail, etc.
                                    Your M203 X3000 Y3000 also means the max speed is being limited by the firmware to only 50mm/s
                                    To get to 367mm/s you would need to raise the M203 value to 22000mm/min
                                    Note the difference between mm/min and mm/s. Multiply or divide by 60 to convert between them.
                                    You may find this post helpful at this point in your commissioning.
                                    https://forum.duet3d.com/topic/14250/tuning-jerk-accel-speed-settings/3?_=1586556079200
                                    • monster
                                      @Phaedrux Good points, thank you!!!
                                      I just printed this:
                                      G0 F3600 X10 Y100 Z0.3
                                      ;TYPE:SKIRT
                                      G1 F1500 E6.5
                                      G1 X110 E100 F100 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      G0 F3600 X10 Y105
                                      G11
                                      G1 X110 E100 F200 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      G0 F3600 X10 Y110
                                      G11
                                      G1 X110 E100 F400 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      G0 F3600 X10 Y115
                                      G11
                                      G1 X110 E100 F800 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      G0 F3600 X10 Y120
                                      G11
                                      G1 X110 E100 F1600 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      G0 F3600 X10 Y125
                                      G11
                                      G1 X110 E100 F3200 ; push 10mm of filament into the nozzle while moving to the X=30 position at the same time
                                      G10
                                      got that
                                      would you say that this confirms that on firmware side (incl config) all looks correct?
                                      Picture oriented that way that bottom stripe is first print line and top&broken one is last printed line.
                                        Printing an actual sliced object would be a better way. I can't tell much from that other than the last one might be good as a prime line....
                                        • monster
                                          Small step forward achieved 🙂
                                          I wasn't progressing no matter I do until I noticed that in firmware I did have a filament set to an extruder used to print sliced object. So I unloaded that filament in WebUI.
                                          Then prints began to reflect changes in Cura.
                                          Task was to print a small ring. I know ring isn't very decisive test object but I chosen it as printing ring makes less vibrations then square. Heads are heavy - vibrations significant.
                                          best result (ring at bottom) I could achieve by setting filament flow 200% and setting in printer settings that my extruded loaded with filament 2mm diameter. When actual diameter is 3mm.
                                          Btw retraction isn't happening at all - as it wants to spin motors way too fast. I hear only whistle instead of retraction.
                                          Does loading filament in WebUI needed for some purposes? Perhaps that is factor here and I should somehow define it right in filament config.g?
                                          And lastly. If in WebUI I do extrude with 1mm/s it extrudes kinda slowish but it does eat about of 5mm of filament. If I chose 5mm/s it goes very fast - on the edge of its max speed. Those 15, 30, 60 aren't usable for me. Is there a way to define what speeds I can select in WebUI?
                                            No, that's mainly for setting up specific settings for different kinds of filament. It will work without doing so.
                                            https://duet3d.dozuki.com/Wiki/Filaments
                                            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Filaments
                                            What settings are you using in your config.g now?
                                            What slicer are you using and what settings do you have set?
                                            • monster
                                              config.txt
                                              Now sure if this screenshot covers most relevant settings.
                                              And I just noticed that actual nozzle (as I believe) is 0.25 - I'll change it and try again!
                                              • monster
                                                monster @monster last edited by
                                                Been trying to print last 10 mins. Some kind of bug was always happening when I Pause&Cancel print. I almost always had to reboot the controller. Now even reboot doesn't work. I'll report this bug just that now still tying to get it to work, it is in state not accepting any commands 😞
                                                • monster
                                                  monster @monster last edited by monster
                                                  fixed nozzle to 0.25 everything else set to normal (filament 3mm, flow 100%) - catastrophic under extrusion.
                                                    Is it really 3mm filament?
                                                    Is it really a 0.25mm nozzle?
                                                    • monster
                                                      @Phaedrux
                                                      Filament is 3mm diameter, that one is easy to be sure.
                                                      For the nozzle story is different 😞 I wish to have any idea how to measure it reasonable way... Perhaps somehow comparing length of used filament to length of extruded thread could be the reasonable way still taking into account all possible errors that it has. I have calipers but measuring extruded filament isn't useful. When extruded to open air it a) shrinks b) my calipers will not show it with descent accuracy.
                                                      0.25mm came from settings in software that I found still available for this printer (printer is BFB Touch 3D). Two more factors reasonably adding up to it a) nozzles in this heads are very hard to change - so most likely it wasn't even designed to have different once b) line of filament that comes out of nozzle is visually very thing - so it is very believable that it is 0.25
                                                      P.S. I wonder is there a test print that would extrude fixed amount filament lets say 1mm above bed and move making some big (easy to measure) rectangular pattern. Then if the extruded line solid (eye accuracy) meaning it didn't brake (under exctrusion) not to tight (over extrusion) then by measuring extruded length and knowing consumed length (and diameter) of filament one could calculate nozzle size (+- accurate)
                                                      Sadly it is not very common not to know nozzle size among printer owners - such task probably never was set by anyone.
                                                      What I've found out last night is that Cura slicer somehow do not set nozzle diameter! Yes, statement 🙂 If I go to Cura printer settings and set there for extrude 0.25 then after I close settings and come back - it is back to 0.4
                                                      And yet if Cura "thinks" I got 0.4 then it should push more raw filament in extruder, isn't it? But reality is so different that if I print with that then under extrusion is that dramatic that after print I catch myself thinking "do I clean the bed or is it ok to leave it like that and print over..." 😂
                                                      Reasonable prints are require flow=N*100% and defining that my filament is lot less in diameter 1-2mm (value of N is factor here ofc)
                                                      Last night I've tried Prusa slicer. That one accepted my 0.25 noizzle, no problem. If I print same ring as on pictures earlier with right filament size and no other tweaks then it prints the ring bu still under extruded one. Not as bad as in Cura but still bad!
                                                      However what is "no no no" thing for Prisa was that printing this ring it made my printer (and whole table) to bounce around!!! Instead of slicing it in nice circle moves (ring 20mm outer diameter 16mm inner diameter 2mm high) it somehow forced it to do lot of small Z shapes and in combination with quick speed it was terrible! I'd rather continue with Cura...
