Delta printer X axis mirrored
Hi....
Until now I dont need, but now I need to Print a text in a piece and the de fault Print are mirrored...
For now, i have solved the issue, mirroring the piece in slicer.... But a better solutión?
A- Change configuration in slicer
B- Change something config.g in duet
C- Buy a Ultimaker S5 -
@peirof what exactly do you want? show us screenshot
I would guess you have your towers in the wrong order.
X should be on the left, Y on the right and Z at the back when looking at the machine from the front. -
On the board from the edge: Z, Y, X, E0, E1
solved, thanks....
Tower was in bad order....
