    How do I configure my default fan?
    981
    • maroondsundefined
      maroonds
      Hey! I'd like to have my Heater 2 port configured to be my 4010 Hotend cooling fan which turns on when my H1 is over 45C and my fan2 port to be my hotend cooling fan.
      However, I don't really understand how the parameters work in the g-code commands section.
      My duet maestro has the RRF2.05 firmware installed.
      Any help is greatly appreciated!
      • PaulHewundefined
        PaulHew
        @maroonds What slicer are you using?
        Regards,
        Paul
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • maroondsundefined
          maroonds
          Silplify3D and sometimes PrusaSlicer.
            dc42 administrators @maroonds
            @maroonds said in How do I configure my default fan?:
            With RRF 2.05 or 2.05.1 I think the following should work to configure fan 3 as a thermostatic hot end fan:
            M307 H2 A-1 C-1 D-1 ; disable heater 2
            M106 P3 A2 H1 T45 S1 ; Fan 3 is on heater 2 output, thermostatically controlled by heater 1
            maroondsundefined 2 Replies Last reply Reply Quote 1
            • maroondsundefined
              maroonds @dc42
              @dc42 The fan still doesn't kick on at 45 degrees. Btw. maybe it's not H2 I'm talking about this port: https://imgur.com/a/jzyW0WV
              • maroondsundefined
                maroonds @dc42
                @dc42 And could you please tell me how I can set my 5015 fan2 to be my default fan (part cooling fan)
                  droftarts administrators @maroonds
                  @maroonds First, test the fans on an 'always on' fan pin header, to check they are working.
                  H0 is 'HEATED BED', H1 is 'E0 HEATER' and H2 is the 'E1 HEATER'. So connect your fan (checking polarity) to the E1 HEATER screw terminals, or the pins behind it (+ve is on the left, GND on the right):
                  To test the fan, use the gcode @dc42 suggests, but change the M106 line to:
                  M106 P3 A2 H-1 S1
                  This should turn the fan on at 100%, ignoring the heater, and should show up in DWC to control it.
                  For the part cooling fan, do you want this to be Fan 0, but connected to Fan2? Try:
                  M106 P0 A22 H-1 S1
                  This should map fan0 to logical pin 22, which should be fan2. I think!
                  maroondsundefined 1 Reply Last reply Reply Quote 1
                  • maroondsundefined
                    maroonds @droftarts
                    @droftarts said in How do I configure my default fan?:
                    M106 P3 A2 H-1 S1
                    Thanks! My part cooling fan is now working, but my hotend cooling fan (connected to e1) is still not working...
                      @maroonds Did you test the hot end fan on the 'always on' fan pins? Did a fan control show up in DWC?
                      • maroondsundefined
                        maroonds @droftarts
                        @droftarts Fan control shows up but only for my part cooling fan. The fan turns on when I connect it to the always on pin but I'd like it to only turn on when the temperature is above 45c since it's kind of loud.
                          @maroonds Can you post how your fans are set up at the moment? You can also check by sending M106 P[fan number], though this doesn't tell you what pins it's using.
                          maroondsundefined 1 Reply Last reply Reply Quote 0
                          • maroondsundefined
                            maroonds @droftarts
                            M106 P[fan number]
                            here is my fan setup
                            droftartsundefined 2 Replies Last reply Reply Quote 0
                              @maroonds I meant in your config.g. Copy the text from config.g and paste it into your reply.
                              • maroondsundefined
                                maroonds @droftarts
                                @droftarts Oh my bad..
                                ; Configuration file for Duet Maestro (firmware version 2.03)
                                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 22 2020 01:05:56 GMT+0200 (Mitteleuropäische Sommerzeit)
                                M550 P"My Printer" ; set printer name
                                M552 P192.168.1.69 S1 ; enable network and set IP address
                                M553 P255.255.255.0 ; set netmask
                                M554 P192.168.1.254 ; set gateway
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S1 ; enable FTP
                                M586 P2 S0 ; disable Telnet
                                M552 S1 P192.168.8.101
                                M569 P0 S1 V0 ; physical drive 0 goes backwards X
                                M569 P1 S1 V0 ; physical drive 1 goes backwards Y
                                M569 P2 S0 ; physical drive 2 goes forwards Z
                                M569 P4 S1 ; physical drive 3 goes forwards E
                                M92 X80.00 Y80.00 Z400.00 E393.00 ; set steps per mm
                                M566 X420.00 Y420.00 Z12.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X24000.00 Y24000.00 Z720.00 E7200.00 ; set maximum speeds (mm/min)
                                M201 X2000.00 Y2000.00 Z500.00 E5000.00 ; set accelerations (mm/s^2)
                                M906 X850 Y850 Z600 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M204 P1000 T2000 ; Set printing and travel accelerations
                                M208 X-5 Y-5 Z-5 S1 ; set axis minima
                                M208 X235 Y230 Z260 S0 ; set axis maxima
                                M574 X1 Y1 S1 ; set active high endstops
                                M574 Z1 S2 ; set endstops controlled by probe
                                M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                G31 P500 X-33 Y1 Z2.5 ; set Z probe trigger value, offset and trigger height
                                M557 X10:210 Y10:210 S20 ; define mesh grid
                                M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
                                M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
                                M106 P0 A22 H-1 S1
                                M106 P3 A2 H-1 S1
                                M911 S23 R23.7 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                  @maroonds From your config.g:
                                  M106 P0 A22 H-1 S1
                                  M106 P3 A2 H-1 S1
                                  You haven't disabled Heater 1, as @dc42 suggested, with:
                                  Also, your tool is using F0, which is the part cooling fan.
                                  For the hot end fan, you don't need to specify it in the tool, as it's going to be set to thermostatically watch Heater 1 anyway. As you don't have any other fans, you may as well call this 'Fan1' or P1. So, change your config.g to:
                                  M106 P0 A22 H-1 S0
                                  M106 P1 A2 H1 T45
                                  M563 P0 D0 H1 ; define tool 0
                                  Fans that are linked to tools won't show up in DWC until the tool is active. Fans that are thermostatic won't show up at all. Fan visibility can be turned on and off in the 'Current Job > Status' page; click on 'change visibility' in Fans section.
                                  Is there any reason you're not using the other PWM fan pins?
                                  • maroondsundefined
                                    maroonds
                                    I had to change my pwm ports because I shorted the ones I was previously using.
                                    Btw. I tried it with your adjustments but my hotend fan is still not turning on when my heater reaches 50 degrees.
                                      @maroonds You made the changes to config.g, saved it, then reset the Duet? Run M98 P"config.g" and see if it generates any errors.
                                      What happens if you send:
                                      M307 H2 A-1 C-1 D-1
                                      M106 P1 A2 H-1 S1
                                      • maroondsundefined
                                        maroonds @droftarts
                                        @droftarts It doesn't create any errors and after I pasted the other commands nothing happens and the fan still doesn't turn on at 50 C
                                          @maroonds Can you post a picture of your board showing wiring? How are you connecting the fan to E1 HEATER, on the pins or screw terminals? Have you checked polarity?
                                          The command from my previous post, M106 P1 A2 H-1 S1, should turn it on full speed straight away, to test. To be thermostatic controlled, needs to be M106 P1 A2 H1 T50. But it needs to be working with the first M106 command, before setting it to thermostatic control. See gcode dictionary to understand the settings: https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
                                          maroondsundefined 2 Replies Last reply Reply Quote 0
                                          • maroondsundefined
                                            maroonds @droftarts
                                            M106 P1 A2 H-1 S1
                                            Screw terminals. I checked the voltages with a multimeter and it has around 0.5V with this command sent: M106 P1 A2 H-1 S1
                                            And yes the polarity is right
