Quick question about boot order with an RPi and Duet 3
I meant that which output is used doesn't matter with respect to the behavior when the board is reset. There are indeed other considerations to make.
Have not tried this myself, but there are examples of people getting the Pi to boot in ~5 seconds with some modifications.
http://himeshp.blogspot.com/2018/08/fast-boot-with-raspberry-pi.html
Note that was with Pi3 a couple years ago now. Not sure how relevant it would be to Pi4.
The pi forums have many threads on trying to optimize boot time. https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=258091
Normal SD card boot times are all pretty close to 25 seconds on the pi4 from what I've seen. Moving to an SSD may improve that a bit but I don't think that's a natively supported option yet.
https://www.youtube.com/watch?v=gp6XW-fGVjo
If sticking with an SD card, try and choose one with high write speeds and high IOPs. A2 U3 class.
I just looked into the boot process again and I've found a way to prioritise DSF. This way, DCS will start within 10 seconds when the Pi is powered on.
On the subject or wiring the fans as being always on, looking at the wiring diagram https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/6mYpDS1EmhXHobw4.huge it looks like I could simply connect the fans to OUT3 (or 4 or 5) GND and V_OUTLC1.
@deckingman said in Quick question about boot order with an RPi and Duet 3:
I may have missed this before but why not use the always-on fan header right above out_0?
V_OUTLC1.
if you remove the jumper that pin has no voltage, use 12v on same header instead.
@gtj0 said in Quick question about boot order with an RPi and Duet 3:
methinks he has 24v Vin and 12v fans.
@bearer said in Quick question about boot order with an RPi and Duet 3:
V_OUTLC1.
???? There is no 12V on that header - but I'm not going to remove the jumper - I'll set it to 12V.
Correct.
never mind, i thought you meant to use the pin on the voltage selection header, but that doesn't make sense.
you're good to go as planned
You had me worried there - at my age, senile dementia is just around the corner so....
seems i'm the one ought be worried
