Print stuttering around curves, LaErrors
Thank you both for your replies! I tried a normal diff checker, but there was far too much different for me to compare. Using "gcodeanalyser.com" (amazing tool, way better than the "gcode.ws" that I used originally which didn't depict accelerations) I think I found my issue.
First image is using Cura 4.5 (no issues).
Second image is using Cura 4.6 (stuttering issues).
Same exact settings, same layer, but notice how Cura 4.6 speeds up and slows down many more times during the layer. I would assume that it would accelerate once for the layer start, and again for the small radius corner (as in 4.5) but 4.6 changes a lot more.
It's worth noting that the version of Cura that @Phaedrux kindly provided does not appear to have the issues that "stock" Cura 4.6 seems to have.
Please let me know if I'm mistaken with any of my assumptions.
@Charlie said in Print stuttering around curves, LaErrors:
Have not seen that one before. I'll have to compare the gcodes and see if I get the same.
Unfortunately my 30mb gcode file is choking the analyser and it eventually crashes the page. I'll see if I can find a smaller one that was sliced with that version.
@brisma said in Print stuttering around curves, LaErrors:
Why 1428 (that's useless) and not 1400 on extruder?
What's useless about 1428 instead of 1400? That's a 2% difference. Seems more than worthwhile to correctly define.
Did you guys report this over on the Cura Github?
@CCS86 On Duet2 Wifi/Ethernet, the current can only be set in increments of 100 mA, and will be rounded down always.
IE 1428 == 1400, and 1478 == 1400
On Maestro, the current can be set in increments of 50 mA, rounded down in the same fashion. I'm not sure of the Duet3.
@CCS86 said in Print stuttering around curves, LaErrors:
He means (however bluntly) is that you only have a 100ma resolution with the Duetwifi and 50ma on the Maestro
https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
No, but I think it's known because the custom build from a few days ago lists "upstream changes" and a fix for geometry simplification, which sounds applicable. I quickly poked around the github of the smartavionics build but not yet the main cura github.
Could be this one: https://github.com/Ultimaker/Cura/issues/7588
@bot said in Print stuttering around curves, LaErrors:
@Phaedrux said in Print stuttering around curves, LaErrors:
Doh, I was reading too fast and thought is was steps/mm. Sorry to derail!
4.6.1 is out, which might fix the issue.
@CCS86 Yes, Cura 4.6.1 does appear to fix the issue (at least it looks fixed in "GCode Analyzer"). Much appreciated!
