    PanelDue no longer connecting on Duet3/io0 with 3.01-RC11
    Beta Firmware
    1.7k
    • gtj0undefined
      gtj0 @Nuramori
      @Nuramori said in PanelDue no longer connecting on Duet3/io0 with 3.01-RC11:
      I'm always up to trying anything; out of pure curiosity, I am interested in what changed that would prevent both devices from sharing the data on io0.out, when it worked prior to RC11, without any hardware changes.
      I'm guessing there was a drive strength change or something. I can't get to the source code right now but I can check tomorrow if @dc42 hasn't answered by then.
      Nuramoriundefined 1 Reply Last reply Reply Quote 0
      • Nuramoriundefined
        Nuramori @gtj0
        Interesting. I wasn't aware that something like that was controllable through software. Thanks for the help @gtj0 .
        gtj0undefined 1 Reply Last reply Reply Quote 0
        • gtj0undefined
          gtj0 @Nuramori
          Yeah on most "microcontroller" platforms, including the ones on the Duets, Pis and other SBCs, many pins are general purpose and have their function (uart, GPIO, SPI, etc) and capabilities (input, output, both, drive strength, pull up/pull down, tristate, etc) controlled from software.
          • A Former User?
            A Former User
            couldn't spot any changes to low level functions, just some conditional logic around the higher level initilization.
            https://github.com/dc42/RepRapFirmware/commit/6f912e9ca47930d7b91d504c0e9c8be31251284a#diff-52cb419324e9c23a2e2c5a269e0e70fcR3581
            0 dc42 committed to dc42/RepRapFirmware
            Various changes for 3.01-RC11
            Tool change files are now run even if axes have not been homed
            PanelDue replies are now sent immediately instead of being saved for
            retrieval by M408
            Added aux raw mode
            On Duet 3, IO_0 is not configured in serial mode until M575 P1 is
            executed
            GCodeException class now stores a small string to allow more meaningful
            error messages
            • Nuramoriundefined
              Nuramori
              Could it be this?
              setPullup(APIN_Serial0_RXD, true);
              I didn’t see anywhere else where the pull-up resistor is used/set in the old code, could the setting the pull-up affect the signal enough that it “dies” enough in signal strength for two electrical connections to be too much for the paneldue circuitry?
              • A Former User?
                A Former User
                click the beginning of the line and choose "git blame" to see when it was changed. (if viewed on github, otherwise git cli works as well)
                i'm guessing its part of the other repositories then
                • gtj0undefined
                  gtj0 @Nuramori
                  Could it be this?
                  Absolutely!
                  I just did a build without the pullup. See this helps...
                  http://dueui.org/download/Duet3Firmware_MB6HC.bin
                  • gtj0undefined
                    gtj0 @A Former User
                    @bearer It was new in the last 2 commits.
                    • A Former User?
                      A Former User
                      (for CoreNG, ofc, my bad)
                      • Nuramoriundefined
                        Nuramori @gtj0
                        @gtj0 I downloaded the file, pushed it to the printer, and performed a "M997 S0"
                        Result was :
                        Error: Operation failed (Reason: ArgumentNullException in SimpleCode: Value cannot be null. (Parameter 'input'))
                        • A Former User?
                          A Former User
                          But without the pull up? Comment said it was removed pending a M575, so the fix would be to enable it upon finding a M575 P1 command?
                          • gtj0undefined
                            gtj0 @Nuramori
                            @Nuramori Eh? I just did it myself and it worked. Maybe try to download again?
                            @bearer Yeah I just removed it altogether to see if it helps. If it doesn't then the issue is elsewhere.
                            • Nuramoriundefined
                              Nuramori
                              unfortunately, my hopes were higher. No change. 😕
                              • gtj0undefined
                                gtj0 @Nuramori
                                @Nuramori Ah well. Don't happen to have an oscilloscope do you? 🙂
                                • Nuramoriundefined
                                  Nuramori @gtj0
                                  @gtj0 I in fact do! It also does fun things like I2C. Siglent DCS 1202X-E
                                  • gtj0undefined
                                    gtj0 @Nuramori
                                    @Nuramori You could examine the level on that pin with and without the Arduino connected and see if it changes. You could also see if either the Arduino or the PanelDue is attempting to pull it up or down itself.
                                    • A Former User?
                                      A Former User
                                      Arduno won't affect the Duet's RX pin, he says that's not connected and works in any case?
                                      (i.e. Io0.out would be the TX pin)
                                      • Nuramoriundefined
                                        Nuramori @gtj0
                                        @gtj0 ok, I'll try that out. My herd of cats (family) are vying for my attention, so I'll poke at it in the morning. Thank you very much for the help!
                                        • Nuramoriundefined
                                          Nuramori @A Former User
                                          @bearer correct. the only wire that's linking the arduino to the duet is through the io.out pin. removing the connection allows the paneldue to receive packets, but attached or not, the paneldue issues commands TO the duet correctly. It (the paneldue) just doesn't update with information such as temps, positions, etc. It WILL do that once the arduino wire is disconnected. The same setup worked prior to RC11.
                                          • A Former User?
                                            A Former User @Nuramori
                                            then while the RX pull up is relevant, its not the cause. (unless maybe to disable it on the arduino)
