Short to ground alarm on the duet board
I had bought the tool changer, and i was installing it, went through the wiring and commissioning after i moved to try a test print as suggested, and it started and we were printing without any filament, just to test the motion, but then i got a alarm, and a some sparks on the board, the alarm was and is still not going is βshort to ground reported by 3 driver(s) over temperature shutdown reported by 3 Driver(s)β i am enclosing a pic of the same, i read online that some duet boards might have a fault and that they are replaced in warranty if this error happens, please help me out here on this, i tried removing all the steppers and it still gives this alarm, however i can home and pick up tools even the fans work, so please help me out here as what to do next, Thanking you
What is the exact error message? Your video doesn't show it.
My Apoligies, i sent the video link and not the picture link, below is the picture link
The good news is that it seems to be just the one driver, if you can remap to the others then user R-1 in M569 for driver 3 to silence the error.
If the motor on driver 3 never had worked I'd go over the wiring before trying it on another driver.
@dc42 also a heads up, i tried swapping the ports in the config.g as i had seen someone do on the duet3d forum but still the alarm persists, strangely i can home the machine, pick and drop tools, fans work too, and i can heat the tools and the bed, hopefully you have some solution to this π
@bearer where can i M569 this, in the config.g , just asking cause i am new to the duet, but have expeirence with other printer boards, also i tried to swap the ports from 3/4/5/6 to 7/4/5/6 that didnt get the alarm silent as well
@rajilpahuja said in Short to ground alarm on the duet board:
Yes, in config.g you will already have a line
M569 P3
and something else, addR-1
to that line to make the error go away (the driver will still be defective, but disabled)The motor on driver 3 worked fine on another driver after you swapped?
@bearer i didnt try that as yet but, i can try that and see , firstly i think want the alarm gone, cause those keep coming
make sure to check the wiring first so you don't risk damaging another driver if there was a problem with the wiring.
the errors will go away with adding R-1 to disable driver 3.
@bearer strangely the wiring came from E3D so i am perplexed how they would have messed it up
@bearer the line there says M569 P3 S0, so i need to add like this M569 P3 S0 -R1 ?
M569 P3 S0 -R1
M569 P3 S0 R-1
not the value for R is -1
@bearer ok will try this to see if error goes
they probably didn't but doesn't hurt to double check.
@bearer i think i should have but generally i never had issues with their stuff, so was relaxed on the checking part, but i guess need to check even if its from the most dependable companies
There are many reports here about people getting a 'short to ground' errors. Are these really shorts to ground or something else? If the latter, consider to change the error message?
Good news is that after adding the R-1 the alarm went away, now i must inspect all the wires to be very sure before plugging them in :), but hope i get a replacement
@zapta my guess is sometimes you can get faulty boards or drivers, electronics are after all not a 100% all the time, or it could be a wiring thing from the @E3D ppl, anyways i will have to investigate this, and hopefully i get a replacement
@rajilpahuja, something is probably wrong ;-), but considering that the steppers connectors don't even include a ground line, I wouldn't be surprised if most fo the 'short to ground' alarms we see on these forums mean something else.
@zapta said in Short to ground alarm on the duet board:
i think most of them are sort of accurate, its just the short to ground is internal to the failed driver; at least after the fact.
Unfortunately we do see a few infant mortality failures of the stepper driver chips, so it's probably a chip failure. But please check the wiring in case a couple of pins have been swapped over. There should be low resistance between pins 1 and 2 of the motor connector, low resistance between pins 3 and 4, but high resistance between 1 or 2 and 3 or 4.
Either way, assuming you bought both the Duet and the wiring loom from E3D, you are entitled to have your Duet replaced or repaired under warranty.
