<solved>M557 grid parameters not being followed.
I have just switched both my CR10S and my Ender 5 Plus over to independent steppers using E1. I have gotten both set up, and able to properly do the G32 command. Now I want to proceed to complete mesh bed compensation. It works perfectly on my CR10S. The M557 command is correctly applied
CR10S:
; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel 3 for BLTouch M558 P9 H1.5 F180 T24000 A10 S0.003 B1 R0.5 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-41.8 Y-24 Z0.73 ; set Z probe trigger value, offset and trigger height M557 X15:255 S60 Y10:280 S90 ; define mesh grid So when I got through the (almost) exact same setup on my Ender 5 PLus, the system (DWC) ignores the M557 parameters. It worked perfectly yesterday. But since I switched to separate z-steppers, it is not following the grid I have requested. Im requesting a starting grid point of X45 Y30. This accommodates both offsets from the corner origin.
But regardless of what is in my config.g, nor if I input that exact into into the drop down menu in DWC, nor if I send the exact line of gcode. The first point is X3.2 Y6.
Ender 5 PLus:
; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel 3 for BLTouch M558 P9 H1.5 F180 T24000 A10 S0.003 B1 R0.5 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X41.8 Y24 Z1.036 ; set Z probe trigger value, offset and trigger height M557 X45:350 S61 Y30:350 S64 ; define mesh grid Here is the total config G for my Ender 5 Plus:
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 17 2020 15:50:42 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Ender5 Plus - 3DimensionGames" ; set printer name M564 H0 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; Forwards M569 P1 S1 ; Forwards M569 P2 S0 ; Backwards M569 P3 S0 ; Backwards M569 P4 S0 ;backwards M584 X0 Y1 Z2:4 E3 U4 P3 ; set drive mapping M671 X-20:370 Y0:0 S0.5 ; leadscrew locations M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation M92 X80.70 Y80.60 Z801 U801 E399.84 ; set steps per mm M566 X900 Y900 Z30 U30 E3000 ; Jerk mm/min M203 X15000 Y15000 Z300 U300 E15000 ; Max Speeds (mm/min) M201 X6000 Y6000 Z30 U30 E8000 ; Max Accell (mm/s^2) M204 P800 T3000 ; Set printing and travel accelerations M906 X1000 Y1000 Z800 U800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X360 Y340 Z400 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 U1 E1 S2 ; set endstops controlled by probe ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel 3 for BLTouch M558 P9 H1.5 F180 T24000 A10 S0.003 B1 R0.5 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X41.8 Y24 Z1.036 ; set Z probe trigger value, offset and trigger height M557 X45:350 S61 Y30:350 S64 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 100C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S275 ; set temperature limit for heater 1 to 275C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not configured M501 ;M572 D0 S0.3; set K-factor BTW, I just updated to firmware 2.05.1 on both machines.
What am I missing?
@RyanP said in M557 grid parameters not being followed.:
G31 P500 X41.8 Y24
I don't know if this is related or not, but you have the same numbers but the signs are reversed. Is the probe actually placed inexactly the same distance just reversed?
It also seems telling that your first point is exactly the distance of your offset minus the X Y minima for the grid.
You say you're running G32, what do you have in the bed.g?
@Phaedrux said in M557 grid parameters not being followed.:
G31 P500 X41.8 Y24
I have the same offsets but reversed because I am using the same mount for both printers, and the BL Touch is in the exact position. Only difference is where the 0,0 origin is. On the CR10S it is on the front left, and the Ender 5 Plus it is on the back right. thats why they are reversed. The probes relation to the nozzle is literally flipped.
As for my bed.g
M561 ; clear any bed transform G29 S2 ; Clear bed height map ; Probe 2-points M401 ; Deploy probe - deployprobe.g G30 P0 X45 Y175 Z-9999 ; Center Left G30 P1 X345 Y175 Z-9999 S2 ; Center Right M402 ; Retract Probe - retractprobe.g -
That makes sense. I'll have to take a closer look tomorrow.
Dumb oversight. I have been using the same parameters for the probe offset, but completely ignored the fact that I just changed this printer from a Microswiss hotend to and E3D Volcano. Y offset was not correct.
