First layer after remachining delta parts
So I was getting a lot of assistance today from Jay_s_uk which helped a little. He gave me his bed calibration file to try and I updated the firmware to the 3.1.1 zip whole package.
None of it really helped my issues really but it was good info.Much thanks to him and everyone helping me out with this.
So, What I do is run Autocalibration G32 3 times than upload the results using M500. Then I run Mesh bed leveling G29 once and upload it G29 S1. Then I home the machine by hitting home all and then start the G-Code.
You're saying every time the machine is homed it clears the calibration? I didn't know this. Why does it clear the calibration? I suppose I will have to stop homing the machine before prints.
Should I just include the Bed.g code+M500 in my slicer code upon startup so It runs a calibration before every print?Should I mesh bed level every print or just G32?
What do ya'll use for bed calibration?
I have a smart effector en route but it will take a while to get that up and running.
Also, here is the quality prints i've been dealing with:
First layer is too close to the bed inconstantly and has gaps between shell and infill. Dimensional stability is AWFUL. Circles are not circles, straight lines wander around. Top layer is EXTREMELY underextruded.
I PID calibrated the nozzle 5 times and bed the same. Changed hot end to Mosquito, no change. Changed heater cartridge to mosquito, no change. Changed thermister to filamentone high temp cartridge. Received calibration data from them for the cartridge, no change. New fans, no change. Capricorn bowden, no change. Bondtech extruder assembly, changed steps to match, no change.
I changed extrusion multiplier up, down and all around, no change.
Hi gperman,
Can you delete the config_override raise the Rin your config to R231.750 then restart the board to make sure it takes effect
Then run G28, then heat the bed to 60c and hot end to 130c run G32 M665 M500 and check the Radius R of the new config_override see if it has changes please. -
Sorry run the G32 let it finish calibration then M665 from the console then M500 from the console then check the file.
@gperman said in First layer after remachining delta parts:
When you do that you're resetting the position of where the firmware thinks the bed based on the location of the endstops which are never 100% accurate. You need to establish where the bed is with G30 before starting the print and before doing the mesh.
Make sure you take G29 S1 out of your bed file and anywhere else you may have put it and delete your heightmap.cv file you will need to remake a new one when you get your probing sorted but that is probably hindering you at the moment so best get rid and remove all your start gcode from your slicer for now as its wrong we can sort that once your probing is accurate.
Also are you sure your rod length is exactly 440. not 440.### something ? -
Performed G32 -> M665 -> M500 three times. no homing. Which resulted in this:
Calibrated 9 factors using 16 points, (mean, deviation) before (-0.001, 0.016) after (-0.000, 0.013)
Auto calibration successful, deviation 0.013mmM665:
Diagonals 440.847:440.847:440.847, delta radius 212.607, homed height 432.734, bed radius 185.0, X 0.632°, Y -0.509°, Z 0.000°All at 130 deg nozzle and 60 deg bed.
No signs of G29 in any file. Deleted my heightmap.
Compensation in use: none
Still issues with dimensional stability and inconsistent nozzle height.
Thats good..now copy the height and the radius to your config one at a time click save then when asked if you want to
restart click No
We haven't done a height map yet which we are getting to.. -
@Carlo
yeah but better ! -
@Carlo
So once you have copied those 2 setting across..The most important being arm length.
We need to actually set the real height
We don't use 9 factor max 6 redo your bed file for 6 please -
So now you copied those to config.g
switch machine off and on
heat the nozzle to 130c and bed to 60c run calibrate
Now we want an accurate height but you need to get that so you are going to get a feeler gauge 0.1mm or piece of standard paper sure you have gauges though and credit goes to another awesome user NexxCat for helping me
lower the nozzle to just only just touching the gauge read the height in dashboard and either add or subtract the remaining from your height H in config.g so when we command the nozzle to 0.1 it just touches the gauge/paper
so what ever is left subtract -the 0.1mm this may take a couple of goes then set your trigger to height in G31 line of config.g to Z-0.1
Once it consistently on command goes to 0.1mm then do G30 S-1 then G1 Z5 repeat these 2 steps a few times to get your trigger once its a consistent height always @ 130c nozzle 60c bed once you get your trigger height add it to your config.g G31 line
After this you won't need a config_override unless you have some changes you want in there (I don't use override)then do G28 and calibrate once calibrate is done do without homing G29 and that gives you your hopefully correct height map
Then try a test print but 6 factor bed file only the other reset your arm length which we don't want!So the proccess going forward is once you switch machine on you home
heat your nozzle and bed make coffee do your calibration or G30 once thats done we don't re-home no need
you print and print if you re-home you need to run calibration before you print but only if you home everyone calibrates before printing it takes seconds and it will be part of your start gcode once we get you calibrated fully and I'll give you the start code and nozzle purge to copy into your Prusa slicer which is what I use -
This will take only around 10mins
Before you do those above delete the override file again
@Carlo
"lower the nozzle to just only just touching the gauge read the height in dashboard and either add or subtract the remaining from your height H in config.g so when we command the nozzle to 0.1 it just touches the gauge/paper
so what ever is left subtract -the 0.1mm this may take a couple of goes then set your trigger to height in G31 line of config.g to Z-0.1"This seems like you're using a smart effector. Ie: using the nozzle as the z probe. My smart effector has not arrived yet and will take some time to set up. Is this true?
Until then, I'll be using my switch probe with the trigger height of 16.8xx.
Can I just set up the trigger height as per described in this link?:
Calibrating_a_delta_printerI'll give this all a shot and see how it goes.
Also, do you have that Slicer start g-code or just cut and paste the contents of bed.g?
I am using a Smart Effector but you don't print with the switch you still need to be able to have your nozzle go to the correct height and your rod lengths need to be accurate so only use the 6 factor bed file
process I laid out above is from that very document but instead of G92 Z0 we want your height to go to the correct heights without resetting them this will be better over all
Yes you can use that guide but make sure you call the 0.1mm height and it does go to that height after homing and before G32 only now during your initial setup or if you swap nozzles or make change which may effect the height
so this only needs to be done once without making changes.Start Gcode includes a purge line for PLA adjust for other materials when you have a good ideal temp for them credit to the user NexxCat that helped me.
M82 ;absolute extrusion mode
G90
M83
G28
M104 S130 T0
M190 S60 T0
M109 S130 T0
;M106 P1 S0 ; turns hot end fan off un-comment when using with Smart Effector
;M291 P"Please ensure the nozzle is clean and click OK to continue." S2 ;un-comment when using Smart Effector
G32
;M106 P1 S1 ;Turns hot end fan back on un-comment when using with Smart Effector
M190 S60 T0
M109 S210 T0
G29 S1
; Draw arc to prime the nozzle between 6PM and 9PM on the bed edgeG1 X0 Y-175 Z0.25 F6000
G2 X-175 Y0 I0 J175 E30 F1500
G1 X-174.52
G3 X0 Y-174.52 I174.52 J0 E28 F1500
G1 Z1 E-0.5 F6000
Hope this helps
