    PINDA V2 thermistor configuration
    2.1k
    • Kolbiundefined
      Kolbi @Kolbi
      @Kolbi said in PINDA V2 thermistor configuration:
      Argo,
      Thanks much for that! Which board are you using with this config?
      Configuration file for Duet WiFi (firmware version 1.21)
      I saw different bin files for Duet3 and Maestro in the archive and it threw me off 🙂
      • Argoundefined
        Argo
        Sorry the comment section is a bit old in my config ^^
        RRF 3.11 and Duet WiFi
        Kolbiundefined 1 Reply Last reply Reply Quote 0
        • Kolbiundefined
          Kolbi @Argo
          @Argo No sorrys needed - you definitely got me way further along with my setup!
          • rkarondeundefined
            rkaronde @Argo
            @Argo Thanks for the info. I have PINDA v2 on order so this will help me once I get it installed.
            • Kolbiundefined
              Kolbi
              Argo,
              Looking at your config and postings I believe the attached graphic, WITH EXCEPTION OF FANS, depicts your wiring configuration - can you confirm please?
              I Drew this up before work, flubbed the fan locations - they have to go one row down and move to the 2nd and 3rd connector on the board, corresponding to FAN1(2nd) and FAN0(3rd). I'll correct this after work.
              Thanks much
              Argoundefined 1 Reply Last reply Reply Quote 0
              • Argoundefined
                Argo @Kolbi
                @Kolbi
                E0 endstop (filament sensor) is the 1st in the row not the second. 🙂
                • Kolbiundefined
                  Kolbi @Argo
                  @Argo Ah... When looking at the top-left endstop block, I read it as E1-E0-EX-EY-EZ?
                  So do you have the filament sensor plugged into the first endstop?
                  • Argoundefined
                    Argo @Kolbi
                    @Kolbi
                    Good you have a photo of it unplugged. Seeing through all the cables of my board I thought it’s the first one I connected.
                    So yes you are right it’s the second for E0.
                    • Kolbiundefined
                      Kolbi
                      The corrected wiring overview.
                      I'm working on a step-by-step guide, once done I'll post it.
                      V/R,
                      Kolbi
                      • Kolbiundefined
                        Kolbi
                        I installed the Duet wifi on my Prusa MK3s this past weekend, no issues at. She got the Zaribo 10mm full upgrade as well as Duet wifi so it's really a completely different machine.
                        For firmware settings, I used @Argo configurations - here
                        For wiring, I used a guide I created, and now verified - here
                        Cheers,
                        Kolbi
                        • Kolbiundefined
                          Kolbi
                          I did just switch the case fan from constant power to fan2 and followed the guide here: https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Cooling
                          M308 S2 Y"drivers" A"DRIVERS"  ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                          M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                          M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
                          M106 P2 H2:3 L0.15 X1 B0.3 T40:70 ; set fan 2 value
                          """"Creates sensors for the driver overtemp flag and the MCU temp reading using M308 as S2 and S3. Creates a fan port for Fan2 with M950. Then creates a fan command to link those sensors to fan2 with a temp range of 4code_text0-70 using M106.""""
                          *This made the case fan MUCH quieter and with that it only runs when its needed.
