GCode to view start print height?
  • perhaps im misunderstanding how this all goes together.
    i have now manually leveled my bed with a .20mm feeler gauge,
    the mesh seems to be working fine. only i cant get my first layer height dialed in.
    i have my g31 set to -0.20 and the micro stepping only seems to work so far. last couple of first layer test prints seem to only curl the PLA on the bottom of the nozzle, baby stepping it down doesn't seem to do anything. to the point i had it down to -9 and it still wasn't laying plastic down.
    with me doing the manual bed probing it was suggested to me to disable my ir probe in my bed.g, than manual probe, and re-enable.
    how do i set my first layer height with this board?
    ideally when i click print my nozzle should already be at my first layer height.
    is there a GCODE to view what the current zheight offset is?
    How are you homing Z? Please post homeall.g and homez.g.
  • 0:/sys/homeall.g
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:11 GMT-0600 (Mountain Daylight Time)
    G91 ; relative positioning
    G1 H1 X-110 Y-122 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-110 Y-122 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X0 Y0 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • @dc42 ; homez.g
    ; called to home the Z axis
    G1 X0 Y0 F6000 ; go to first probe point
  • @dc42 i take that back, it seems the mesh isnt even doing anything.. while its printing i cant see the either of the z axis adjusting
    absolute rubbish first layer.....
    im starting to think this swap was a mistake lol
  • Realized i didnt load the height map in the config.g
    added
    ;Bed
    G29 S1 P"heightmap.csv" ;Load manual probed heightmap
    config.g
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
    M550 P"JoehBo3D" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P3 S0 ; physical drive 3 goes forwards
    M569 P4 S1 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
    M671 X-160:160 Y0:0 S1 F1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M208 X-110:110 Y-122:122 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
    M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
    M92 X80 Y80 Z800 E790 ; set steps per mm
    M566 X1020 Y1020 Z24 E3000 ; set maximum instantaneous speed changes (mm / min)
    M203 X6000 Y6000 Z180 E8000 ; set maximum speeds (mm / min)
    M201 X6000 Y6000 Z100 E3000 ; set accelerations (mm / s ^ 2)
    M906 X935 Y935 Z935 E935 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-110 Y-122 Z0 S0 ; set axis minima
    M208 X110 Y122 Z203 S1 ; set axis maxima
    M574 X1 Y1 S1 ; set active high endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P600 x-2 Y-24 Z-0.135 ; set Z probe trigger value, offset and trigger height
    M557 X-108:108 Y-110:98 S100 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
    M143 H1 S300 ; set temperature limit for heater 1 to 300C
    M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ; Bed
    G29 S1 P"heightmap.csv" ; Loads manual probed height map
    M501 ;
  • also just realized i could just
    g29 s1
    and it will auto load the heightmap.csv...
    durrr
  • Hi,
    I think you are better off setting the Z=0 datum with G30 and then loading the height map with G29 S1 at the start of each print.
    This should take into account any changes in Z=0 as the bed heats.
  • getting there, still incredibly inconsistant though
  • @fcwilt im trying that right now, adjusted my g30 and added g29 s1 to the starting script on slicer
  • Hey,
    so when you set the Z=0 Datum, it makes sence, that you can't move the printhead down by -9 mm because of the axis limits.
    You may want to allow movement below 0 to accomplish that (But with Caution!!)
    M208 Z-3 S1 ; set minimum Z
    Best Regards
    Adrian
  • @joehsmash said in GCode to view start print height?:
    If I wasn't clear let me try again. The G30 should also be part of the starting script.
    I don't like having GCode in the slicer. I use M98 to execute GCode that I maintain on the Duet.
    I have M98 P"printbegin.g" and M98 P"printend.g" entered into the appropriate places in the slicer setup.
    printbegin.g has the G30 and the G29 S1 commands. It also has commands to wait for the hotend and bed to reach working temp, to prime the hotend with filament and others.
  • Ive decided to scrap all of this and i tore off my crappy ir probe and went back to my z switches. i cant get any repeatability out of it, one small nudge and everything is gone.
