Offset for Dual Y Endstop?
  • I have just been converting a CNC router to a duet 2 ethernet board.
    Everything seems to work fine.
    I am running two seperate steppers on Y with an endstop each.
    Using marlin I used to be able to square off the axis perfectly by setting up an offset for the endstops using the M666 command.
    Is there a way to do something similar on the duet 2?
    Firmware is 3.11
    You can do this in the homey.g file. After homing both motors together, use M584 to temporarily reassign Y to just one of the motors; then you can use a G1 Y move to move just that one a little. Then use M584 to assign Y to both motors again.
    If your homeall.g file homes Y without calling homey.g, then you will need to do the same in the Y homing sequence within homeall.g.
  • Great, thank you!
