    endstop trigger and bangbang questions
    1.8k
      Phaedrux Moderator @deltajegga
      @deltajegga said in endstop trigger and bangbang questions:
      also if i just pushed the switch by hand it wouldn't reset, only when i ran home y or home all
      Can you post your homing files? I have to admit, I'm having a hard time following along. Do you think you could summarize what exactly you have hooked up and how it's configured?
      • deltajeggaundefined
        deltajegga
        the X and Y endstops are NC switches wired to the duets endstops outer two pins. the emergency stop switch is a NO red push button, wired to the duexe2stop outer two pins. and the Z is a bltouch.
        im in the process of building the printer, so i just recently was able to test the homing. when i did, it homed X just fine, but when i homed Y, i would lose wifi connection. so i commented that estop code out as a random guess and it homed just fine. so i uncommented it again and just pressed the switch by hand in various ways as to trigger a rising or falling signal, but it did not reset. BUT when i ran "home all", it would make it to the homing Y part and reset, or if i just ran home Y.
        (i think it has to do with the way and timing of the quick move to endstop and the second pass that made it trigger, idk)
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:41 GMT-0700 (Pacific Daylight Time)
        G91                      ; relative positioning
        G1 H2 Z5 F6000           ; lift Z relative to current position
        G1 H1 X-1405 Y-805 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 H2 X5 Y5 F3000        ; go back a few mm
        G1 H1 X-1405 Y-805 F360  ; move slowly to X and Y axis endstops once more (second pass)
        G90                      ; absolute positioning
        G1 X50 Y50 F6000      ; go to first bed probe point and home Z
        G30                      ; home Z by probing the bed
        ;G91                     ; relative positioning
        ;G1 Z5 F100              ; lift Z relative to current position
        ;G90                     ; absolute positioning
        ; homex.g
        ; called to home the X axis
        G1 H1 X-1405 F6000 ; move quickly to X axis endstop and stop there (first pass)
        G1 H2 X5 F3000     ; go back a few mm
        G1 H1 X-1405 F360  ; move slowly to X axis endstop once more (second pass)
        G1 H2 Z-5 F6000    ; lower Z again
        ; homey.g
        ; called to home the Y axis
        G1 H1 Y-805 F4000 ; move quickly to Y axis endstop and stop there (first pass)
        G1 H2 Y5 F2000    ; go back a few mm
        G1 H1 Y-805 F360  ; move slowly to Y axis endstop once more (second pass)
        ; homez.g
        ; called to home the Z axis
        G1 X50 Y50 F6000 ; go to first probe point    used to be -13.3
        ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:40 GMT-0700 (Pacific Daylight Time)
        M550 P"1M"                                         ; set printer name
        M587 S"MTS" P"Judy1985"
        M569 P0 S0                              ; physical drive 0 goes backwards  X
        M569 P1 S1                              ; physical drive 1 goes forwards   RY
        M569 P2 S0                              ; physical drive 2 goes backwards  RZ
        M569 P3 S1                              ; physical drive 3 goes forwards   E
        M569 P5 S1                              ; physical drive 5 goes forwards   LY
        M569 P6 S0                              ; physical drive 6 goes backwards  LZ
        M584 X0 Y1:5 Z2:6 E3                                     ; set drive mapping
        M350 X16 Y16:16 Z16:16 E16 I1                            ; configure microstepping with interpolation
        M92 X114.29 Y114.29:114.29 Z400.00:400.00 E420.00        ; set steps per mm
        M566 X300.00 Y100:100 Z12:12 E120.00                     ; set maximum instantaneous speed changes (mm/min)
        M203 X2600.00 Y2600:2600 Z500:500 E1200.00               ; set maximum speeds (mm/min)
        M201 X100.00 Y50:50 Z20:20 E250.00                       ; set accelerations (mm/s^2)
        M906 X800 Y1100:1100 Z600:600 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                  ; Set idle timeout
        M208 X1400 Y800 Z900 S0                            ; set axis maxima
        M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
        M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
        M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
        M950 S0 C"duex.e2heat"                             ; create servo pin 0 for BLTouch
        M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X28.3 Y0 Z2.5                             ; set Z probe trigger value, offset and trigger height
        M557 X15:1350 Y50:750 S75                          ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
        M307 H0 A46.7 C538.0 D3.3 V24.0                    ; bed tuning parameters
        M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
        M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        T0                                                 ; select first tool
        ;M950 J1 C"!^duex.e2stop"
        ;M581 P1 T0 C0
          @deltajegga Can you include your current config.g?
            deltajegga
            its still the same as up top except the last lines are
            ;M581 P1 T0 C0
              Can you send M115 and verify that you're actually running 3.1.1?
              Also, can you send M98 Pconfig.g and report any errors?
              Also the content of M122 report please.
                If you are running 3.1.1 your M581 does require an S parameter.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
                  deltajegga
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-05-19b2
                  no errors on M98 other than my hotend sensor its not installed yet nor is the extruder motor.
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DLM-996RU-N8PS4-7J1F6-3SD6K-TUAZN
                  Used output buffers: 3 of 24 (11 max)
                  Static ram: 27980
                  Dynamic ram: 94324 of which 96 recycled
                  Exception stack ram used: 264
                  Never used ram: 8408
                  Tasks: NETWORK(ready,368) HEAT(blocked,848) DUEX(suspended,160) MAIN(running,1656) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:03:01 ago, cause: power up
                  Last software reset at 2020-06-20 13:22, reason: User, spinning module GCodes, available RAM 8252 bytes (slot 2)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 28.2, current 35.2, max 35.3
                  Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 5: standstill, SG min/max not available
                  Driver 6: standstill, SG min/max not available
                  Driver 7: standstill, SG min/max not available
                  Driver 8: standstill, SG min/max not available
                  Driver 9: standstill, SG min/max not available
                  Date/time: 2020-06-23 22:07:08
                  Cache data hit count 316873259
                  Slowest loop: 11.95ms; fastest: 0.12ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.8ms, write time 6.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 22.99ms; fastest: 0.00ms
                  Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address bc:dd:c2:2d:67:63
                    WiFi Vcc 3.42, reset reason Unknown
                    WiFi flash size 4194304, free heap 19864
                    WiFi IP address 192.168.1.161
                    WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                    Socket states: 0 4 0 0 0 0 0 0
                    === DueX ===
                    Read count 3, 0.99 reads/min
                    deltajegga
                    i tried
                    M581 P1 T0 C0 S1
                    still a no go. heres a picture, the red switch on top goes from white/green to two white wires down to the duex endstop. it has 3 wires for NC or NO, but i assume that doesn't really matter with the inversion capability. if feel like im missing something obvious.
                      It's hard to tell from the photo of the wiring bundle but have you followed the Duex wiring guide on connecting the grounds with a short piece of wire as shown here? https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                      Can you send echo sensors.gpIn[1].value and report the results?
                        deltajegga
                        yes its wired the same.
                        i get this back
                        Error: meta command: array index out of bounds
                          ;M581 P1 T0 C0
                          You've uncommented these lines right?
                          i get this back
                          means gpIn[1] doesn't exist, so either the M950 J1 command wasn't run or it didn't work
                          What do you get if you send just M950 J1 in the console?
                            deltajegga
                            hahaha, silly me. i guess it would help if i uncommented them.
                            ok i get a value of 0 back.
                            and if i send the m950 j1 i get back
                            Pin !duex.e2stop, active: false
                              M581 P1 T0 C0 S1
                              And with this? Does it work as expected?
                                deltajegga
                                no, it still resetes if i home
                                  I wonder if having the wiring bundled like that is causing the e stop switch pick up the signal from the endstop.
                                  Usually when I'm making my looms I always twist the wires to try and prevent cross talk. Can you physically separate the wiring for the e stop from the bundle and test again?
                                    deltajegga
                                    ok, interesting. so that solved the triggering when it shouldent problem. (i allways thought that only pwm and data lines cared about twisting.)
                                    but it still wont trigger when i press the button. just a reminder im using a normally open switch.
                                      Try changing it to normally closed. This should be configurable with the S0 S1 switch, but it's worth a shot.
                                      I twist or braid everything when using cramped conduits. Just as a matter of habit.
                                        deltajegga
                                        yeah still nothing.
                                          And you're sure the switch really works?
                                          Do you have a regular endstop microswitch you can connect in its place to test?
                                            deltajegga
                                            yeah i tested it with a multimeter at the plug on the duex.
