    DUET 3 - connectivity issues
    407
    • CJ.BRAVOundefined
      CJ.BRAVO
      Duet 3 with latest RRF.
      All of a sudden can't connect via ethernet nor YAT (usb).
      not sure whats up....
      help!
      ; Configuration file for Duet 0.6 (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 17 2020 18:15:06 GMT+0200 (Israel Standard Time)
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates
      M568 	; tool mix ratios on
      M302 P1 S0				 ; Allow cold extrusion minimum of 0
      M552 P192.168.200.15 S1                 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                       ; enable HTTP
      M586 P1 S0                       ; disable FTP
      M586 P2 S0                       ; disable Telnet
      M550         ; set printer name
      ;	Drives
      M569 P0 S0                       ; physical drive 0 goes forwards
      M569 P1 S0                       ; physical drive 1 goes forwards
      M569 P2 S1                       ; physical drive 2 goes forwards
      M569 P3 S0                       ; physical drive 3 goes forwards
      M569 P4 S0                       ; physical drive 4 goes forwards
      M569 P5 S1                       ; physical drive 5 goes forwards
      M569 P1.0 S1                     ; Drive E0  FEEDER
      M569 P1.1 S1 D2		       		 ; E1 printhead
      M569 P1.2 S1 D2                    ; E2 printhead
      M569 P2.0 S1 D2		       		 ; E3 printhead
      M569 P2.1 S1 D2		       		 ; E4 printhead
      M584 X5 Y1:2 Z3:4 U0 E1.0:1.1:1.2 			  ; Use E1 for Z axis
      M350 X16 Y16:16 Z16:16 U16 I1          ; Configure microstepping with interpolation
      M350 E16:16:16 I0						;
      M92 X100 Y80.00 Z462.5 U100 E115:215:215; set steps per mm
      M566 X500 Y500 Z50 U500 E500:800:800		; set maximum instantaneous speed changes (mm/min)
      M203 X20000 Y20000 Z2000 U20000 E10000:15000:15000	; set maximum speeds (mm/min)
      M201 X1000 Y10000 Z1000 U1000 E500:1000:1000; set accelerations (mm/s^2)
      M906 X2000 Y1800 Z2100 U2000 E2200:1200:1200 I30     	; set motor currents (mA) and motor idle factor in per cent
      M84 S0														; disable motor current reduction
      ;M84 S30                        							; Set idle timeout
      M574 X1 S1 P"io3.in"   ; X min active high endstop switch
      M574 Y1 S1 P"io1.in"   ; Y min active high endstop switch
      M574 U1 S1 P"io0.in"   ; U min active high endstop switch
      M208 X0 Y0 Z0:0 U0 S1                 ; set axis minima
      M208 X600 Y600 Z5000 U600 S0           ; set axis maxima
      M564 S1 H0						; Allow axis move without home and outside boundries
      M563  P0 D0:1 X3		;Define tool 0
      M567 P0 E1.5:3 									;MIXING RATIO tool 0
      M563 P1 D2 X0 					;Define tool 1
      M567 P1 E1:1										;MIXING RATIO tool 1
      G10 P1 X0 Y0 									; set offset for tool NSH
      G10 P0 U130 Y-139   								; set offset for tool fat
      M308 S0 P"spi.cs0" Y"rtdmax31865" A"Fidder temp"		;
      M308 S1 P"spi.cs1" Y"rtdmax31865" A"Bath temp"		;
      M308 S2 P"spi.cs2" Y"rtdmax31865" A"Auger temp"		;
      M558 P0 H5 F120 T6000                        ; Disable Z probe but set dive height, probe speed and travel speed
      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;m605 s1;
      M915 R0 ; stall detection
      thanks
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @CJ.BRAVO
        @CJ-BRAVO If you're able to (PanelDue) you could make a M122 and check whether voltage is ok or if you see other errors. Maybe there are also LED indicators on the board which signal an error (but I don't know them).
        • CJ.BRAVOundefined
          CJ.BRAVO
          M122 works
          RepRapFirmware for Duet 3 MB6HC version 3.01-RC12 running on Duet 3 MB6HC v0.6 or 1.0
          Board ID: 08DJM-956L2-G43S4-6J9DA-3SD6R-1V5AF
          Used output buffers: 1 of 40 (13 max)
          Static ram: 154588
          Dynamic ram: 161144 of which 20 recycled
          Exception stack ram used: 308
          Never used ram: 77156
          Tasks: ETHERNET(blocked,472) NETWORK(ready,276) HEAT(blocked,1412) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,208) MAIN(running,4676) IDLE(ready,80)<Owned mutexes:
          Last reset 00:05:42 ago, cause: reset button
          Last software reset time unknown, reason: Terminate called, spinning module GCodes, available RAM 77064 bytes (slot 3)
          Software reset code 0x4183 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04432000 BFAR 0x00000000 SP 0x20417478 Task MAIN
          Stack: 0000002b 0046afa7 00000000 2044d198 204177e0 0046b30f 00000000 0046ac95 204174c8 00450373 20417518
          Error status: 0
          MCU temperature: min 37.6, current 38.7, max 38.8
          Supply v[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
          Voltage is 30.
          I see this warning:
          • CJ.BRAVOundefined
            CJ.BRAVO
            ok sorry my bad. heres the full M122:
            m122
            Static ram: 154588
            Dynamic ram: 161224 of which 20 recycled
            Never used ram: 77076
            Tasks: ETHERNET(blocked,444) NETWORK(ready,276) HEAT(suspended,1412) CanReceiv(suspended,3428) CanSe
            nder(suspended,1484) CanClock(blocked,1432) TMC(blocked,208) MAIN(running,4532) IDLE(ready,80)
            Owned mutexes:
            Last reset 00:12:36 ago, cause: reset button
            064 bytes (slot 3)
            7478 Task MAIN
            17518
            Error status: 0
            MCU temperature: min 38.6, current 38.6, max 38.6
            Supply voltage: min 30.0, current 30.0, max 30.0, under voltage events: 0, over voltage events: 0, p
            ower good: yes
            12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
            Driver 0: standstill, reads 59616, writes 0 timeouts 0, SG min/max not available
            Driver 1: standstill, reads 59615, writes 0 timeouts 0, SG min/max not available
            Driver 2: standstill, reads 59616, writes 0 timeouts 0, SG min/max not available
            Driver 3: standstill, reads 59616, writes 0 timeouts 0, SG min/max not available
            Driver 4: standstill, reads 59616, writes 0 timeouts 0, SG min/max not available
            Driver 5: standstill, reads 59616, writes 0 timeouts 0, SG min/max not available
            Date/time: 2020-06-09 13:29:47
            Slowest loop: 0.87ms; fastest: 0.14ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 37.5MBytes/sec
            Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
            === MainDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is ready with "m122" in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon* is idle in state(s) 0 0, running macro
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 13.02ms; fastest: 0.03ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 1 of 8
            • Ethernet -
              State: active
              Error counts: 0 0 0 0 0
              Socket states: 2 2 2 2 2 0 0 0
              === CAN ===
              Messages sent 0, longest wait 0ms for type 0
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 756039ms ago
              RX/TX seq numbers: 0/1
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 0/0-0
              ok
            • CJ.BRAVOundefined
              CJ.BRAVO
              I tried updating RRF to 3.1 (which the true latest...).
              Because I can't connect to the duet 3 IP, I copied the firmware to the SD card then used M997 S0 with the terminal.
              but I get an error that it can't be found..
              I tried copying it to the SYS and other folders... no success
              jay_s_ukundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @CJ.BRAVO
                @CJ-BRAVO Have you tried a different SD card?
                • JoergS5undefined
                  JoergS5 @CJ.BRAVO
                  @CJ-BRAVO there was a bug with 30V, but it was fixed a few versions older than you use (https://forum.duet3d.com/topic/12157/duet-3-attempt-to-move-motors-when-vin-is-not-in-range-30v/7) I don't think it's the reason.
                  I see no errors in your M122.
                  How do you access Ethernet and USB (Windows, Linux, Mac?) and is it possible that the connection broke to to an (security?) update. If Duet 3 Ethernet is connected to your internet router, something like MAC address control could block the Duet. It would be visible in the router log file as access denied.
                  • CJ.BRAVOundefined
                    CJ.BRAVO
                    ok I did M21 to restart the sd card.. i have connection and managed to update the firmware.
                    • A Former User?
                      A Former User @CJ.BRAVO
                      @CJ-BRAVO if you didn't power off the board when removing and putting the sd card back you will always need M21 otherwise it sounds like gremlins in the system somewhere.
                      CJ.BRAVOundefined 1 Reply Last reply Reply Quote 0
                      • CJ.BRAVOundefined
                        CJ.BRAVO @A Former User
                        @bearer
                        I think it is gremlins and I think they had a late supper.
                        I got it to work I think. changed the SD card.
                        could it be just the cards' fault? is there procedure of formatting the card?
                        • A Former User?
                          @CJ-BRAVO said in DUET 3 - connectivity issues:
                          best option is using the sd formatter tool, and not using a quick format (takes a while, but will remap all bad sectors)
                          https://www.sdcard.org/downloads/formatter/
                          (gremlins should stick to being in films... sigh)
                          • CJ.BRAVOundefined
                            CJ.BRAVO
                            ok will give it a shot
                            thanks
