Solved Heated bed 2500 Watt + Duet3 6hc
@jens55
I used the code with my specifications.
M303 H0 P0.7 S65
Sry -
I don't understand why you insist on putting in PWM figures but if it makes you happy (and if it it doesn't give you a warning message) then so be it. Just be aware that it results in less power to your heat bed and causes a longer warmup time.
@jens55
25C - 60C
S.1 = 78sec
S.0.7 = 110 sec
Both it's ok in my mind
No warning. Thanks to. The tune was successful @Stephen6309 -
Sounds like you got it figured out.
@Phaedrux
Yes. There is nothing the forum can't help me!
Thanks to all!!!!
