    Question related to multiple Z endstop setup
    • Ray11
      Ray11 last edited by
      I have a z_max endstop that is using a switch and a z_min endstop with a probe. Normally, I would use the z_max endstop for homing the printer. I am wondering if I first use the z_max endstop and home the printer, and then use G30 with the probe, what is the current z_axis referencing with? Is it the probe or the previous z_max endstop?
      barbarossa.cologne 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt last edited by
        I have a Z "min" endstop switch that I use for homing which gets me to within 10 mm or so of Z = 0.
        At that point I use G92 to set the actual position.
        When printing or mesh probing I first use the Z probe for establishing the current Z = 0 position.
        • aidar
          aidar last edited by
          G30 is homing Z, just with probe, not endstop, so if you first home with Z max and then do G30, the last one, G30 result will be Z axis reference.
          • barbarossa.cologne
            barbarossa.cologne @Ray11 last edited by
            @Ray11 hey
            Would you share your gcode?
            I have 4 a axis and at the moment I'm not able to create my own g.code.
            I'm still learning.
            Thanks
            • KipK
              KipK last edited by
              Home to zMin with your probe directly. Z max homing is only usefull for resume after failed print in your case.
              • gorf26
                gorf26 last edited by
                Thanks i thing i got it figured out..
                Gary
                  Here is an example of using a z min probe and z max endstop together.
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s213
                  The probe fidns the bed and the z max can be used for power failure resume. There is even a macro that will help measure the exact distance of the zmax endstop and save it.
