    Extrusion Option greyed out
    968
    • hiro_onoundefined
      hiro_ono
      As it says really, I can extrude from the console but not with the buttons, even when temperature is high
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 07 2020 08:26:17 GMT+0100 (British Summer Time)
      M550 P"My Printer" ; set printer name
      M667 S1 ; select CoreXY mode
      M550 PMaestroTest ; Set machine name
      M552 P192.168.1.14 S1 ; Enable network and set IP address
      M553 P255.255.255.0 ; Set netmask
      M554 P192.168.1.254 ; Set gateway
      M586 P0 S1 ; Enable HTTP
      M569 P0 S0 ; physical drive 0 goes backwards
      ; Motor setup
      M350 X64 Y64 Z64 E64 I1 ; configure microstepping with interpolation
      M92 X320.00 Y320.00 Z1600.00 E1746 ; set steps per mm E was 1672/4
      M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Accel & Jerk
      M203 X6000 Y6000 Z600 E1200 ; Set maximum speeds (mm/min)
      M201 X800 Y800 Z250 E2500 ; Set accelerations (mm/s^2)
      M566 X800 Y800 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      ;M566 X300.00 Y300.00 Z12.00 E1000.00 ; set maximum instantaneous speed changes (mm/min)
      ;M203 X12000 Y12000 Z4000 E1400 ; set maximum speeds (mm/min)
      ;M201 X2000 Y2000 Z250 E250 ; set accelerations (mm/s^2)
      M208 X200 Y200 Z185 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:185 Y15:185 S20 ; define mesh grid
      M950 F1 C"fan1" Q500 ; create fan 0 on pin fan0 and set its frequency
      M106 P1 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
      • aidarundefined
        aidar
        Hi. First of all :
        M667: Select CoreXY or related mode
        This command is deprecated in RRF 2.03 and later. Use M669 instead.
        Secondly, what DWC version are you using?
        • hiro_onoundefined
          hiro_ono
          I'm not sure what you mean by DWC version?
          • deckingmanundefined
            deckingman @hiro_ono
            @hiro_ono How are you setting the temperature and what temperature are you setting to? You need to have the tool active (send T0) pr click on it. Then set he active temperature, Also, extrusion is disabled until the temperature reaches a default value. I think that is 160 deg C but I think it's configurable in DWC.
            Edit - DWC = Duet Web Control
            • hiro_onoundefined
              hiro_ono
              Duet Web Control 2.1.0
              Setting the temp in DWC, to 200.
              When i click on the tool it just says changing tool for ages, when thats done i still can't control the extruder.
              If I type T0 i get a green tick to say its worked but still cant extrude
              G1 E20 Works
                @hiro_ono When you click on the buttons in the web interface, what drive do you select and what feedrate?
                • hiro_onoundefined
                  hiro_ono
                  I just telect tool 0 i'm not selecting any specific drive i dont think? feed rate can be anything but doesn't make a difference, its on 5mm/s at the moment
                    jay_s_uk
                    IIRC, there was an issue with a DWC build of around your number.
                    I suggest updating to DWC 3.1.1 and RRF 3.1.1
                      deckingman
                      Something else too.
                      This line at the top of your config.g.............
                      But the configuration file is for firmware V2
                      What firmware are you actually on? (run M122 to find out).
                      • hiro_onoundefined
                        hiro_ono
                        @deckingman said in Extrusion Option greyed out:
                        M122
                        M122
                        RepRapFirmware for Duet 2 Maestro version 3.01-RC6 running on Duet Maestro 1.0
                        Board ID: 08D8M-9T8A2-MQNS0-7J9FL-3SJ6K-KNSQX
                        Used output buffers: 1 of 24 (21 max)
                        Static ram: 22012
                        Dynamic ram: 88620 of which 60 recycled
                        Exception stack ram used: 408
                        Never used ram: 19972
                        Tasks: NETWORK(ready,312) HEAT(blocked,1328) MAIN(running,1876) IDLE(ready,80)
                        Owned mutexes:
                        Last reset 01:40:48 ago, cause: software
                        Last software reset at 2020-06-18 12:56, reason: User, spinning module GCodes, available RAM 19972 bytes (slot 1)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                        Error status: 0
                        Free file entries: 10
                        SD card 0 detected, interface speed: 15.0MBytes/sec
                        SD card longest block write time: 2.3ms, max retries 0
                        MCU temperature: min 35.0, current 39.7, max 43.9
                        Supply voltage: min 0.0, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: standstill, read errors 0, write errors 1, ifcount 93, reads 45221, timeouts 0
                        Driver 1: standstill, read errors 0, write errors 1, ifcount 93, reads 45220, timeouts 1
                        Driver 2: standstill, read errors 0, write errors 1, ifcount 96, reads 45221, timeouts 0
                        Driver 3: standstill, read errors 0, write errors 1, ifcount 80, reads 45218, timeouts 5
                        Driver 4: standstill, read errors 0, write errors 1, ifcount 69, reads 45232, timeouts 0
                        Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 45238
                        Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 45238
                        Slowest loop: 35.21ms; fastest: 0.13ms
                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 121, MaxWait: 799239ms
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                        === AuxDDARing ===
                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                        Heater 0 is on, I-accum = 0.4
                        Heater 1 is on, I-accum = 0.6
                        Segments left: 0
                        Movement lock held by null
                        HTTP is ready with "M122 " in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 140.79ms; fastest: 0.02ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        Interface state active, link 100Mbps full duplex
                        • hiro_onoundefined
                          hiro_ono
                          Just updated everything to 3.1.1 and its working fine now 🙂
