CR-10S Pro - Looking for inspiration
Hi All,
I'm currently upgrading my CR-10S Pro V2 with a Duet 2 Ethernet and PanelDue 4.3. Thinking about the best solution to place the board so that SD card slot, reset switch and USB/Ethernet port are accessible from outside the case. Are there any CR-10S Pro users who can give me some inspiration?
For the PanelDue I think I'll go with this one and remix it to my needs: https://www.thingiverse.com/thing:4023963
Thanks and greetings from Berlin.
Martin
Hi Martin,
I have ported exactly the same printer to Duet 2 plus the expansion board some weeks ago.
I made a very simple holder for the boards and used some glue to glue it to the case. Similar to the same location where the stock board was.
I decided to store the boards "somewhere", I do not see any reason to reach the ports from the outsite. I have the WiFi board. The "reset" can be triggered with the main power switch.
I do not need to access the card from the outsite, all files can be reached via FTP or the web UI.
Cheers, Chriss
Hi Chris,
I think I will also go this way for now. Once everthing is running I'll look into "nicer" possibilities
BTW: Is anyone willing to provide me a config for a CR-10S Pro V2 to have a smooth start? I'm completely new to Duet.
Thanks, Martin
Just start with the web configurator. You can choose the ender 3 pro preset as a starting point and modify the build volume and whatever else.
@MartinNYHC Search for my name and cr10 config, I shared my config with a other forum member some weeks ago.
Endstops, motos, tools and fans are tested and working but I still have problems homing the printer.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 08:05:32 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CR-10S Pro V2" ; set printer name ; Network M552 S1 P0.0.0.0 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes backward M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z4000.00 E415.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X310 Y310 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; Z-Probe M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch G31 P500 X50 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height ; Heaters :: BED M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M307 H0 A245.4 C400.5 D1.3 S1.00 V24.1 B0 ; Chriss - Disable bang-bang, tuned with "M303 H0 S120" M140 H0 ; map heated bed to heater 0 ; Heaters :: Hotend M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S450 ; set temperature limit for heater 1 to 280C ; BLTouch - Heaters M307 H7 A-1 C-1 D-1 ; Chriss - Disable the 7th Heater to free up PWM channel 5 on the Duex board. ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Extrudor" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M501 G10 P0 Z10
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 20 2020 20:48:43 GMT+0200 (Central European Summer Time) G1 H1 X-10 Y-10 Z5 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-10 Y-10 F240 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X50 Y-20 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
When trying to home the printer it doesn't go to the endtop positions and Z is dropping into the bed
Thanks, Martin
The author of that config has a duex5 expantion board connected where the bl-touch is connected to:
You may need to change "M950"
This guide should help you:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_2_WiFi_Ethernet_without_a_Duex_2_or_Duex_5_expansion_board
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probeThe bltouch config was always looking a bit like witchcraft to me, I was more than happy that if finally worked after a very, very long journey.
Does the "home X/Y" work? Instead of the "home all"?
Does the endstop stages change when you trigger them manually (with your finger) and look at the web UI at "Settings / MachineSpecific"? The "Endstops", at the right, should show a state change when you trigger them manually.
0=X, 1=Y (If I recall correctly)Cheers, Chriss
@MartinNYHC in Firmware 3 you don't use M307 to clear a pin any more:
"You can no longer disable a heater using M307 A-1 C-1 D-1. To use the pin for something else, don't create a heater on that pin." from https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parameters so you can remove this line. -
Thanks for your input. It looks like I have a cabling problem. Need to investigate further.
Anyway, I think it's better to create anew post if required.
