    Duet3 Expansion Board 3HC - No CAN-Connection
    2.0k
    • CR3Dundefined
      CR3D
      The Firmware is the newest one:
      So for Case 1: Endstop triggerd before homing
      The engine turns very briefly in the direction away from the end stop (which is normal in my opinion)
      I get no Homing failed message
      Case 2: End stop not triggered before homing
      Z axis moves down
      Y-axis moves towards end stop
      Z axis moves up again
      Homing failed is displayed
      Y-axis continues to move and does not react!
      However, the screen shows that the state of the end stop is changing!
      config.g
      G90            ; send absolute coordinates...
      M82            ; and absolute extruder moves
      M550 P"I444-S" ; set printer name
      M552 S1        ; enable network
      M586 P0 S1     ; enable HTTP
      M586 P1 S0     ; disable FTP
      M586 P2 S0     ; disable Telnet
      M569 P0.0 S1   ; physical drive 0.0 goes forwards Z0
      M569 P0.1 S1   ; physical drive 0.1 goes forwards Z1
      M569 P0.2 S1   ; physical drive 0.2 goes forwards Z2
      M569 P0.3 S0   ; physical drive 0.3 goes backwards X1 (U)
      M569 P0.4 S0   ; physical drive 0.4 goes backwards E0
      M569 P0.5 S0   ; physical drive 0.5 goes backwards E1
      M569 P1.0 S0   ; physical drive 1.0 goes forwards X0
      M569 P1.1 S0   ; physical drive 1.0 goes backwards Y0
      M569 P1.2 S1   ; physical drive 1.0 goes forwards Y1
      M584 X1.0 Y1.1:1.2 U0.3 Z0.0:0.1:0.2 E0.4:0.5  ; set drive mapping
      M350 X16 Y16 U16 Z16 E16:16 I1  ; configure microstepping
      M92 X80.00 Y35.56 U80 Z800 E415:415 ;set steps per mm
      M566 X900 Y900 U900 Z12 E120:120   ;set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 U30000 Z300 E9000:9000      ;set maximum speeds (mm/min)
      M201 X1000 Y1000 U1000 Z20 E1000:1000            ;set accelerations (mm/s^2)
      M906 X1400 Y4200 U1200 Z1200 E1000:1000 I30  ;set motor currents (mA)
      M84 S30               ; Set idle timeout
      M208 X0 Y0 U0 Z0 S1   ; set axis minima
      M208 X500 Y450 U600 Z420 S0         ; set axis maxima
      M574 X1 S1 P"!1.io1.in" ; active-high endstop for low end on X via pin io0.in
      M574 U2 S1 P"!io0.in" ; active-high endstop for high end on U via pin 1.io1.in
      M574 Y2 S1 P"!1.io2.in" ; active-high endstop for high end on Y via pin 1.io2.in
      ; Z-Probe (Piezo)
      M558 P5 I1 C"!io3.in" R1.0 H5 F200 6000 ; Z probe type -> Piezo
      M557 X120:400 Y20:400 P04:04      ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092          ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                               ; map heated bed to heater 0
      M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out2" T2                                    ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out7"                                   ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H1 T50                                     ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8"                                  ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H2 T50                                     ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out4"                                   ; create fan 2 on pin out4 and set its frequency
      M106 P2 S1 H-1                                        ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"out5"                                  ; create fan 3 on pin out5 and set its frequency
      M106 P3 S1 H-1                                        ; set fan 3 value. Thermostatic control is turned off
      M563 P0 S"Links" D0 H1 F0:2  ; define tool 0
      G10 P0 X0 Y0 Z0 S0 R0        ; set tool 0 axis offsets
      G10 P0 R0 S0                 ; active and standby temperatures
      M563 P1 S"Rechts" D1 H2 X3 F1:3   ; define tool 1
      G10 P1 Y0 U0 Z0 S0 R0        ; set tool 1 axis offsets
      G10 P1 R0 S0                 ; active and standby temperatures
      ; Open Door Switch
      M581 T0 C"1.io3.in"  S0 C0		;trigger #2 (calls trigger2.g)
      ; LED
      M950 F3 C"out3" Q500  ; create fan 3 on pin out5 and set its frequency
      M106 P3 S1     ;set fan 3 value. Thermostatic control is turned off
      M501          ; load saved parameters from non-volatile memory
      T0            ; select first tool
      M572 D0 S0.03
      Home.y
      ; homey.g
      ; called to home the Y axis
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jun 19 2020 21:08:48 GMT+0200 (Mitteleuropäische Sommerzeit)
      G91              ; relative positioning
      G1 H2 Z5 F6000   ; lift Z relative to current position
      G1 H1 Y455 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y-5 F6000  ; go back a few mm
      G1 H1 Y455 F360  ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F6000  ; lower Z again
      G90              ; absolute positioning
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      • CR3Dundefined
        CR3D
        now i have the same phenomenon with the x axis. This axis is also controlled from the 3HC.
        Here it is a bit different ... the end stop reacts to the first hint, then reduces the speed and then it no longer reacts to the second trigger ...
        The other axes, which are controlled by the main board, work perfectly ...
        I really have no idea what is the problem here ...
        Homepage:
        www.cr-3d.de
        Facebook:
        Our Discord Server
        • deckingmanundefined
          deckingman @CR3D
          @CR3D Bit of a long shot here but try this. After the first G1 H1 (first pass), the axes will (should) be flagged as homed. So after that, you don't need to use the H2 parameter to move away from the end stop. Try taking out that H2 in those G1 Y-5 and X-5 moves( but you ned to leave it in for the Z moves).
          CR3Dundefined 1 Reply Last reply Reply Quote 0
          • CR3Dundefined
            CR3D @deckingman
            @deckingman
            I will test this too!
            @dc42 any ideas now?
            Homepage:
            www.cr-3d.de
            Facebook:
            Our Discord Server
            • CR3Dundefined
              CR3D @CR3D
              I think we can narrow down the error further ... it definitely has something to do with the 3HC ....
              I have now put X0 and Y on the mainboard and the homing of X0 and Y worked!
              Homepage:
              www.cr-3d.de
              Facebook:
              Our Discord Server
              JoergS5undefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @CR3D
                @CR3D what is strange that the Y had different rotation directions: S0 and S1 when on 1.1 and 1.2. In your original config (Jun 23rd) it was same direction. In your new mapping it's S1 both again. Do you have different stepper wirings? (or direction is wrong and your Z isn't working now, S0-S0-S1)
                • CR3Dundefined
                  CR3D @JoergS5
                  @JoergS5
                  No ... you are right...
                  but that's right ... I need different directions ... before that it was set wrong ... and here I also had a mistake ... but the directions have nothing to do with it ... I only had a few things were adjusted and at the beginning I had not installed any straps ...
                  the error only ever occurs when I control the axes from the 3HC, ...
                  Homepage:
                  www.cr-3d.de
                  Facebook:
                  Our Discord Server
                    I've made a note to try to reproduce this next week. It looks like a firmware bug to me.
                      deckingman @dc42
                      @dc42 said in Duet3 Expansion Board 3HC - No CAN-Connection:
                      No problems here with my CoreXYUVAB and assorted motors/end stops/expansion boards. The only thing that jumps out at me is that the OP has end stops on the high end whereas mine are all at the low end. So if there is a bug, it might be related to using end stops at the high end?? Just a thought...................
                        I was thinking the the original issue might be related to using more than one Y motor.
                          deckingman @dc42
                          I'm using 3off Y motors. But thinking about it, they get re-mapped to individual axes for homing so you could well be right.
