CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help
@Hélder-Rocha
The file looks good. Do you have a endstop configured for y in your config.g?
I have seen that in the past too, but I can not remember how I have solved it.
Do you see that the state of the switch changes when you trigger the switch with your finger? You can monitor the switch in the webui, the very last section on the navigation on the left. -
well... one of my problems is that i have my printer in my garage. Its not here near me. My answer is a question! If the x and z are working, possibly with the endstop configured, was that suppose to appen in the y axis? I really dont know if the Y endstop is configured! Dont know how to do that! And where to do that! Remember that i am the chosen noob ... take it easy on me!
@Hélder-Rocha
Im not close to my printer at the moment, too. And I forget always my fist name, my date of birth and 120% of the g-codes. I will give you a hint tomorrow if nobody else jumps in till than. It is a good idea to have the printer close to you during the setup period. You will need that during the next days, I was there a view weeks ago... -
Take a look at https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches there is a section "testing" that may be helpfully too.
The M574 is responsible for the endstops: https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
Allright Chriss...the problem with the y axis was that the connector was not well pluged on the board.
My next step is understanding the config for the bondetech... ill chek yours for now and see if it runs ok -
@Hélder-Rocha
The bondtech should be a nobrainer. Calibrate the e-steps and you should be Good to go.
I thing that the Bondtech is the only part at my printers which did not caused problems. -
Ok, but there must be a common base on the values i should use in the beginning right? In the exemples i see, by several cr-10 users with bondetech, there are different values on de config!
In the M569, the P3 is usualy refered to the extruder, right?
In the M92, for the ender 3, the value for the steps/mm is 420, should i uset?
M566, i beleabe is the jerk, is set 120.
M203 max speed is 1200.
M201 acceleration is 250
M906 mootr current is 800. -
The correct bondtech settings will depend upon what motor you are using. Are you using the stock creality extruder motor? Which port do you have it plugged into?
My reflex would say "yes" to all of your questions. I think that I have 482.5, so 420 is fine to start with. Follow the guide from the wiki, it explains very, very well how to do that. I, personally, would not play to much with the other settings, you can tune them when your stepper start to skip steps.
Yes, is the stock one from cr-10. dont realy know what do you mean with port, but it suppose to be connected to the E0 Stepper in the board
@Chriss Tks Chriss... ill try then
Hi good fellows,
allready have my printer working, but, at the momment i have 3 problems:
1-Its printing too slow
2-At the end of the printing, the extruder stays on top of the printed object.
3- The fan for the noozle does not start after the first layer.I already encreased the acelleration to 1000 on x and y but i dont see much difference.
I slice using Cura, and i was checking for possible problems with this slicer, and some guy said the slow problem have to do with a few lines in the beggining of the g-code, that he needs to erase! But he does not specify what lines are!!! Any place where i can check about cura settings to work with duet?
Tks -
@Hélder-Rocha it's in the start gcode section for the printer profile in Cura.
Google Cura start gcode if you can't find it.
When you're there you can also change the end gcode to move the print head up and away from the print.
Can you control the part cooling fan with the slider in dwc?
@Hélder-Rocha said in CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help:
Change your "stop.g" and tell the printer there what to do after the print.
My look like that:
M400 ; Finish move queue G91 ; Relative positioning G1 E-20 ; Retract filament 20mm M104 S0 ; Extruder heater off M140 S0 ; Bed heater off ;M106 S255 ; Fan at 100 to cool nozzle and bed M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed G1 Z15 ; raise nozzle 15mm from printed part G1 Y255 F3000 ; Drive the bed forward
If you want to use stop.g on the duet rather than the end gcode in cura, you need to add M0 in the end gcode in cura otherwise stop.g won't get called
Hi guys, fist of all, thankyou very much for the help. Im sorry but the last few days ive been working out and has been impossible for me to check this forum.
Chriss, the end of my g.code for a test cube on cura is like this:
;TIME_ELAPSED:2011.898237
G1 F2700 E-3
M140 S0
M82 ;absolute extrusion mode
M107
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionningG1 X0 Y300 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bedM84 X Y E ;Disable all steppers but Z
M83 ;relative extrusion mode
M104 S0
;End of Gcode
;SETTING_3 {"extruder_quality": ["[general]\nversion = 4\nname = Dynamic Quali
;SETTING_3 ty #2\ndefinition = creality_cr10\n\n[metadata]\nquality_type = a
;SETTING_3 daptive\nposition = 0\ntype = quality_changes\n\n[values]\ncoast
;SETTING_3 ing_enable = True\nmaterial_print_temperature = 220\nretraction_amo
;SETTING_3 unt = 3\nretraction_extrusion_window = 6\nspeed_print = 60\n\n"],
;SETTING_3 "global_quality": "[general]\nversion = 4\nname = Dynamic Quality
;SETTING_3 #2\ndefinition = creality_base\n\n[metadata]\nquality_type = adap
;SETTING_3 tive\ntype = quality_changes\n\n[values]\n\n"}However, the printer doesnt do nothing, and it stays stoped on top of the print.
As Jay_s_uk said, is it possible to for a conflit between this G.code from cura and a Stop.G on the duet? If it is, i cant find that stop.g in the duet config!Phaedrux, "Can you control the part cooling fan with the slider in dwc?" i cant even make the fan tests with the macros i have, but, for the momment, thats not a problem. The speed is what is troubelling me for now.
Sorry for my gramatics...
Best regards -
Phaedrux describes stop.g here:
https://forum.duet3d.com/topic/6760/stop-g/2I think that you do not have the "M0" in your endcode in your slicer. You can test your code fist by adding it the the endcode of your slicer for testing.
Cheers, Chriss
Tks Chriss.
How you know, when we find ourselfs a bit lost, we have to solve one problem at the time. For now, i wold like to find what is making my printer so slow. On the web panel i find the speed between 8 and 12 mm/sec. I have Cura 4.6.1 and g.code is reprap flavor. Do you know how can i make the printing faster? -
This is my inicial g.code on the machine settings. However, in my cnfig is like this:
M201 and M203 are complitly different!
