CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help
@Hélder-Rocha said in CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help:
sorry but a think i dont have that config-hoverride.g
That's fine.
Did you test if M401 and M402 deploy and retract the probe pin?
If that works, test the porbe as described here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
@Phaedrux i havent test it yet... ill try tomorrow....
Phaedrux, I finally got the time to dedicate myself a little to testing my duet. I've been taking advantage of my time off because of Covid to make some improvements at home, which has been taking up a lot of my time.
I did what you told me, the M401 and 402, and it worked perfectly. Following the tests indicated in the link you sent me, when I insert the G30, in the dinamic test, nothing happens and I receive the following message: "Error - G30 Z probe already triggered at start of probing move" .
When I turn on my duet, the bltouch performs its own tests, I don't know if that is what the error refers to.
Tks a lot for the help -
When I turn on my duet, the bltouch performs its own tests,When it does the self test does it successfully deploy and retract and then retract and stay red?
M401 and M402 work to deploy and retract?
If the self test is working and M401 and M402 work, but it gives an already triggered error when doing a G30 I think you should double check your white wire.
@Phaedrux , good morning.
Yes, when it des the self test, it successfully deploy and retract and then retract and stay red.
M401 and M402 work to deploy and retract perfectly.
Ill check the wiring.Tks
