    CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help
    1.7k
    • Hélder Rochaundefined
      Hélder Rocha @Phaedrux
      @Phaedrux , those lines you are talking about are those from the g.code in the object i want to print, or can i erase the complet start g.code in the printer settings in cura?
      Chrissundefined 1 Reply Last reply Reply Quote 0
      • Chrissundefined
        Chriss @Hélder Rocha
        @Hélder-Rocha
        Remove at least the M20X lines... They override .. Well as Phaedrux said....
          Hélder Rocha
          Well, in the next image i have 2 g.codes. one with the start gcode from cura and the other with out it.... will the second work?
          • Chrissundefined
            @Hélder-Rocha
            Looks Good to me. As long as you keep the M20x in the config.g. There must me at least one place where you set some limits which should match your hardware and other settings.
            Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
              Hélder Rocha @Chriss
              @Chriss i beleave is there! Looks good?
              Going now downstairs to the garage and try it
              M569 P0 S0 ; Drive 0 goes backwards
              M569 P1 S0 ; Drive 1 goes backwards
              M92 X80.00 Y80.00 Z408.00 E820.00 ; Set steps per mm Z400
              M566 X600.00 Y600.00 Z24.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
              M906 X750.00 Y1150.00 Z750.00 E1050.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S300 ; Set idle timeout
                Hélder Rocha
                YESSSSSSSSSSSSSSSSSS... speed is normal now. Tks a lot guys... are you ready for the next problem i have? eh eh
                Allright... my config for homeall with the bltouch. Is the original one, not replica. Is the smart bltouch 2020.
                But first one question: i heve seen in some toturials that we should make a cut with a knife, because of the 3.3 v power or something like that!!! Is it needed to be done on this bltouch?
                My config next:
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2 on Wed Dec 26 2018 13:31:24 GMT+0000 (Hora padrão da Europa Ocidental)
                G91 ; relative positioning
                M98 Pdeployprobe.g ; deploy mechanical Z probe
                G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G90 ; absolute positioning
                G1 X200 Y150 F6000 ; go to first bed probe point and home Z
                ;G91 ; relative positioning
                ;G1 S2 Z5 F100 ; lift Z relative to current position
                ;G90 ; absolute positioning
                M98 Pretractprobe.g ; retract mechanical Z probe
                Ok... at the momment, i have the bltouch installed, but i am doing the home return with endstops swich. But first i tried this config and what apenned is that the printer does the x and y, but doesnt come down to make the measures!
                Any sugestions?
                  No you don't have to cut any trace now.
                  Please post you config.g as text.
                    @Phaedrux Good morning, sorry at the time i went to bed. My config is like this:
                    M111 S0 ; Debugging off
                    G21 ; Work in millimetres
                    M555 P2 ; Set firmware compatibility to look like Marlin
                    M550 P"Cr 10 - S" ; Set machine name
                    M552 S1 ; Enable network
                    ;*** Access point is configured manually via M587
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M208 X300 Y300 Z400 S0 ; Set axis maxima
                    M574 X1 Y1 S1 ; Set active high endstops
                    M574 Z1 S2 ; Set endstops controlled by probe
                    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                    M558 P9 H5 F120 T6000 A5 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
                    G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
                    M557 X50:250 Y50:250 S50 ; Define mesh grid
                    M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                    M143 H1 S290 ; Set temperature limit for heater 1 to 290C
                    M106 P0 S0 I0 F30 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M563 P0 D0 H1 ; Define tool 0
                    ; Automatic power saving
                    M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                    M912 P0 S-1 ; calibrate MCU Temp
                    ; pressure advance
                    M572 D0 S0.3 ; pressure advance
                    M501 ; Load saved parameters from non-volatile memory
                      Phaedrux Moderator @Hélder Rocha
                      @Hélder-Rocha said in CR-10+Bondtech+Silicon Bed 450W+Microswiss...Help:
                      Remove those parts from your homing file. You don't need to control the pin manually. It should deploy automatically with G30.
                      Please test M401 and M402 to deploy and retract the probe, and post your retractprobe.g and deployprobe.g files.
                      Also check your config-override.g file and look for an M307 H3 command that could be over writing your M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                        @Phaedrux hello... tks a lot for your time and patience with my issues.
                        ; deployprobe.g
                        ; called to deploy a physical Z probe
                        M280 P3 S10 I1
                        ; retractprobe.g
                        ; called to retract a physical Z probe
                        ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
                        M280 P3 S90 I1
                        sorry but a think i dont have that config-hoverride.g
                          That's fine.
                          Did you test if M401 and M402 deploy and retract the probe pin?
                          If that works, test the porbe as described here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                            @Phaedrux i havent test it yet... ill try tomorrow....
                              Hélder Rocha
                              Phaedrux, I finally got the time to dedicate myself a little to testing my duet. I've been taking advantage of my time off because of Covid to make some improvements at home, which has been taking up a lot of my time.
                              I did what you told me, the M401 and 402, and it worked perfectly. Following the tests indicated in the link you sent me, when I insert the G30, in the dinamic test, nothing happens and I receive the following message: "Error - G30 Z probe already triggered at start of probing move" .
                              When I turn on my duet, the bltouch performs its own tests, I don't know if that is what the error refers to.
                              Tks a lot for the help
                                When it does the self test does it successfully deploy and retract and then retract and stay red?
                                M401 and M402 work to deploy and retract?
                                If the self test is working and M401 and M402 work, but it gives an already triggered error when doing a G30 I think you should double check your white wire.
                                  @Phaedrux , good morning.
                                  Yes, when it des the self test, it successfully deploy and retract and then retract and stay red.
                                  M401 and M402 work to deploy and retract perfectly.
                                  Ill check the wiring.
                                  Tks
