    What’s the best way to set up a continuous rotation for an axis?
    Firmware developers
    911
    • pgoellnerundefined
      pgoellner
      Hi everyone,
      I´m new here and try to set up a new kinematics.
      For that reason my axis have to be in a “(continuous-) rotation-mode” which means that all angles must be in 0..360° (-> Angle%360).
      From my transformation I got values from between 0° and 360° (or +-180°).
      If I will do a move from 0° to 350° the axis should not move +350°, instead the axis should take the “short” path with -10°.
      I enable in my kinematics class the function “IsContinuousRotationAxis(){… return = true;}”.
      In my opinion this should solve this problem but it don’t.
      Did I something wrong, or do I miss a setting?
      Thanks in advance, Best Peter
      Duet 3 Firmware (RepRapFirmware: v3.01-dev; RRFLibraries: dev; CoreNG: dev; FreeRTOS: master; DuetWiFiSocketServer: master)
        It sounds like some work is being done for this for version 3.2
        https://forum.duet3d.com/topic/16788/u-axis-without-limit/12?_=1592935944738
        pgoellnerundefined 1 Reply Last reply Reply Quote 0
          pgoellner @Phaedrux
          @Phaedrux Thanks for that respone. 😃
          bondusundefined 1 Reply Last reply Reply Quote 0
          • bondusundefined
            bondus @pgoellner
            @pgoellner It worked when I played around with it.
            When IsContinuousRotationAxis() returns true the firmware should always find the closest direction to rotate to reach the goal.
            It has to be a G0 move for it to do this.
            • arhiundefined
              arhi
              is there a way to set "speed" for continuousRotationAxis (start/stop) or at least multiple of 360 degrees (I need it to turn e.g. 20 turns)
              • bondusundefined
                bondus @arhi
                @arhi It's supposed to be used with polar/arm printers, if you move 360 degrees you end up at the same place.
                M92 sets steps/deg in this case and not steps/mm. For example a 0.9deg stepper with 16 microstepping and a 20:1 gearbox will be 16*20/0.9 = 355.556 steps/deg
                arhiundefined 1 Reply Last reply Reply Quote 0
                • arhiundefined
                  arhi @bondus
                  @bondus said in What’s the best way to set up a continuous rotation for an axis?:
                  Yes, but I'm thinking about multi axes cnc and want to turn a thread for e.g.
                  I can do it as ton of small moves but maybe a single multiturn move?
                  Or, I'm thinking about 3D scanner where I need to do 5-6 rotations of the table,
                  or, I'm thinking about "presenter" with rotating base + pan and tilt
                  or ..
                  There'a a million reasons one would like to have a precise continuous rotation of one axis
                  • bondusundefined
                    bondus @arhi
                    @arhi If you do not return true from IsContinuousRotationAxis() that is exactly what you get. You can still rotate multiple rotations, it only affects the automatic wrapping.
                    • arhiundefined
                      arhi
                      ah, perfect, thanks
                      • JoergS5undefined JoergS5 referenced this topic
                      • joshuabirdundefined joshuabird referenced this topic
