    Duet 3 Mechanical Bed Leveling
    27
    • wdenker
      wdenker last edited by
      I noticed when looking through the configurator that the mechanical bed leveling isn't an option any more. Is there more documentation on this new mesh bed compensation? duetquestion.JPG
      • A Former User
        A Former User last edited by
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        • wdenker
          From everything I have seen this is the old documentation on it. What changed?
          • A Former User
            g29 is the "new", g32 is the old. changed before my time afaik.
            wdenker 1 Reply Last reply Reply Quote 0
            • wdenker
              wdenker @Guest last edited by
              @bearer but it doesn't do the leadscrew leveling so why deprecate it?
              A Former User 1 Reply Last reply Reply Quote 0
              • A Former User
                A Former User @wdenker last edited by
                maybe this is what you're after?
                https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                • wdenker
                  Yes but the configurator is saying it is replaced with the new mesh bed leveling.
                  • A Former User
                    I'll defer to a higher power here, but I don't think that is what it is (meant to be?) saying.
                    • jens55
                      jens55 last edited by
                      Don't know why the mesh bed leveling should 'replace' mechanical leveling. AFAIK, it's allways been a case of getting the best mechanical leveling before running mesh bed compensation on top of the already adjusted bed.
                        The 5 point compensation had nothing to do with mechanical leveling. It was a limited form of mesh compensation based on a few defined points. It was replaced by the G29 mesh compensation because you can easily duplicate the old functionality by simply defining a sparse 3x3 point grid.
