Duet3 + supervolcano + 24v/12v+MOSFET??
Hey,
I want to connect the E3d supervolcano. I have here a 12 v or 24 v version.
Are there any explanations to wire up the MOSFET correctly?
Thanks to all
If your system is 24V then you don't need to use the mosfet, but be sure to use ferrules where the heater wires connect to the terminal block.
@barbarossa-cologne As far as I know, the 24V does not come with a mosfet, mine did not at least. I have used my 24V successfully with a Duet Wifi and wired it just like any old regular heater.
Hope this helps
-Nxt
I have a version with 12v and mosfet and another 24v without mosfet.
So I can decide which I use
ok. thanks for the fast answer.
@barbarossa-cologne said in Duet3 + supervolcano + 24v/12v+MOSFET??:
So I can decide which I useOnly if you can still also choose whether to power your Duet from 12V or 24V.
I have a power supply with 24v. So I´ll take the 24v version on out1.
Sounds right?
thanks
Sounds right?
thanksYes.
