    Added Duex5 - Really need some help
    1.2k
    • GeorgeMundefined
      GeorgeM
      When I try to home it stays busy and the arrow circles spins and then I get a homing error.
      Same with either x or y. Same if I comment out the raising of z before I home.
      Motors are plugged into:
      X in 0
      Y in 1
      Z in 2
      E in 3 or E0
      U in 4 or E1
      Well what do you know. With the duex removed and U removed from M92, it homed correctly.
      With the duex reconnected and U removed from M92 - no movement and driver 5 error is back.
      • GeorgeMundefined
        GeorgeM
        I need to leave for about 90 minutes
          Phaedrux Moderator @GeorgeM
          @GeorgeM said in Added Duex5 - Really need some help:
          The first point I expected. The second point is still perplexing.
          What happens with duex connected and M92 U removed?
          GeorgeMundefined 1 Reply Last reply Reply Quote 0
          • GeorgeMundefined
            GeorgeM @Phaedrux
            @Phaedrux said in Added Duex5 - Really need some help:
            • GeorgeMundefined
              GeorgeM
              As a sanity check, I configured X to use driver 5. When doing so I get no movement from X motor.
                How have you the Duex wired?
                https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                • GeorgeMundefined
                  GeorgeM @Phaedrux
                  Exactly like that.
                    I think you have a failed driver 5 on your Duex. When was it purchased and from where?
                    • GeorgeMundefined
                      GeorgeM @Phaedrux
                      June 26 from Filastruder. I contacted Tim there and gave him the link to this thread.
                        Well at least our endeavour wasn't totally fruitless.
                        • GeorgeMundefined
                          GeorgeM
                          I do appreciate all your attention to this. You were able to get me corrected about the U parameters. That's a win.
                          I do need to start a new thread about why my laser wont operate from gcode commands.
