Unsolved G29 G32 😱
ok
@Phaedrux nothing has changed
Then I'm all out of ideas and we're back to improving the mechanics. That's the limit of my delta insight unfortunately.
hello can you tell me if I have to set the offset of my extruder with respect to the center of the effector? maybe that's why the map doesn't compensate well
Do you mean the offset of the probe?
@Phaedrux no my titan aero is not in the center of my effector so the nozzle is not in the center of the effector
to make you better understand when I go down the z to 0 leffector and centered on my plate. but I nozzle no
That is interesting. I'm not sure, but I think you could use the G10 tool offset to better define where your nozzle actually is in relation to the center of the effector. This may actually help your G29 performance because the probe offset assumes that it's offset from the nozzle.
@Phaedrux ok i will try today. I will let you know
good morning I did not understand correctly. did you tell me about the g10 should i enter the offset here?
Yes that is where you can set the tool offset. Or in your case, the nozzle offset from the print head center position.
https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Tool_Offset_and_Temperature_Setting
ok but in homedelta as well I have to change here?
No, that's a G1 command to move the head to a X Y position, nothing to do with G10.
good morning I have not yet solved the problem today I noticed that after correcting the G32 when I go home I start with the correction of the x y axes as you see in the photo
so I was wondering if I had to resume my probe offset starting from the correction? I tell you this because if I do a small survey 100 x 50 with G29 then I print a picture of 100 mm my nozzle is not precise on the survey that I marked with a pen on the plate -
here I have to add L2?
also my calibration is not centered on what depends?
