Unsolved G29 G32 😱
@nemecek you could do that, or run the delta autocalibration multiple times until it converges to flat printing
@oliof OK thanks. when you talk about delta calibration. you mean the G32 to do it several times?
@nemecek yes until the numbers stop changing. If they don't stop changing after 4 it 5 runs you very likely have a mechanical issue (something loose, backlash, whatever) you need to solve.
@oliof ok thanks for the explanation I try now
10/07/2020 Ã 19:16:24 G32
Calibrated 9 factors using 19 points, deviation before 0.046 after 0.044
10/07/2020 Ã 19:10:43 G32
Calibrated 9 factors using 19 points, deviation before 0.048 after 0.043
10/07/2020 Ã 19:05:44 G32
Calibrated 9 factors using 19 points, deviation before 0.062 after 0.044 -
no guys it's not a mechanical problem I think that even if you load the map not the law doesn't correct there is little error in the level you can see it with the photos I sent you. I say this because I only print with the G32 and it is the same as when I also send the identical G29 nothing changes .. I can't understand what's wrong. Is it normal that here where I highlighted it doesn't activate and always like this? is my start print script correct?
G28; home all axes
G1 Z5
G30
G29 S1 P "heightmap.csv"
M116 T0 -
The highlighted item being greyed out is ok because It's referring to a different means of compensation. You are using mesh compensation (it shows it as active "compensation in use" mesh" To disable it you would use "disabled mesh compensation (g29 S2)"
@Phaedrux hello agree so here is fine. can you please tell me if my start script is correct?
Yes that looks like it should work
I'm afraid the issue is with the calibration and mesh creation being inaccurate due to mechanical issues. Some things software can't correct for.
I also tried to lower 40% of the values in the map where I highlighted in the photo above ...
without success I have not noticed any difference -
and how is it possible then that without the map doing only the G32 and putting a thickness of paper folded in 2 under the plate I adjust only the height print well
If it's printing well without G29, why use G29?
The combination of probe offset from the nozzle and effector tilt varying with position can lead to probed points being inaccurate.
yes I understand but something should change if I change the values of the map manually instead nothing changes ok thanks for everything I keep the thickness of cards under the plate
@Phaedrux
G29 S1 P "heightmap.csv also delete this from simplify3d start script? bI'm sorry if I write badly I use google translate -
Just delete the
P "heightmap.csv"
part from the start script. Leave G29 S1 intact.
