    Unsolved Duet 3 warranty process - Error: Short-to-ground on drivers 0
    403
    • kdsands88
      kdsands88 last edited by
      I am receiving Error: Short-to-ground on drivers 0.
      I am commissioning a new Core XY 3d printer using 4Gb Raspberry Pi with DuetPi. I have had shorts on the wire harness on all drives. Once, I corrected the shorts, I tested all drivers. Now I only have the error on drive 0. All other drives work. Core XY is working correctly.
      What is the warranty process? What additional information do you need?
      Thanks.
      Notes:
      Per the reseller: Spool3D Support support@spool3d.ca
      Thank you for contacting us. As per Duet3D’s warranty process, please start a new forum thread in their forum so a Duet3D technician can confirm and authorize a warranty replacement:
      https://forum.duet3d.com/
      ReferencePer Duet 3D forum page:
      https://forum.duet3d.com/topic/4160/error-short-to-ground-on-drivers-1/4
      Setup:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9D2-3S46L-1U2YD
      Used output buffers: 1 of 40 (10 max)
      Static ram: 154604
      Dynamic ram: 161432 of which 956 recycled
      Exception stack ram used: 224
      Never used ram: 76000
      Tasks: NETWORK(ready,1972) HEAT(blocked,1416) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:02:19 ago, cause: power up
      Last software reset at 2020-07-06 16:57, reason: User, spinning module LinuxInterface, available RAM 75848 bytes (slot 1)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 21.6, current 33.6, max 33.8
      Supply voltage: min 24.5, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Driver 0: standstill, reads 31964, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 31961, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 31962, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 31962, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 31962, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 31963, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2020-07-07 00:25:02
      Slowest loop: 3.58ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.86ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 0, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 16ms ago
        RX/TX seq numbers: 3450/3451
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 0.13
        Phaedrux Moderator @kdsands88 last edited by
        @kdsands88 said in Duet 3 warranty process - Error: Short-to-ground on drivers 0:
        What exactly do you mean with this?
        • kdsands88
          "I have had shorts on the wire harness on all drives" - means I got another error stated something like "one of the poles of the motor is not connected"
          Again, I root caused the errors to poor wire harness connectors/connections/solder.
          Once I fixed the connection issues, all the driver worked except driver 0.
          • T3P3Tony
            what error is now reported by driver 0?
            www.duet3d.com
            • kdsands88
              Note: the stepper motor will rotate.
              Below is the screen shot showing the error - Error: Short-to-ground on drivers 0
              • T3P3Tony
                So the motor rotates fine, just reports the short to ground on driver 0?
                Can you try the motor on a different driver?
                www.duet3d.com
                Kiwi3D 1 Reply Last reply Reply Quote 0
                • Kiwi3D
                  Kiwi3D @T3P3Tony last edited by Kiwi3D
                  @T3P3Tony
                  My experience with this issue ALWAY ends up with a terminal connection issue. I'd suggest making sure all 4 pins are crimped correct and fir inside the MOLEX housing
                  Or.....an issue with the a1 a2 - b1 b2 pairs - I had this with a recent batch of motors that were wired wrong
                  I had to wire red-green / blue-black
                  Hope these ideas help
                  Cheers
                  Ray
                    Which version Duet 3 main board is it? On v1.0 and v1.1 boards, a missing, misplaced or badly soldered diode could cause a spurious S2G error. Can you post a hi-res photo of the area of the Duet around that driver?
                    • kdsands88
                      Question: So the motor rotates fine, just reports the short to ground on driver 0?
                      Answer: Correct. The motor rotates fine, just reports the short to ground on driver 0.
                      Question: Can you try the motor on a different driver? (And, making sure all 4 pins are crimped correct and fir inside the MOLEX housing.)
                      Answer: The motor is a test motor I used to root cause the issues with the other drivers. So yes, the motor works on all other drivers with no issue.
                      Question: Which version Duet 3 main board is it?
                      Answer:
                      Pictures:
                      Test motor setup:
                      Board:
                      Drivers:
                      Driver 0:
                      • A Former User
                        A Former User last edited by
                        Does the error persist when the motor is disconnected?
                        • kdsands88
                          Question: Does the error persist when the motor is disconnected?
                          Answer: Yes.
                          Please see above picture.
                          Please confirm you see the C38 and C36 resistors are cracked.
                          Is this the issue?
                          A Former User 1 Reply Last reply Reply Quote 0
                          • A Former User
                            A Former User @kdsands88 last edited by
                            good call highlighting that, I took it to be the same fibers as scattered around the board. they can crack due to thermal stesses, but think we'll leave the judgement to dc42 and/or t3p3tony
                            • kdsands88
                              Sorry, bad quality picture.
                              New picture does not show cracks:
                              • kdsands88
                                Please confirm you will honor your warranty?
                                • A Former User
                                  You have read https://www.duet3d.com/warranty and the section about incorrect wiring?
                                  To me it sounds like you should be singing your praises that having shorts in the wiring harness only damaged one driver instead of making demands; or at the very least pick another approach to elicit some goodwill.
                                  • kdsands88
                                    bearer are you speaking for Duet 3D?
                                    I work for Ford Motor Company, and I understand my rights as a customer.
                                    Please stop speaking down to me.
                                    • A Former User
                                      in no way what so ever.
                                      see the above.
                                      • kdsands88
                                        Speaking to Duet 3D: Does bearer speak legally for Duet 3D? If not, please block bearer from posting on my official warranty claim.
                                        I am seeking warranty advice from Duet 3D only.
                                        Thanks,
                                        • T3P3Tony
                                          T3P3Tony administrators @kdsands88 last edited by
                                          @kdsands88 we have a lot of helpful users on this forum (especially @bearer ), please respect the friendly environment we are trying to engender here.
                                          It looks like the initial miswiring has damaged Driver 0 so it still works, but reports the error. Normally that would not qualify as a warranty return, however in this case we will make an exception so we can get the board back and look at the damage.
                                          Please upload your config.g file to this thread so we can see the current used etc.
                                          Separately the way the board is mounted in your test setup concerns me. the brass nuts look large enough to overlap the edge of the keepout area around the mounting holes and could wear through the solder resist on the board over repeated fitting. Its not possible to see if you are using the supplied nylon washers to insulate the standoff and nuts from the board but i would recommend using a different mounting solution with female standoffs and small head M4 socket cap screws. See: https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board?#Section_Mounting
                                          www.duet3d.com
