aviation connectors
hiya i am looking to do a massive revamp on my cable management on 3d printer and enquiring about the specs of the aviation connectors more specifically the following:
CX24 aviation connector for the steppers i.e. x, y, z, z1, e, e1
GX20 14pin for the x carriage i.e. hotend wire, fan0, fan1, thermistor
GX20 14pin for endstops i.e. x axis, y axis, z axis, fan2, fan3
however way these connectors are fleshed out for my 3d printer can these connectors handle the currents, ohms and vattage of the hotend being a 70w cartridge, the nema 17 stepper motors.
The heated bed will be a AC settup with the SSR.
Please help
As far as I know, brand name aviation connectors are rated at 5 amps. Your guess is as good as mine in regard to chinese clones.
Having said that, Creality uses a lot of aviation connectors and they seem to work well.
I would re-think the idea of 14 pin connectors - have you ever tried soldering those guys? It's possible but you might not be able to put heat shrink on.
I did not check the dimensions on CX and GX connectors ... I just know I use a lot of aviation connectors.
I hope it goes without saying that you do not use those connectors for AC mains power (but SSR signal inputs are fine)
@jens55 said in aviation connectors:
Some of them are rated for 4-500VAC and pass insulation testing with flying colours, have used them for years outside of 3d printing and have had less issues with them than say PowerCon.
If I am not mistaken, they are rated at 32 or 48V but each to their own. I would never use them for mains voltages unless they were brand name and were spec'd for that use. China imports do not qualify!
maybe I am reading it incorrectly, but when the specs sheet of the connector mentions 5 amps, does that mean 5 amp per a pin or 5 amp for the whole connection
generally pr pin; it may say something about derating the ampacity for elevated temperatures or when having high loads on all pins in a high pin density plug/wire.
might actually stick to the GX20 connector since that is mostly supported,
http://nationalconnectors.com/contact.html
Ask for a datasheet.
it that the pg to make the purchase
I am using these a lot (also the 2/3/5 pin versions)
http://www.sah.co.rs/df16-a-4b.html
they do not get warm at 5A 400V nor 5A 24V nor 5A 48V
my insulation tester goes up to 1000V and 2000M ohm and do not trip them. I have somewhere around the 2500V version too but can't seem to find it but I guess 1000V is ok for a PRC connector
