    Is this capacitor supposed to be missing
    540
    • joshuamenschundefined
      joshuamensch
      I just bought a duet 2 wifi got it hooked up and had some issues the stepper drivers said they were overheating even though they never drove any motors and the thermistor showed -2000c then I noticed an empty capacitor slot as shown in the picture was there a new revision that removed that capacitor or is it just defective thanks in advance B08C211C-2D6C-4875-8F02-FC3E73159E00.jpeg
      zaptaundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • weed2allundefined
        weed2all
        No its not supposed to be missing!where did you buy your board?
        https://www.thingiverse.com/weed2all/designs
        • zaptaundefined
          zapta @joshuamensch
          It is missing on mine.
          • A Former User?
            A Former User
            AFAIK its missing on all 1.04c boards
            @weed2all said in Is this capacitor supposed to be missing:
            ref https://forum.duet3d.com/post/111587
            joshuamenschundefined 1 Reply Last reply Reply Quote 0
              joshuamensch @A Former User
              @bearer thank you
                droftarts administrators @joshuamensch
                @joshuamensch regarding your errors, please post your config.g and firmware version (send M115 To Duet and post response). Also please post the exact error message you’re getting.
                From your picture, your X and Y motors are using plugs that are not compatible with the pin in the board, and may be making poor contact. Check your stepper motor wiring phases are correct (see https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors). You also do not have any temperature sensor plugged in for the hot end. As -273C usually means open circuit (ie nothing connected), and +2000C means short circuit (ie no resistance), I’d expect this to be an error in your config.g, usually that you have set the thermistor configuration using RepRapFirmware 3 notation, when your Duet is running RepRapFirmware 2.
                • mihaitinteaundefined
                  mihaitintea
                  Here's a photo of my board:
                  • A Former User?
                    A Former User @mihaitintea
                    @mihaitintea said in Is this capacitor supposed to be missing:
                    which is a 1.04b and it is supposed to have c99 placed. OP has 1.04c where it is removed; ref above.
                      joshuamensch @droftarts
                      @droftarts when i came back to it today i stopped getting a stepper driver overheating error but i am still having a thermistor reading error. when i put in the M115 this is the response "FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2" and attached is my config.g config.g thanks in advance
                        @joshuamensch you are running firmware version 2.03, but your config is for v3. Either update to v3.1.1 (via v3.0) or redo your config in the config tool for v2.03.
                        Most likely other things won’t work either, until you do one of those two things.
                          @droftarts thanks this worked
