    Homing issues on 2 delta printers after upgrading to 3.1.1
    Firmware installation
    1.9k
    • mhackneyundefined
      mhackney
      A remote friend and I have each attempted to update from 2.x RRF to RRF 3.1.1 following the install procedures. It all went swimmingly well except that when we home we both get the following error:
      G28
      Error: G0/G1: target position not reachable from current position
      I googled this as well as searched here but didn't find a solution. So I went back to square 1 and used the online configurator tool to generate the config files. It generates the same error. I suspect the issue must be in homedelta.g as all we are doing is clicking the Home All button or issuing G28 in the Console.
      The generated homedelta.g is nearly identical to the original version I've been using for a few years. The new version looks like this:
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 14 2020 09:11:17 GMT-0400 (Eastern Daylight Time)
      G91                        ; relative positioning
      G1 H1 X455 Y455 Z455 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
      G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
      G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
      G90                        ; absolute positioning
      G1 X0 Y0 F6000             ; move X+Y to the centre
      I've selectively commented out the last few movement lines (one at a time) in the homedelta.g file but still have the error.
      These are Ultibots D300VS deltas running Duet 2 WiFi boards that were both working and printing for several years prior to the upgrade.
      Any recommendations or insights on how to fix this are greatly appreciated.
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        • Are your M665 and M666 commands the same as before?
        • If you remove the last two G1 lines, do you still get the error; and what XYZ position does DWC then report after homing?
        • Please post your config.g file.
        • mhackneyundefined
          mhackney
          Thanks David.
          I am using the same M666 and M665.
          Ok - when I comment out the last 2 G1 lines I do not get the error. (If I comment them out 1 at a time I get the error) It reports X 3.1 Y-0.3 Z454.29
          Config:
          ; Configuration file for UltiBots D300 V-Slot 3D Printer
          ; version 1.0 for firmware version 3.0
          ; Communication and general
          M111 S0                         		; Debug off
          M550 PThing-2  				    	    ; Machine name and Netbios name (can be anything you like)
          M551 XXXXX				                ; Machine password (used for FTP)
          ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
          ;*** Wifi Networking
          M552 S1					                ; Enable WiFi
          M555 P2                         		; Set output to look like Marlin
          M575 P1 S1 B57600		    		    ; Communication parameters for the PanelDue
          G21                           		 	; Work in millimetres
          G90                          		 	; Send absolute coordinates...
          M83                           		 	; ...but relative extruder moves
          ; Axis and motor configuration
          M569 P0 S0			        	       ; Drive 0 goes forwards (X tower)
          M569 P1 S0			        	       ; Drive 1 goes forwards (Y tower)
          M569 P2 S0			        	       ; Drive 2 goes forwards (Z tower)
          M569 P3 S0				               ; Drive 3 goes forwards (extruder 1)
          M574 X1 S1 P"xstop"   ; X min active high endstop switch
          M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
          M574 Z1 S1 P"zstop"   ; Z min active high endstop switch
          ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
          M665 L376.890 R209.670 H450.462 B140.0 X0.114 Y0.283 Z0.000	; set delta radius, diagonal rod length L380.31, printable radius and homed height
          M666 X0.107 Y-0.648 Z0.542			   ; put your endstop adjustments here, or let auto calibration find them
          M350 X64 Y64 Z64 E16 I1			; Set microstepping to 32 for X, Y and Z and 16 for extruder stepper with interpolation
          M92 X640 Y640 Z640			; Set axis steps/mm
          M906 X1000 Y1000 Z1000 E500		; Set motor currents (mA)
          M201 X1000 Y1000 Z1000 E1000		; Accelerations (mm/s^2)
          M203 X20000 Y20000 Z20000 E3600		; Maximum speeds (mm/min)
          M566 X1200 Y1200 Z1200 E300		; Maximum instant speed changes mm/minute
          M950 F2 C"fan2"
          M950 F1 C"fan1"                        ; This fan is the Heatsink Fan
          M106 P1 T50 S255 H1			    	   ; Set hotend heatsink FAN1 thermostatic control at 50°C
          ; Thermistors
          M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
          ;M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor
          M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F5
          ; Heater configuration
          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
          M140 H0
          M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
          ; Tool definitions
          M563 P0 D0 H1                          ; Define tool 0, the extruder
          G10 P0 S0 R0                           ; Set tool 0 operating and standby temperatures
          ;M92 E415					           ; Bondtech BMG steps per mm
          M92 E822	                       	   ; Titan Aero steps per mm                    	old: 837
          ; Z probe and compensation definition
          ; Change "H25" to "H3" AFTER commissioning your printer
          M558 P5 C"!e0stop" X0 Y0 Z0 H4 F60     ; FSRs with JohnSL board Z probe behaves as a switch and is not used for homing any axes
          ;G31 X0 Y0 Z-0.15 P500				   ; More (-) Z is less smooshed, more (+) Z is more smooshed
          G31 X0 Y0 Z-0.25 P500				   ; More (-) Z is less smooshed, more (+) Z is more smooshed
          T0						               ; Select tool 0, the hot end
          M501						           ; Load config-override.g
            Does it work if you replace this line:
            by this:
            G1 H2 X-5 Y-5 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
            or alternatively by:
            G1 Z-10 F6000 ; move down a few mm so that the nozzle can be centred
            • mhackneyundefined
              mhackney
              Thank you David. I changed to
              And that did the trick.
              • mhackneyundefined
                mhackney
                But it did not work for my friend's machine. IO asked him to post here.
                • sLpFhaWKundefined
                  sLpFhaWK
                  Hi David, I am also having this issue which is why I got help from Michael, it seems even after changing the lines you recommend I am still getting that error.
                  Config.g
                  M111 S0                         		; Debug off
                  M550 PVader  				    	    ; Machine name and Netbios name (can be anything you like)
                  ;M587 S"Epcot" I"192.168.1.102"
                  ;M574 X2 Y2 Z2 S1			    	   ; set endstop configuration (all endstops at high end, active high)
                  M665 L376.890 R209.421 H448 B140.0 X1.000 Y0.329 Z0.000	; set delta radius, diagonal rod length L380.31, printable radius and homed height
                  M666 X-0.44 Y-1.37 Z1.81			   ; put your endstop adjustments here, or let auto calibration find them
                  M950 F2 C"fan2"
                  ; Thermistors
                  M140 H0
                  ; Tool definitions
                  Here is my current homedelta.g
                  ; Homing file for RepRapFirmware on UltiBots D300VS
                  G91							; use relative positioning
                  G1 H1 X1000 Y1000 Z1000 F2500		; move all carriages up 1000mm, stopping at the endstops
                  G1 H1 X6 Y6 Z6 F250			; move carriages slowly up 6mm, stopping at the endstops
                  G90							; back to absolute positioning
                  G1 X0 Y0 F2000				; center the head and set a reasonable feed rate
                  -sLpFhaWK
                  Ultibots K250v
                  Rostock Max v2 Soon to be Full MetalMax
                  Mini Kossel
                  Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  • mhackneyundefined
                    mhackney
                    sLpDhaWK and my config.g and other files are nearly identical. The only difference is that I have a PT100 setup on an E3D Titan Aero and he has a V67 hot end with Ultibots microstruder. Otherwise I used the exact config files that we edited together yesterday.
                      Phaedrux Moderator @sLpFhaWK
                      @sLpFhaWK said in Homing issues on 2 delta printers after upgrading to 3.1.1:
                      Can you try more than 10mm?
                      sLpFhaWKundefined 1 Reply Last reply Reply Quote 0
                        @sLpFhaWK , your homedelta.g file is very significantly different, and wrong in at least one important respect. Please take a closer look and work out what it is doing, and what you want it to do instead.
                        • sLpFhaWKundefined
                          sLpFhaWK @dc42
                          @dc42 said in Homing issues on 2 delta printers after upgrading to 3.1.1:
                          David, I've been messing with it for a good part of the morning. I even used the configurator to see what a clean homedelta.g would look like, and I've used the exact same one as Michael and I am still getting the issue.
                          Our printers are nearly identical aside from his hotend/extruder setup.
                          -sLpFhaWK
                          Ultibots K250v
                          Mini Kossel
                          • sLpFhaWKundefined
                            sLpFhaWK @Phaedrux
                            @Phaedrux
                            I can, and will. This is my homedelta.g now.
                            G1 H1 X1200 Y1200 Z1200 F2500  ; move all towers to the high end stopping at the endstops (first pass)
                            G1 H2 X-6 Y-6 Z-6 F2500        ; go down a few mm
                            G1 H1 X7 Y7 Z7 F360         ; move all towers up once more (second pass)
                            -sLpFhaWK
                            Ultibots K250v
                            Mini Kossel
                              That homedelta.g file looks better than the one you pstes earlier. But if you refer to my earlier post, I suggested to @mhackney that he change the line:
                              • sLpFhaWKundefined
                                sLpFhaWK @dc42
                                If you refer to my earlier post, I suggested to @mhackney that he change that line.
                                David you are correct, and I did change that and even though it worked for Michael it did not work for me.
                                -sLpFhaWK
                                Ultibots K250v
                                Mini Kossel
                                  dc42 administrators @sLpFhaWK
                                  So why did you post the old homedelta.g instead of the modified one? How do you expect me to help you if it appears to me that you have ignored my suggestions?
                                  • sLpFhaWKundefined
                                    sLpFhaWK @dc42
                                    David, with all due respect I haven't ignored your suggestions. I am unsure why the homedelta.g I posted didn't have your change in it, at the time I copied and pasted what Michael had sent to me in a messenger chat.
                                    But I am also confused, is that line supposed to be in the homedelta.g twice? If you look at my original code it is in there on line 5. Do I delete line 6?
                                    This is what I have now, and even now I'm not sure it's correct.
                                    ; G1 Z-20 F6000                   ; move down a few mm so that the nozzle can be centred
                                    -sLpFhaWK
                                    Ultibots K250v
                                    Mini Kossel
                                    • mhackneyundefined
                                      mhackney
                                      @dc42 So, this is odd and probably related to his issue too...
                                      As I reported above, when I made the one line change you suggested, homing worked fine. Then I homed, jogged down in Z by 200mm and reset the Duet. Now I am getting the same error - and even odder - even issuing G28 (or clicking home) multiple times, the printer does the home cycle and then generates the target not reached error.
                                      Here is my homedelta.g after making your change:
                                      G1 H2 X-5 Y-5 Z-5			; move all carriages down 3mm
                                      I have not touched my scripts and after I made your change earlier today I tested homing and jogging in Z and X-Y many (>10) times with no issues. But now after a reboot it is failing.
                                      • mhackneyundefined
                                        mhackney
                                        And removing the last 2 G1 lines as you originally requested, the error is not generated.
                                        • mhackneyundefined
                                          mhackney
                                          I've tried lowering 15 mm in the G1 H2 line third from the bottom to give a bit more room. That fails too.
                                          If I only comment the last G1 X0 Y0 F2000 no error is generated but any jog move in Z generates this error:
                                          M120 G91 G1 Z-5 F6000 G90 M121
                                            I'm not really a delta guy, but from past instances of that error it was usually enough to drop all carriages in Z to resolve the error, which from what I understand means that the requested move would require one of the carriages to raise above the endstop to be reached.
