Solved RRF3 and Duet wifi + Duex5
@JoergS5 Thank you all for your help here. It is certainly multivariate! I am going to pull it apart this weekend and bench test it... but I am leaning toward some sort of board failure and less a config error. I did learn allot (and I hope others did)... including the bit about the oft missing aux power jumper on the Duex board... completely explains why I have seen a missing 5v rail in the PWM ports there in the past. Those zingers in plain sight are the worst. I will post what I find. Thank you!
@beachtec Good luck! And I'm curious what it is.
I finally got back to the Railcore RRF3x issue and ended up pulling my boards... @Phaedrux mentioned the Duet WiFi was a cloned board... and I think that was the problem. I put in a genuine Duet board I had on hand it is has been working without a hitch. It is POSSIBLE that the very act of the board R&R corrected a wiring issue (intermittent connection) or the like... sometimes it is hard to tell if things are terminated properly. Overall a great learning... nothing gets me from rote knowledge to understanding faster than solving challenging problems - cheers.
p.s. thx to @JoergS5 too for the help!
